Author Topic: [IC] GMK Grey on Black // GB Extended Til Sunday Feb 20th  (Read 210700 times)
Offline cmander7688
Re: [IC] GMK Grey on Black
« Reply #150 on: Thu, 06 May 2021, 18:22:43 »
dope. I'd pick up a set, I'm a sucker for all things black&grey.
Offline kure_
« Reply #151 on: Thu, 06 May 2021, 21:36:38 »
this is the embodiment of "nut"
Offline dkrikun00
« Reply #152 on: Fri, 07 May 2021, 03:46:10 »
Inspiration 10/10
Looks great, good luck!
Offline leexy
« Reply #153 on: Sun, 09 May 2021, 04:22:48 »
personally don't care for accents, iso and numpad in base kit
Offline SykeJr
« Reply #154 on: Sun, 09 May 2021, 18:44:25 »
I'm liking this set a lot. Please include UK-ISO in base; if you don't, I definitely won't be buying it and if you do I definitely will.
Offline illusixn
  • Formerly illusixn
« Reply #155 on: Sun, 09 May 2021, 19:06:12 »
There is at least one person on this page that definitely won't be buying this set.
Offline VXQN
« Reply #156 on: Wed, 16 June 2021, 11:34:33 »
Hope this is still slowly moving along!
Offline Skok
« Reply #157 on: Thu, 17 June 2021, 01:56:51 »
it sure is, I wanted to teach myself how to render first before I updated the IC. Should be within a few weeks. Looking to announce vendors as well.
Offline inceptive
« Reply #158 on: Fri, 18 June 2021, 22:09:43 »
That render looks incredible.
Offline stomaha
« Reply #159 on: Mon, 21 June 2021, 08:12:26 »
Any hope for an R1 equals (=) key so we can use this on compact 1800 boards like Zambumon's Sar?
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #160 on: Mon, 21 June 2021, 16:57:47 »
This set has a sort of essential beauty to it. An instant classic! Wishing you all the best.  :thumb:
Offline moonmaster
  • big bumps, beautiful boards
« Reply #161 on: Mon, 21 June 2021, 19:29:52 »
Love it! In for one
Sent from my LE2125 using Tapatalk
Offline Skok
« Reply #162 on: Tue, 22 June 2021, 11:40:34 »
Most likely not. I'm looking to have a pretty ambitious base kit since I am switching the black to stock GMK to get better prices and there are other keys that I would prefer to add that would be of more use.
Thank you, Lewis. You as well!
Offline yuutsu
  • Consumer of Brioche Loaf
    • Desktop Designs
« Reply #163 on: Tue, 22 June 2021, 14:26:59 »
No 40's? Cringe.
Offline Tomson
« Reply #164 on: Tue, 22 June 2021, 15:47:57 »
Will you be down to change mods to Text only or Icon+Text?
Offline azzipa
« Reply #165 on: Tue, 22 June 2021, 17:31:15 »
i understand not putting it in base, but please consider an extension kit with that key as well as 7u spacebar support for macos users who detest 1.5u Alt keys. (this would require two 1.5u Super keys and an additional 1u Alt.) honestly, no point in waiting a year or more for a kit that doesn't support my preferred layout. if it's niche, i'm ok with that (but it's not).
Offline Skok
« Reply #166 on: Tue, 22 June 2021, 17:48:34 »
No 40's? Cringe.
I plan on adding 3 key 40s to the base but have decided against a dedicated kit.
The set is staying as icon mods. I highly prefer them for this set because of the less busy look.
Yeah, I am for sure interested in adding an extension kit similar to the ones found on GMK Jags/Taiga. Would also be a good excuse to add some shine throughs to the set.  :thumb:
Offline XiXora
« Reply #167 on: Tue, 22 June 2021, 18:15:35 »
YES!!! I'll get my 1.5u Supers! I love an extension kit as they seem to get more popular as times goes on.
(weirdly have collected macro column'd keyboards recently too, I'll welcome that as well ;))
Offline stomaha
« Reply #168 on: Fri, 25 June 2021, 05:01:00 »
LOVE the GMK Jags/Taiga extension kit! Please do this!
Offline nvh2092
« Reply #169 on: Fri, 25 June 2021, 05:55:18 »
I'd prefer having accent space bars or at least a 6.25u gray space bar. I like to have more color combos.
Offline bobtheguitar
« Reply #170 on: Fri, 25 June 2021, 19:58:11 »
This is good. +1 for the extension kit.
Offline menuhin
« Reply #171 on: Sat, 26 June 2021, 13:17:09 »
Any hope for a 40% extension kit?
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline Skok
« Reply #172 on: Sun, 27 June 2021, 18:31:39 »
Probably not. Out of 400 responses only 25 people asked for a 40s kit so far. I am adding 3 key 40s for physical layout support but I do not plan on adding a dedicated kit since it will most likely have trouble hitting MOQ.
Offline koolkeebs
« Reply #173 on: Sun, 27 June 2021, 18:44:23 »
I am really digging the look of this. Gives me metal vibes especially with the Iron rendor.
Offline Skok
« Reply #174 on: Fri, 23 July 2021, 23:10:18 »
Some updates:
- The custom RAL has been changed to stock CR. I've decided to do this since the difference was negligible and will allow for more flexibility in kitting and pricing.
- I've added 3 key 40s to base as well as full Alice support.
- I've dropped accent arrows from base since I don't see them being particularly necessary and will only lend itself to driving up cost whereas I'd rather have alice/40s.
- I've done some new renders on the Onyx and 910 with more to come.
- I'm working on building up the rest of the kits and still deciding on some things (extension kit, r5) before I present them here for further feedback.
- Vendors will be announced next update most likely and the set is slated to run early q4
Thanks
« Last Edit: Fri, 23 July 2021, 23:13:48 by Skok »
Offline moonmaster
Re: [IC] GMK Grey on Black // Some Updates
« Reply #175 on: Sat, 24 July 2021, 00:15:23 »
Hype
Offline Arithmetics
« Reply #176 on: Sat, 24 July 2021, 13:34:00 »
like the kits changes nice work
Offline VellFlamm
« Reply #177 on: Sat, 24 July 2021, 20:08:22 »
I love the added 40s support! I'm getting this.
Offline VXQN
« Reply #178 on: Tue, 03 August 2021, 08:22:20 »
Sad to see that this has moved to CR. Whilst it's good for compatibility, it means the uniqueness of the set as a whole has been diminished.
Offline santela
« Reply #179 on: Tue, 03 August 2021, 10:39:31 »
Personally glad that it has moved to CR as I won't have to purchase separate spacebar kits.
Offline Skok
« Reply #180 on: Tue, 03 August 2021, 11:09:33 »
This was definitely a criticism I was expecting. In reality, the difference between CR and the custom RAL was completely overstated in the original renders. The difference is pretty arbitrary in real life and all I saw it doing was driving up cost on a kit that I would like to be comprehensive and well priced. My main goal for the set was a more subdued look with the grey legends, icon mods, and an encompassing base kit which is what it currently represents. I do understand the disappointment though.
Offline Skok
« Reply #181 on: Mon, 16 August 2021, 15:22:43 »
Update 8/16/21
- I've uploaded all the kits as well as the deskmat. I plan on submitting quotes for the base kit with and without alice support. The reason for this is because CR spacebars should be useful to a good amount of sets as well as being relatively cheap. The IC form was about 50/50 on having it in base.
- I've added a Macro kit as well as an R5 kit. Both of which were requested in some capacity on the IC as well as the google form. Although they weren't the overwhelming majority they are definitely two kits I want personally. I think we definitely have more flexibility being that everything is stock.
- The accent kit is something I've gone back and forth on in terms of colors for a while. I've decided to lean into the bright neon colors as I think those contrast and look the best with the set. They add a good amount of flair for an otherwise subdued look if you so choose.
- I decided to switch the US vendor to Vala Supply in order to get a much sooner GB. The only thing we are waiting on should be deskmat protos and quotes from GMK. After that, we should have the green light.
Thanks.
Offline wndy
Re: [IC] GMK Grey on Black // Vendors, Kits, Updates!
« Reply #182 on: Mon, 16 August 2021, 16:10:30 »
Would love to have this! gl w ic
Offline Space_Case88
  • keebs, anime, video games and coffee
« Reply #183 on: Mon, 16 August 2021, 23:50:47 »
is that forties support in the base kit? yes please!
Offline Skok
« Reply #184 on: Tue, 17 August 2021, 11:20:15 »
Yup, seemed like a no brainer with the stock colors. Don't think a full 40s kit would fair too well.
Offline XiXora
« Reply #185 on: Tue, 17 August 2021, 13:47:07 »
Answered my prayers… I'm in.
Offline _IanOfEarth
« Reply #186 on: Tue, 17 August 2021, 13:47:21 »
Fantastic kitting and colors. Take my money.
Offline krey
« Reply #187 on: Thu, 19 August 2021, 11:11:26 »
definitely looking forward to this.
Kepler FC65 | 7v | Think6.5 v1 | Maja | G60 | TX75v2 | Fjell | Klippe x2 | Acrylic Tofu | CA66 | Norbaforce
Offline Skok
« Reply #188 on: Wed, 25 August 2021, 11:58:58 »
Zfrontier added for China so we now have our full list.
We are just awaiting quotes back from GMK and GB should thus follow promptly after we receive those. Looking to be sometime in October or early November depending on quotes.
Offline hottrout
  • I'd Hit Dat Key
« Reply #189 on: Fri, 27 August 2021, 05:26:39 »
Please please get UK ISO in to a kit somewhere.  Love everything about this set.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline Skok
« Reply #190 on: Fri, 27 August 2021, 19:25:59 »
Sorry, but there was very little interest in UK ISO on my IC form. Specifically 19 of 456. I opted to just do basic ISO instead.
Offline DERBS
  • N E 3u bars avail?
« Reply #191 on: Sat, 28 August 2021, 02:04:04 »
This is hot!  :p
Offline hottrout
  • I'd Hit Dat Key
« Reply #192 on: Sat, 28 August 2021, 02:30:53 »
Me sad.
Systems -
  Keyboards -
Offline konstantin
  • Formerly constexpr
« Reply #193 on: Sat, 28 August 2021, 03:49:27 »
Hi! I've been looking at these kits, and I have some suggestions and notes for your consideration.
  • Please consider offering R3 Pg Up, R4 Pg Dn either in the Base kit or the Extension kit. Currently, there is no way to get those keys, so users who need them (primarily for various popular 65% layouts) have no way of getting them.
  • The Extension kit currently has a second R4 1u Ctrl key, which is unnecessary as the only real use case for it is on 40% boards. It should be removed (e.g. to make room for the aforementioned keys) or, alternatively, changed to a generic legend such as Code or Meta so it can be used for other things.
  • Yet another approach would be to merge the PgUp/PgDn keys with the extra generic key by having just two keys and giving them agnostic legends (e.g. R3 Init, R4 Out; you can find a full list here). I'm personally fine with this approach, but I know some people don't like it. If you don't want to experiment, doing what I said in the above two paragraphs is probably your best bet.
  • On a different note, the default numpad 5 key in Base looks to be a regular, non-scooped key. This is likely just a rendering error, but you may want to fix it either way.
  • It may be worth including R5 1u Ctrl, Alt, Fn keys in the Row 5 kit, for 1800/CP, HHKB and some other layouts that are likely to use a 7u bottom row (which is what the kit is targeting). In fact, I would say that these keys would be more useful than the two R5 macro column keys, but I guess those could be a personal inclusion or something.
  • Last and kind of least, you could consider moving the second 2.25u Shift to Extension, and the Alice B to Spacebars, in order to remove some not strictly necessary keys from Base. However, I would argue against this, as you can currently get correct Alice support with just the Base kit if you're okay with using Shifts as spacebars. (There's also the fact that putting B in Spacebars would be adding an extra color to that kit.)
Thanks for reading!
« Last Edit: Sun, 29 August 2021, 07:42:56 by konstantin »
Offline Dave_Lister
« Reply #194 on: Sat, 28 August 2021, 07:05:37 »
Absolutely gorgeous kit. If this runs successfully I would also love to see a reverse colourway as someone else mentioned.
The main reason I am here however is to beg for UK ISO support. I'd also happily buy a full NORDEUK kit if that was more likely to sell.
GL!
Offline Skok
« Reply #195 on: Sat, 28 August 2021, 11:10:40 »
  • Yet another approach would be merge the PgUp/PgDn keys with the extra generic key by having just two keys and giving them agnostic legends (e.g. R3 Init, R4 Out; you can find a full list here). I'm personally fine with this approach, but I know that some people don't like it. If you don't want to experiment, doing what I said in the above two paragraphs is probably your best bet.
Thanks for reading!
Thanks for taking your time to write this out Konstantin!
1-3: I decided to skip on those keys as I didn't deem them necessary for the kit. It was definitely based on my subjective opinion and personal preference to use the 65% column the way I currently have it kitted. I am not opposed to adding them but I definitely have a bit of hesitation being that we already submitted for quotes. If I swap them into the extension kit while removing the 2nd Ctrl key this should be unnecessary. Either way, I'll discuss it with my vendors. I'll look into changing the legend in the extension kit before GB if I don't substitute in the PgUp and PgDn keys.
4: Yes it is a rendering error. When I submitted for quotes I did signify that it would be scooped and I will also add that here to correctly represent the kit.
5: This is a great point but I don't imagine many people buying the r5 kit are using 1800 or HHKB. That is just an assumption on my part and there really is no way to tell who will be buying it. The goal of that kit is to get 7u r5 support on 60s, 65s, and TKLs. Bottom rows are completely subjective and there are always many options, so although it may not be optimal for 1800 people to use 4 1.5u keys, at least the physical compatibility is still there. I will most likely keep the kit in its current configuration as that is what I am personally happy with.
6: I intend on keeping B in base as well as the second 2.25u shift since you can have physical compatibility using the shift keys as you said. Also, I wanted to keep the spacebar kit just spacebars since it keeps it just one color as well as anyone else who might need CR spacebars isn't getting an extra key that they don't need. I'd say it works out for everyone this way.
Feel free to correct me on anything I may have said that was wrong. Thanks!
Offline Lil Pai
« Reply #196 on: Sun, 29 August 2021, 05:17:59 »
Would've loved a NorDeUK kit.
Offline konstantin
« Reply #197 on: Sun, 29 August 2021, 07:41:49 »
Sounds reasonable on all counts!
I do think that swapping those keys into the Extension kit instead of the Ctrl is the best option at this point.
Re #5: Indeed, it's hard to know for sure, but I get your reasoning here.
Re #6: Good point about the CR spacebars being viable as a standalone kit, I didn't think about that.
Anyway, thanks for your consideration!
« Reply #198 on: Sun, 29 August 2021, 23:11:14 »
1800 i agree on, but i think HHKB is actually quite popular, but those people are covered by just using arrow keys like most ppl do with OG doubleshots
on the whole, i think it's not that big a deal and that you're largely correct
Offline alxbrn
« Reply #199 on: Thu, 30 September 2021, 06:38:27 »
I may just have skipped the text, but has a date been decided for when this will run?
