Author Topic: Looking for keyboard suggestions  (Read 1971 times)
Offline cbeland
« on: Fri, 08 January 2021, 07:17:04 »
Looking for a keyboard with the following attributes:
- RGB
- TKL
- Blue cherry, white kalh box or hot swappable
- Internal memory for macro and RGB effect (will be plugged on a USB switch and used on a Mac, Linux and windows hosts and I don’t want to have to set everything when changing host)
- Floating key design with minimal bezel
- Standard key cap layout (easy to find replacement set)
- Pbt double shot key caps
- Can be bought from Canada
I bought the Drop CTRL, which checked all those boxes, but returned it because the keyboard leds were had humming noise that bothered me a lot for a 350$+ cad keyboard. I really liked it.
Do you have any suggestions??
Offline mustardgreens
Re: Looking for keyboard suggestions
« Reply #1 on: Fri, 08 January 2021, 10:35:27 »
varmilo VA87M% fits your criteria except I'm not sure about the internal memory.
Check out Durgod's TKL as well, I know they have a low profile one.
Offline Darthbaggins
  • PC Cannibal
« Reply #2 on: Fri, 08 January 2021, 11:13:04 »
I would 2nd the Durgod, surprisingly good boards for the price.  I can say I still love my CM Pro S (Rapid) - found  mine for $65 from CM's refurb outlet and it's been solid.
Offline cbeland
« Reply #3 on: Sat, 09 January 2021, 23:35:53 »
Thanks
Any thoughts on GMMK tkl?
