Author Topic: [IC] GMK Power Chord | Pricing | Group Buy Dec 6, 2021  (Read 110965 times)
Offline ItszBrian
    • GMK Devoted
« on: Wed, 20 January 2021, 05:50:07 »
Drive Us Crazy!
I would like to introduce everyone GMK Power Chord
About
This set was inspired by two of my interests, HKS and Raise A Suilen. HKS is a Japanese tuning company that focuses on producing aftermarket car parts that improve the performance of your car. Raise A Suilen is also from the series BanG Dream! If you know GMK Devoted, you already know. The color scheme is based on both HKS' and RAS' color schemes. The colors have been matched physically with a RAL book with official merch.
Inspirations
References and Colors Chosen
Colors: CR, RAL 180 60 50, RAL 300 50 40, RO2, MG1, WS1
The main colors are Green and Purple. The purple is lighter than GMK DY to improve readability.
The red is for the essential icons that show up on your car's dashboard. MG1 is for the pink stripes found in all HKS livery.
Kits
The kits are designed to fit most 60, 65, 70, 75, TKL, 96, 1800, Full-size keyboards in ANSI, tsangan/WKL, ISO, HHKB, Alice and more.
Fill out the IC form for more layout support!
All novelties and logos were designed by ItszBrian.
Hiragana Base Kit
-Row profiles are 112344
Latin Base Kit
Boosted Novelties Kit
Key profiles are:
-R1 1Us
-R3 Exhaust Enter
-R4 Intercooler Left Shift
-R4 1.5U and 1U Coilovers and Turbos
Music Novelties Kit
Key profiles are:
-R1 1us
-R4 Piano Left Shift
-R4 the rest
Accent Kit
-comes with 6.25u and 7u
-accent minibars
Extensions Kit
-XT support
-F13
-alpha keys with mod colors
-660
-GK64
-Spacebars 6U, 2x 3U, 1.75U, 2x 1U
-Row profiles are 12344
Renders (Thanks to Kingk22!)
TGR Jane
i69
F1-8X
Cucumber
Austin
TGR Alice
Koyu
Deskmats!
Designed by ItszBrian!
Speed
Speed Signature
Lightning
Techno
Part of this deskmat was made with Digital Circle Shapes by inZane, used under CC BY 3.0 and was modified by me.
Collabs/Artisans:
esc lab
-Innercooler Aluminum keycap
HIBI
Honeycomb Intake for car tuning.
Green Glow in the Dark Penlight for the band fans.
Mechfashion
-keyboard sleeves samples in production
Suiparacords
-custom cable in an alternating pattern of black, purple, and green using YC8 connectors
THOK
Burnt Tipped Titanium 1u keys.
Asero Foundry
-multicolored random pattern aluminum keycaps
Vendors:
Mechs & Co (USD)Deskhero (CAD)Proto[typist] (GBP)mykeyboard.eu (EUR)DailyClack (AUD)
Hiragana Base Kit$136.00$182.00£127.00€145.00$212.00
Latin Base Kit$136.00$182.00£127.00€145.00$212.00
Accents Kit$55.00$74.00£50.00€59.00$85.00
Extensions Kit$50.00$67.00£47.00€53.00$77.00
Music Novelties Kit$60.00$80.00£55.00€64.00$92.00
Boosted Novelties Kit$50.00$67.00£47.00€50.00$77.00
Asero Foundry Alu Keycaps$60.00$80.00£55.00€64.00$92.00
Hibi Honeycomb Intake$38.00$51.00£35.00€41.00$59.00
Hibi Penlight$45.00$60.00£42.00€48.00$69.00
esc lab Intercooler$60.00$80.00-€64.00-
THOK Burnt Ti$59.00$79.00£55.00€63.00-
Deskmats$20.00$27.00£19.00€21.00$30.00
HEX Keyboards (SGD)Zion Studios (PHP)zFrontier (Yuan)zFrontier (USD)
Hiragana Base Kit$1907500₯959.00$162.00
Latin Base Kit$1907500₯959.00$162.00
Accents Kit$762800₯369.00$61.00
Extensions Kit$692500₯339.00$56.00
Music Novelties Kit$833300₯409.00$67.00
Boosted Novelties Kit$692800₯339.00$56.00
Asero Foundry Alu Keycaps$833500₯429.00$66.00
Hibi Honeycomb Intake$532500₯269.00$40.00
Hibi Penlight$622700₯319.00$48.00
esc lab Intercooler--₯429.00$66.00
THOK Burnt Ti$813500₯419.00$65.00
Deskmats$301250₯129.00$22.00
https://thok.design/ will carry the Burnt Titanium keycap directly.
Group Buy
Date: December 6th, 2021 to January 7th, 2022
Signature
If want to support the set, please add this to your forum signature!
Code: [Select]
[url=https://geekhack.org/index.php?topic=110762][img height=120]https://i.imgur.com/soNIsdl.jpg[/img][/url]
Discord
Idol Band Caps: https://discord.gg/FQhWxxD
To Do:
Decide on vendors
Artisan caps
Finalize kits
Deskmat designs
Thanks
Kingk22 for the renders!
Idol Band Caps for supporting my first set!
FinalEleven!
Edits
-June 11, 2021
-Overhauled kitting, removed cat headphones for obvious reasons, removed DJ board as it felt forced in
-3 key 40's support in base
-Slightly changed colors
-Updated banner
-listed Collabs I would like to do
-Changed signature to something more in the spirit of the inspiration
-Pending on some vendors
July 24, 2021
-slightly edited the renders to reflect all possible keys in each kit
-Titanium collaborations underway, THOK and MTBKeys
-Chose new colors that resembles the colors better while having enough contrast
-Quotes have been requested, kits are finalized
-Deskmat 3 revealed
September 15, 2021
-THOK Collab image
-Asero Foundry collab and images
-Lightning Deskmat
-Zionstudios as PH proxy
October 19, 2021
-HIBI collab
October 28, 2021
-esc lab collab
November 30, 2021
-Pricing
-Group Buy date set
-Removed MTBKeys as they will not manufacture the Titanium spacebars
December 6, 2021
-Group Buy
« Last Edit: Wed, 08 December 2021, 21:23:52 by ItszBrian »
Offline ItszBrian
    • GMK Devoted
Re: [IC] GMK Power Chord
« Reply #1 on: Wed, 20 January 2021, 05:50:34 »
Reserved
Offline HungHingDaiLo
  • 無間道
« Reply #2 on: Wed, 20 January 2021, 05:55:49 »
Rice cooker novelties for Rice car's representative symbol? :D
Btw I used HKS products too for my rice car back then. Nice!
IG: @rayhhdailo
Offline paulgali
    • SKME
« Reply #3 on: Wed, 20 January 2021, 06:04:53 »
Nice. I'm on board with the kitting. B in base, Iso layout. Only, no UK ISO avail. Any plans for it?
Offline ItszBrian
    • GMK Devoted
« Reply #4 on: Wed, 20 January 2021, 06:07:59 »
Actually might add that in the IC Form haha
Fill out the IC Form! If I were to add UK ISO, should I add it in the Base Kit or Latin Alphas or both?
Offline Vegas_
« Reply #5 on: Wed, 20 January 2021, 06:15:15 »
really like this set, the inspo is unique and the colorway looks amazing! :)
Offline nvh2092
« Reply #6 on: Wed, 20 January 2021, 06:20:06 »
Can you consider move the standard (esc, enter and arrows) keys from Boosted Novelties to base? I think it's better in term of kitting.
Offline tanghus
  • BEIGE GUD
« Reply #7 on: Wed, 20 January 2021, 06:30:57 »
HKS R32?
« Last Edit: Wed, 20 January 2021, 06:36:43 by tanghus »
Offline Khaine
« Reply #8 on: Wed, 20 January 2021, 06:37:59 »
Ormsby guitar and schecter bass style novelties oh my! you can count me in :D Will fill out the IC form, GL with this set!
Offline Full
« Reply #9 on: Wed, 20 January 2021, 08:12:38 »
I love this! Awesome job! :)
Hi!
Offline Idod
  • Formerly templa23
« Reply #10 on: Wed, 20 January 2021, 13:13:02 »
You crazy bastard, I'm ****ing in
Also I better see a green lighstick rama
Offline treeleaf64
    • treeleaf64
« Reply #11 on: Wed, 20 January 2021, 17:17:05 »
I like the people in the picture that you linked. I think they are pretty
This is not even that bad of a keyset I think it is a nicely themed and it looks rahter clean because of the black
Everyone must pay the cat tax
Offline Suavity
  • Smile more! 🙂
« Reply #12 on: Wed, 20 January 2021, 17:52:43 »
Nice Boosted Novelties. Any considerations for a Rama Cap with a turbo?  :thumb:
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
« Reply #13 on: Wed, 20 January 2021, 18:24:33 »
I must have that deskmat now...I absolutely love that HKS pattern.
Offline pdlif
« Reply #14 on: Wed, 20 January 2021, 18:39:09 »
Reminds me a little of IFK Blacklight. Looks good!! :thumb:
Offline hkiri
« Reply #15 on: Tue, 26 January 2021, 15:12:10 »
Any chance to separate the accented keys from the boosted novelties kit?
Interested in base and those accent keys but not interested in the car novelties at all.
Offline Havattack
« Reply #16 on: Wed, 27 January 2021, 12:50:52 »
Cool. And looks like the people that missed cyberspace (i think that's set I'm thinking of...) should be pretty happy there's something some what similar (color wise at least) for them.
Offline CustomerSupport
  • 🕸 developer
    • Discord
« Reply #17 on: Fri, 29 January 2021, 16:58:18 »
I definitely dig the colors; keeping an eye out on this one
Offline noorejji
« Reply #18 on: Fri, 29 January 2021, 18:47:14 »
Very nice and lean kitting, and only two custom colors. I think this'll do well.
Offline WilsonWan
« Reply #19 on: Sat, 13 February 2021, 14:01:41 »
Is it possible for you to get a UK Vendor for this?
It would be amazing if you could
Offline treeleaf64
    • treeleaf64
« Reply #20 on: Sat, 13 February 2021, 17:06:17 »
A daring set  Idon't know what to thnik about it  I'll think about it some more
Offline Rx003
« Reply #21 on: Fri, 19 February 2021, 05:09:24 »
I love the color inspiration, glwic wish you all the best for this project!  :thumb: :thumb: :thumb:
Offline LAWSON
« Reply #22 on: Thu, 25 February 2021, 21:52:22 »
The boosted novelties are sweet, especially the turbos and hazard light button - GLWIC!
Offline ibcruzn408
« Reply #23 on: Wed, 10 March 2021, 01:13:52 »
Checking in.. just hope this sets off =) Now got to dust off my HKS Skyline model lol
Offline Sax_______
« Reply #24 on: Wed, 10 March 2021, 04:11:36 »
I like the set and all but wew lad that's an odd combo of themes for one single set.
Offline UswordM
« Reply #25 on: Thu, 22 April 2021, 01:06:46 »
I missed Devoted gb because of joining this hobby late, but I definitely won't miss this one. Gl on IC
« Last Edit: Wed, 05 May 2021, 01:14:53 by UswordM »
Offline ItszBrian
    • GMK Devoted
Re: [IC] GMK Power Chord | Kitting Overhaul with new renders 06/11/2021
« Reply #26 on: Fri, 11 June 2021, 23:50:59 »
Sorry for the hiatus on this set, GMK Devoted and my life got way more busy than I ever anticipated.
I have contacted a community member that has made metal spacebars before but we are currently R&D'ing to see if it's feasible
-June 11, 2021
-Updated banner
Offline ItszBrian
    • GMK Devoted
Re: [IC] GMK Power Chord | Renders and Ti Collabs 07/24/2021
« Reply #27 on: Sat, 24 July 2021, 11:58:59 »
July 24, 2021
-Deskmat 3 revealed
Every collab for GMK Devoted has gone longer than expected but now I have time for this set! I've been relatively low key on this set since I felt that the initial post was a bit premature but I'm pretty satisfied with what I have planned.
Sidenote rice cooker was a really good meme whoever suggested that but it didn't make the final cut.
« Last Edit: Wed, 29 September 2021, 15:56:36 by ItszBrian »
Offline ItszBrian
    • GMK Devoted
« Reply #28 on: Mon, 02 August 2021, 17:37:07 »
Someone asked for a color comparison so here you go! The RAL I used for the Teal is leaning more on the greener shade when compared to TU1 and TU2
Offline mr_foggy
  • neue = nope
« Reply #29 on: Tue, 03 August 2021, 17:38:36 »
man this set is good. that's all I have to say.
Offline ItszBrian
    • GMK Devoted
« Reply #30 on: Tue, 03 August 2021, 22:42:17 »
August 3, 2021
-small update but Zion Studios will also proxy in the Philippines
Offline Mr Chrome
« Reply #31 on: Wed, 04 August 2021, 08:44:22 »
This is very clean for some pretty strange inspo. But it's kinda niche... are you sure two base kits will reach MOQ?
“This plastic rectangle is alright. The plastic rectangles on top of it, though...”
Offline ItszBrian
    • GMK Devoted
« Reply #32 on: Sat, 07 August 2021, 18:37:44 »
I've gotten many requests to make the Latin Kit the "main" kit (this was when it used to be a Latin add-on kit). I liked how they both looked but I realize that many people would rather buy one kit instead of being forced to get something extra so this is my compromise. I've even structured my kitting to fit basic 40s and Alice bars to get as many single kit buyers as possible.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #33 on: Sat, 07 August 2021, 19:46:34 »
Thought this would be guitar or metal/rock music inspired, disappointed...... GLWIC though!
Offline ItszBrian
    • GMK Devoted
« Reply #34 on: Mon, 09 August 2021, 20:02:50 »
It is based on a j-rock band! With some cars added in the mix!
Offline _rubik
« Reply #35 on: Mon, 09 August 2021, 20:11:37 »
Huh. Interesting that this has flown under the radar.
ai03 Meridian € Mech 27 € E8.5 € Brutal60 € SSK White Label € HHKB Pro JP € vAEK68 Alps Blues € RF87u
Offline ItszBrian
    • GMK Devoted
Re: [IC] GMK Power Chord | Burnt Ti Caps, Paint Splatter, 4th Deskmat 9/15/2021
« Reply #36 on: Wed, 15 September 2021, 05:48:15 »
September 15, 2021
-THOK Collab image
-Lightning Deskmat
-Zionstudios as the PH proxy
Offline edwyn
  • I create stuff for CONCEPT & IDEA
    • CONCEPT & IDEA
« Reply #37 on: Wed, 15 September 2021, 11:15:29 »
Very cool looking set and THOK Collab  is also very cool
Offline qats
« Reply #38 on: Wed, 15 September 2021, 14:05:17 »
lit af
Offline mmayhem17
    • Steam profile
« Reply #39 on: Wed, 15 September 2021, 15:42:42 »
what a nice thok, i'm in!
Offline 0xtanja
  • need 1.5u supers
    • linktr.ee/tanjarinne
« Reply #40 on: Sun, 19 September 2021, 09:26:12 »
Thank you for including 1.5u Super keys!
Offline Necrolegion
« Reply #41 on: Sun, 19 September 2021, 16:26:05 »
Love the base kits! The accents are also really nice.
Offline AuroraCamo
« Reply #42 on: Mon, 20 September 2021, 00:58:28 »
I am stanning this set. What a gorgeous set.
Offline bert039
« Reply #43 on: Mon, 20 September 2021, 11:40:16 »
I could only afford an HKS intake filter back in the day lol but I'm totally in with this set  :thumb:
Offline nihonjam
« Reply #44 on: Tue, 21 September 2021, 00:15:36 »
Also a fan of HKS. This is nice.
Offline ItszBrian
    • GMK Devoted
« Reply #45 on: Thu, 23 September 2021, 02:09:40 »
Forgot to mention that I finally found zFrontier's contact so they can proxy this set. It should be much more accessible for some people!
« Last Edit: Fri, 24 September 2021, 03:47:25 by ItszBrian »
Offline evidentLEE
« Reply #46 on: Thu, 23 September 2021, 02:28:58 »
LOVE the HKS oil spill design inspiration!!! The Boosted novelties kit is amazing as well! Keeping an eye out for this one. Great work!!!  :thumb:
Give a man a gun, he'll rob a bank. Give a man a bank, he'll rob the world.
Offline ItszBrian
    • GMK Devoted
Re: [IC] GMK Power Chord | HIBI Collab 10/19/2021
« Reply #47 on: Tue, 19 October 2021, 03:13:41 »
October 19, 2021
-HIBI collab announcement
Offline Chroma Keys
« Reply #48 on: Tue, 19 October 2021, 03:18:50 »
Some nice looking artisans there :-)
FB: @Chromakeysartisans
IG: @chroma_keys
Offline thestrayed
« Reply #49 on: Tue, 19 October 2021, 11:40:49 »
Pretty noice
