Author Topic: What springs should I pair with Tealios V2?  (Read 2697 times)
Offline phensey
  • Anyone tryna slide that mode 80 my way>
« on: Wed, 27 January 2021, 00:11:17 »
So my current 67g springs on the Tealios V2 are waring down and Im looking for something new. Is there a actuation force that is ideal for the Tealios V2?
Offline S61
Re: What springs should I pair with Tealios V2?
« Reply #1 on: Wed, 27 January 2021, 02:46:38 »
The key choice is between standard or long spring when springs pressure are same,it depends on whether you like lightness or push-fingers
Offline phinix
« Reply #2 on: Wed, 27 January 2021, 04:24:21 »
I have a brand new pack of SPRIT MX 78 gold plated - I kept it for my second set of Tealios v2, but didn't mod after all, I have modded one set with these are are great.
Offline Sup
« Reply #3 on: Wed, 27 January 2021, 07:15:55 »
With what springs you should pair the Tealios V2? the ones you like.
current
Coming soon
Offline Leslieann
« Reply #4 on: Wed, 27 January 2021, 20:29:10 »
How do springs wear?
They can sag or go soft but I can't imagine that's already happened.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline HungerMechanic
« Reply #5 on: Wed, 27 January 2021, 21:08:35 »
This shouldn't be happening, but Zeal springs are the weakest part of the switch IMHO. Pretty much any name brand would be better, from TX to Spirit.
I personally enjoy 65 TX in my linears, as well as 63.5 Spirit. The 65 TX will probably be close to Zeal 67.
