Author Topic: Dygma Raise Spacebars  (Read 4826 times)
Offline RickHoen
« on: Sat, 02 January 2021, 10:49:25 »
I really miss options for my Dygma Raise spacebars. I would love MT3 or SA spacebar sets that work with the Raise (so 1.25 u, 1.5 u and 2x 1.75 u) but I have never seen anything like that, not even in different profiles.
It would be so great if someone would make these, at least in black and white, so that there are options for Raise users.
Sent from my iPad using Tapatalk
Re: Dygma Raise Spacebars
« Reply #1 on: Sat, 02 January 2021, 11:00:09 »
I think some GMK sets have had 1.75u "Space bars" but I'm not sure if they were actually convex Space Bar-profile or just blank keys, like 1.75u blank right Shifts.
Offline Parva Ovis
« Reply #2 on: Sat, 02 January 2021, 12:40:08 »
I believe the MDA keycap profile has convex spacebars in all those sizes. XDA also has 1.75u spacebars that may be still available ala carte on Aliexpress. SA, GMK, and MT3 use blank non-convex keys for spacebars smaller than 2u.
Offline RickHoen
« Reply #3 on: Sat, 02 January 2021, 13:48:15 »
1.75u is sometimes available and rarely there’s 1.25u but I don’t think there ever is 1.5u as well, let alone all these sizes in the same color/theme/set.
« Last Edit: Sat, 02 January 2021, 13:50:46 by RickHoen »
Offline RickHoen
« Reply #4 on: Sat, 02 January 2021, 13:53:31 »
Maybe MT3 blank keys are available in all these sizes but they would not be in 1 set. So you would have to buy many sets just to get the spacebars filled.
Offline RickHoen
« Reply #5 on: Sat, 02 January 2021, 14:00:17 »
You’re right about MDA. They do not have the sizes in one kit, but several small kits, so that’s doable.
I still would like to see MT3 or SA options though. Or generally more options.
