Author Topic: Looking for ABS keyscaps - pudding and floating  (Read 4664 times)
Offline dman777
« on: Thu, 07 January 2021, 21:32:59 »
I am finding I like ABS more than PBT.
Can anyone recommend ABS keycaps that would fit my ducky Shine 3 and Shine 7 full keyboards that are the below?
- Floating keycaps
- Pudding keycaps
Offline seville57
Re: Looking for ABS keyscaps - pudding and floating
« Reply #1 on: Fri, 08 January 2021, 10:03:04 »
- Floating keycaps
- Pudding keycaps
Ducky Shine 2/3/4/5/6/7 and Ducky One/2 has a standard bottom row size (Ctrl, Win, Alt, FN/Menu and Spacebar) (see link). So 99,9% sets will fit but read the text when you're lookin at the sets.
https://www.maxkeyboard.com/mechanical-keycap-layout-and-size-chart.html
The sets I could find is PBT, PBT is better than ABS (cheaper).
A guy here in sweden are lookin for a White Pudding keycaps set but you can only find it in ANSI layout, here in sweden we have ISO/Nordic layout.
So ANSI Enter and Left Shift will not fit on the ISO keyboards.
2 of mine Ducky keyboards:
The White is a ANSI Ducky One RGB YOTG.
The Black is a ISO/Nordic Ducky Shine 3.
The keycaps sets are Jukebox SA, the 2 orange pumkins don't belong to the set.
Edit: Not ABS and only 104 keys set: https://www.google.se/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwinms_P-YzuAhWJjYsKHdp_A-wQFjACegQIDBAC&url=https%3A%2F%2Fwww.hyperxgaming.com%2Fus%2Fkeyboards%2Fkeyboard-accessories%2Fhyperx-pudding-keycaps&usg=AOvVaw3Zs7WE-iT0bD2bS8amvrx0
Ducky:s own PBT set: https://www.google.se/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiexb3_ko3uAhXus4sKHc74B4sQFjAAegQIAhAC&url=https%3A%2F%2Fmechanicalkeyboards.com%2Fshop%2Findex.php%3Fl%3Dproduct_detail%26p%3D5790&usg=AOvVaw23FHuN8BuYEys4MUJ6VPeD
« Last Edit: Fri, 08 January 2021, 14:17:30 by seville57 »
Offline rinkaan
« Reply #2 on: Tue, 19 January 2021, 05:45:48 »
https://m.tb.cn/h.47zMeAg?sm=764098
option 5 is 141 keys set. Supports ISO, double check using the image.
But this is from China, might have a proxy vendor on aliexpress or bangood carrying it...
Sent from my Redmi K20 Pro using Tapatalk
Offline rinkaan
« Reply #3 on: Tue, 19 January 2021, 05:46:14 »
Pudding keycap BTW (with shine thru)
Offline Darthbaggins
  • PC Cannibal
« Reply #4 on: Tue, 19 January 2021, 09:00:12 »
Just get the Glorious or Hyper X sets. .
