Author Topic: QMK firmware DIY keyboard PCB  (Read 4131 times)
Offline Diede3x0
  • Keyboard noobie
« on: Fri, 01 January 2021, 09:47:56 »
Hi!
I made a custom PCB for my DIY mechanical keyboard. I've used a At90usb1286, it is being recognized by Windows, but when trying to flash it in QMK toolbox it says: Atmel DFU device connected (NO DRIVER): (03EB:2FFB:0000)
Installing a driver through Windows gets me an error
https://imgur.com/a/TjdtOrK
How can I flash this IC?
Thanks
« Last Edit: Fri, 01 January 2021, 09:49:35 by Diede3x0 »
Offline yoot
    • none
« Reply #1 on: Fri, 01 January 2021, 09:49:20 »
This forum category is for Interest checks, not integrated circuits
Offline Darth_munkee
Re: QMK firmware DIY keyboard PCB
« Reply #2 on: Fri, 01 January 2021, 09:51:34 »
Yeah, this is for interest checks but try using AVRDUDESS to install the drivers.
Offline King Icewind
    • Keys of Kings
« Reply #3 on: Fri, 01 January 2021, 10:20:37 »
You need to press your reset button, or connect the reset pin to ground. Then within a few seconds you flash the firmware from QMK toolbox.
