Author Topic: Cheap MX Black Options?  (Read 2299 times)
Offline junkfist
« on: Fri, 06 August 2010, 19:10:44 »
I just got my Scorpius M10 and i'm absolutely loving it. A total joy to type on.
My single complaint is that I wish there was just a tiny bit more force to the switches themselves. I want a new keyboard (so I don't want to get someone's old used Model M), so I figured MX Blacks/linear force would be a good place to look. I do use this for typing and occasional gaming, but I do have a natural tendency to kind of smash keys (I learned to type on a Apple //e, that thing had the stiffest damn keyboard ever)
Is there anything cheaper than the Filco Majestouch Linear Force NKRO?
« Last Edit: Fri, 06 August 2010, 19:13:11 by junkfist »
Offline Viett
« Reply #1 on: Fri, 06 August 2010, 19:22:55 »
The Steelseries 6Gv2 is $100 shipped.
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
Offline Infinite north
« Reply #2 on: Fri, 06 August 2010, 19:25:43 »
If you are a masher but looking for something with some click you should try to find some clears. if you know what you are looking for you could pick up either blacks or clears cheap on ebay.
Offline junkfist
« Reply #3 on: Fri, 06 August 2010, 19:32:13 »
Okay, cool. Am I correct in understanding that ALPS switches should have about as much force as a a MX Black/Clear too?
Offline spolia optima
« Reply #4 on: Fri, 06 August 2010, 20:38:50 »
imho MX blacks are underrated as a typing switch. Some geekhackers swear by them. I mean, it's easy enough to say "they're not so great for typing, just look at the force diagram". But that's not the whole story. The switches really smooth due to the lack of a tactile bump. This helps with comfort. Further, the actuation point is, IIRC, a bit higher than browns and much higher than blues.
I know that I'm not saying much right there, but shoot, if you have a chance then try them out. Don't invest too much into the negative things some people say about the black MX (or any switch for that matter). It's the most widely-available MX switch, so it's no quest trying to find one on the cheap.
Oh, and for gaming, It's pretty easy to score an mx8000 series off of ebay. Many of these have full NKRO (with diodes) and are programmable.
keyboards!
Offline gr1m
« Reply #5 on: Fri, 06 August 2010, 20:42:16 »
Quote from: spolia optima;210024
This.
Offline patrickgeekhack
« Reply #6 on: Fri, 06 August 2010, 21:11:54 »
Quote from: gr1m;210028
This.
Off topic: I see you are a fan of Rémi Gaillard. I love the "bat" video.
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline washuai
    • http://home.earthlink.net/~haruai/
« Reply #7 on: Fri, 06 August 2010, 22:41:57 »
If you don't want a used board, but you like buckling springs, then you can get a unicomp.
⌨(home)Realforce 87U ⌨(backup) Filco Majestouch 104 Brown ⌨(backup)Cherry G80-8200LPDUS ⌨(work)Leopold FC200RT/AB
☛CST L-Trac-X ☛Logitech Wireless Optical Trackman ☛ Razer 3500 dpi ☛MS Explorer DeathAdder
Lay-a-bouts:  ⌨Full 109 Key Virtually Indestructable  Keyboard ⌨Compaq Radio Quack GYUR84SK
Wishlist: ⌨KBDmania Pure ⌨Déck 82 ice/frost/toxic/royal ⌨Ricercar spos G86-62410EUAGSA ☠ ✞⌨miniGuru(s) ☠
 ✐Intuos or Cintiq
Offline Oqsy
« Reply #8 on: Sat, 07 August 2010, 01:45:54 »
mx11900's are a great little board.  Not a typical form factor, but someone posted an ebay finds link to several "open box" for around $45 with double shot key caps.  It's a good deal on a damn solid board with increasingly rare cherry double shot keys as a bonus.  If you like your scorpius but want something with more force, you can always put the black switch springs on the blue switch stems for an ultra stiff blue, more in line with what you're hoping to achieve.  The double shot cherry keys and black springs on your scorpius would be a very nice change in feel and quality of experience.  If/when you decide you're bored with it its not what you were after, you can swap everything back, or sell the scorpius as a custom hybrid clicky black switch with double shots and I promise you that someone here will buy it :P
Damn, I might just put my black springs on my Dolch blue mx board with double shots when it arrives...  that sounds like a fingergasm.
Oh, ANY time you're doing a stem/switch swap, or dismantling the switches for any reason, keep some kind of tray / muffin pan around for separating and keeping track of pieces.  I usually do that, and then store the pieces each in their own individual ziplock bag, ie stems, springs, and switch casings each separated.  Oh, and ALWAYS label containers / bags containing springs to keep yourself from going insane trying to sort which spring went with which switch in the event that you ever DO want to put stuff back or make a different swap.
« Last Edit: Sat, 07 August 2010, 01:54:58 by Oqsy »
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #9 on: Sat, 07 August 2010, 02:20:53 »
To the OP-
You got many great suggestions =)
I would second the getting an MX11900
or
Go to unicomp and get essentially a new Model M
Congrats on getting what seems to be a decent M10, but I wouldn't worry about getting a second hand or nasty old ebay Model M. It will still probably waaaaay oulast your M10, LoLz!
Goodluck on your keyboard travels, tell us what you end up getting =)
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline SpatiallyAware
« Reply #10 on: Sat, 07 August 2010, 02:57:01 »
I've tried blues, browns, blacks, and fukkas.  IMO My Filco Fukka would be the best board for a 'smash' typist.  I swear it seems to stiffen up the harder you hit the keys.
I like the noise too.. it really does sound like the name when you type.  Fukka fukka fukka..
Offline Mental Hobbit
« Reply #11 on: Sat, 07 August 2010, 10:33:09 »
Just give it a week to get used to the lightness of the switches before making a decision. As you find the Blues "a total joy to type on" already, you probably have found the perfect switch for yourself.
Typing on blues.
Offline Phaedrus2129
« Reply #12 on: Sat, 07 August 2010, 10:39:53 »
Hm, has anyone tried an MX blue with a black or clear spring?
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
