Author Topic: Help me choose new keycaps + where to buy in EU?  (Read 6418 times)
Offline kbuild
« on: Sat, 16 January 2021, 07:13:44 »
I decided to build a keyboard instead of buying one because I just can't find one that I truly like... So I delved deep into everything keyboard!
So far I've been using standard keycaps of Ducky Shine 3 and some new model of Shine (tried at a friend's). They're fine. But if I'm building a keyboard, I want to choose great keycaps, not fine keycaps.
What are my choices? I know that PBT is the material I should go for as opposed to ABS. I don't think there are any other materials that are any better?
I'm getting GMMK plate, so I only need keycaps and switches. That's the cheapest option and it seems to be well built. I'd prefer a bit different layout but that would raise the price by extra €150-200 because I'd need to get a casing, plate, etc separately. I'm going for their TKL option. I couldn't stand ISO format because of my typing style, so I'm going for ANSI.
I know there are different keycap profiles but I have no possibility to try them: OEM, Cherry, DSA, XDA, SA. But I really don't know which ones I should get and why - I've heard that SA is a good choice, and Cherry and OEM are the standard ones.
I'm going with clicky Kailh switches if it matters. And the GMMK plate will have LED, although I'm not 100% if I want to use it or not. I probably will because I like low lighting in my work room. Although high contrast keycaps might work too - I really love the old school keyboards. I haven't decided yet.
What are your suggestions? Any other materials? Which profile? Anything else that would help me choose keycaps?
Additionally, I've been having a hard time finding keycaps to buy within the EU (excluding UK) - customs add 50% to the price, and I'd prefer to not spend more than €50 on keycaps.
« Last Edit: Sat, 16 January 2021, 07:16:09 by kbuild »
Offline Faceman76
Re: Help me choose new keycaps + where to buy in EU?
« Reply #1 on: Sat, 16 January 2021, 07:28:56 »
Candykeys.com is out of Frankfurt.
As for the rest, it's personal preference.  I prefer OEM or Cherry profile.  I only use PBT as I hate how ABS feels once it is shiny.
FYI, Amazon in the US has a decent selection, you may find the same by you.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
Offline rinkaan
« Reply #2 on: Tue, 19 January 2021, 05:03:59 »
If you don't want to spend too much starting off and like the old school look, maybe u would like the retrovibe of durgod fusion in the Nintendo - esque red black cream colorway
Sent from my Redmi K20 Pro using Tapatalk
Offline rinkaan
« Reply #3 on: Tue, 19 January 2021, 05:09:55 »
Maybe drop ALT if u want hotswap and a 65% layout.
Alternatively you can always buy kbdfans. They have various models that are more budget friendly.
Other Chinese vendors that carry xd65 are also options you can consider.
Offline JohnWoodward
« Reply #4 on: Fri, 29 January 2021, 04:03:22 »
https://www.achieveessays.com/essay-writer.html
Order online, not a big deal.  You can find cheap.
Offline Unregistered
« Reply #5 on: Fri, 29 January 2021, 10:27:23 »
Candykeys has the EPBT Spectrum set ready to order. Base is 109€.
Offline Rx003
« Reply #6 on: Fri, 19 February 2021, 02:02:31 »
Candykeys.com or best bet would be after market in reddit. In any cases good luck with this I hope you can get one!  :thumb: :thumb:
