Author Topic: Recommendations for building an ISO-ES keyboard  (Read 7475 times)
Offline guillermo_m_96
« on: Sun, 17 January 2021, 18:10:13 »
Hi guys, first time posting here. I'm trying to build my first keyboard.
I'm trying with ISO-ES format, but it seems almost imposible the only choices for the pcb, case and keycaps that I've found are the ones from Glorious the GMMK ISO and the spanish ISO keycaps.
It is important to say that I want backlit keycaps and TKL format with hot swappable pcb which complicates the search even more.
Thank you in advance
Re: Recommendations for building an ISO-ES keyboard
« Reply #1 on: Mon, 18 January 2021, 00:14:50 »
Welcome to geekhack :)
Even without shinethrough your options for Spanish keycaps are very limited.  Maybe Ducky sell some?  They sell ISO-UK ones here...
Hotswap TKL boards also aren't common, the GMMK barebone is the most common recommendation.
« Reply #2 on: Mon, 18 January 2021, 13:44:37 »
Yeah, I've been searching but the only keycaps that I've found are the Glorious ones. There's this ones: https://www.maxkeyboard.com/iso-layout-custom-backlight-cherry-mx-keycap-set-top-print.html but VERY expensive.
And the pcb/case I didn't found anything except for the GMMK. I don't know if this one is heavy or stable enough but it's the only one that has all I want.
Offline aleck
  • im so full of topre yum
« Reply #3 on: Mon, 18 January 2021, 19:08:20 »
Busca en Amazon un Magicforce68 con teclas PBT, yo tengo uno así y tengo Ñ y Ç y todo lo demás, puedes sacar las keycaps de ahí y usarlas en algún otro teclado, son decentemente gruesas y me han durado un buen tiempo.
A menos que no te guste la fuente, ya ahí no te puedo ayudar mucho...
HHKB Pro 2 Type-S (2016)
« Reply #4 on: Mon, 18 January 2021, 19:24:44 »
Me interesa! Si tienes un enlace con el modelo específicamente te lo agradecería.
Offline aleck
« Reply #5 on: Mon, 18 January 2021, 19:39:15 »
Este es el que tengo yo: https://www.amazon.com/Qisan-Mechanical-Keyboard-Gateron-Office-White/dp/B07MMDDQDM/ref=sr_1_16?dchild=1&keywords=magicforce%2B68%2Bpbt&qid=1611020158&sr=8-16&th=1
No estoy seguro si vives en América o Europa, pero me imagino que debe de haber alguno en Amazon España.
Offline Zorkum
« Reply #6 on: Sun, 21 February 2021, 08:37:51 »
Hello,
Pbt keys with backlit and ISO-ES is really difficult to find, the only ones I could find (HaoTai) are sold out: https://candykeys.com/product/tai-hao-blue-moon-backlit-pbt-iso-es
This ones are without backlit but pbt and iso-es: https://es.aliexpress.com/i/4000843949312.html
Regarding the pcb, you still can join in the CU80 group by: https://caps-unlocked.com/cu80-iso-r3/
Hola
Encontrar teclas ISO-ES en PBT y con retro iluminación es muy difícil, solo he encontrado las de HaiTao en el enlace de arriba pero están agotadas. Tienes esta opción sin retro iluminación: https://es.aliexpress.com/i/4000843949312.html
En relación a la placa y caja, todavía estas a tiempo de unirte al groupby del CU80 (Iso, hotswap, Qmk con caja de aluminio).
