Author Topic: Having trouble with bootloadHID flashing on Linux  (Read 3092 times)
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« on: Mon, 04 January 2021, 02:34:10 »
I'm having trouble flashing a B.face_X2 PCB, in order to put QMK on it.
I am using Linux, so I built bootloadHID from source:
Code: [Select]
# Get prerequisites
if grep -iq opensuse /etc/issue
then
  sudo zypper install libusb-1_0-devel libusb-compat-devel
elif grep -iq debian /etc/issue; then
  sudo apt install libusb-dev
fi
# Get the bootloadHID source
wget https://www.obdev.at/downloads/vusb/bootloadHID.2012-12-08.tar.gz
tar -xf bootloadHID.2012-12-08.tar.gz
# Build bootloadHID
cd bootloadHID.2012-12-08/commandline
make
cp bootloadHID ~/bin/bootloadHID
export PATH="$HOME/bin:$PATH"
I plugged in the keyboard while holding Left Ctrl, and in the output from lsusb I see the line:
Code: [Select]
Bus 001 Device 027: ID 16c0:05df Van Ooijen Technische Informatica HID device except mice, keyboards, and joysticks
I tried flashing with:
  • make winkeyless/bface:via:flash
  • make winkeyless/bface:via:bootloadHID
  • make winkeyless/bface:via && bootloadHID -r ./winkeyless_bface_via.hex
and in all cases I get the following error:
Code: [Select]
Warning: could not set configuration: Device or resource busy
Warning: could not claim interface
Error sending message: Input/output error
Error reading page size: Communication error with device
And I get the following output from dmesg:
Code: [Select]
[62368.440698] usb 1-7: new low-speed USB device number 30 using xhci_hcd
[62368.635193] usb 1-7: New USB device found, idVendor=16c0, idProduct=05df, bcdDevice= 1.00
[62368.635200] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[62368.635204] usb 1-7: Product: HIDBoot
[62368.635207] usb 1-7: Manufacturer: obdev.at
[62368.655898] hid-generic 0003:16C0:05DF.0022: hiddev98,hidraw5: USB HID v1.01 Device [obdev.at HIDBoot] on usb-0000:00:14.0-7/input0
[62395.584140] usb 1-7: usbfs: interface 0 claimed by usbhid while 'bootloadHID' sets config #1
[62395.584168] usb 1-7: usbfs: process 10226 (bootloadHID) did not claim interface 0 before use
I double-checked that the following lines are present in /etc/udev/rules.d/50-qmk.rules:
Code: [Select]
# BootloadHID
SUBSYSTEMS=="usb", ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="05df", TAG+="uaccess"
I also tried logging in on a different TTY just in case the Udev rules needed a new login session to take effect.
How do I figure this out? What additional debugging steps can I take?
« Last Edit: Mon, 04 January 2021, 02:44:45 by tex_live_utility »
Offline yui
Re: Having trouble with bootloadHID flashing on Linux
« Reply #1 on: Mon, 04 January 2021, 03:06:39 »
a google search of that "usbfs: interface 0 claimed by usbhid while 'bootloadHID' sets config #1" (line that seemed to me to contain the problem, it tells you that usbhid "stole" the interface before bootloadHID could get it) gave that stack exchange article:
https://unix.stackexchange.com/questions/55495/prevent-usbhid-from-claiming-usb-device
although you will need to know the usb vendor and product id of your keyboard (i think 16c0:05df from your lsusb but not 100% sure)
« Reply #2 on: Mon, 04 January 2021, 05:17:25 »
Aha, thank you!
I added the following to /etc/modprobe.d/98-usbhid_bootloadHID.conf:
Code: [Select]
options usbhid quirks=0x16c0:0x05df:0x4
and bootloadHID worked perfectly.
For anyone reading who doesn't understand what this does: 0x16c0:0x05df correspond to the vendor and device IDs shown by lsusb, and the 0x4 is just a magic number that everyone else on the Web said to use :))
Edit: unfortunately, Via does not recognize the keyboard after flashing the Via hex, but at least I got the flashing part working.
« Last Edit: Mon, 04 January 2021, 05:20:30 by tex_live_utility »
Offline yui
« Reply #3 on: Mon, 04 January 2021, 05:30:57 »
well you maybe need to remove the usbhid quirk so that it can start communicating normally with it again, i do not know how via works on linux, or on windows to be honest, still having trouble with making it work at all.
« Reply #4 on: Mon, 04 January 2021, 13:47:08 »
I see. I commented out the line in my modprobe.d conf file, but Via still does not recognize the Bface_X2 board.
It works fine on my OK60 though (which has the standard Atmega32u4), so I know Via itself is working.
« Reply #5 on: Tue, 05 January 2021, 09:47:48 »
Update: apparently Via doesn't actually have a JSON file for the Bface_X2 :)) I will try to put one together and see if I can get it working.
