Author Topic: [IC] GMK Pulse Custom Matching Cable  (Read 6522 times)
Offline Sinhailien
    • @pump_upp - best crypto pumps on telegram !
« on: Sun, 31 January 2021, 22:47:04 »
This interest check is for a custom keyboard/device cable that will match as closely as possible to the GMK Pulse Keycap set.
All cables will come with a 6" Inch coil with a 90 degree turn from the device to coil, and then 90 degree turn from coil to host cable. Along with aviator connectors, and USB-C unless specified in the form. The other half will be a 5' foot straight cable. Cables will be tested thoroughly prior to shipping to guarantee quality. Cables are sleeved in MDPC-X, and then double sleeved in Techflex.
Cable Color: Pulse Blue
Heat Shrink Color: Black
The price per cable would be $55 which would include free shipping to the CONTUS. If wanting to be shipped internationally, can do on buyers expense.
Link to previous work: https://imgur.com/a/XIS4yL6 (update will come soon with pictures of actual cable color.)
Link to IC Form: https://forms.gle/GwvvK6TZ2hv8qVWw6
Offline iinko_mk
  • Status: broke
Re: [IC] GMK Pulse Custom Matching Cable
« Reply #1 on: Mon, 01 February 2021, 09:37:26 »
wtf is this, this is not an IC, this would be more suitable as a reddit ad. Please don't post this in the IC section, crap like this clogs the forum
Offline Havattack
« Reply #2 on: Mon, 01 February 2021, 15:03:45 »
You even painting your aviators? Come on bra, you gotta level up!
In all seriousness, I'm not sure cables warrant their own separate IC, and should probably just stay on their respective Keyset page. (I realize there isn't one for Pulse, and youre doing this on your own, but ...maybe you shouldn't..?)
At least just throw together a prototype or 2 to show on this page.... At this point, I could just take the specs you mentioned and have my cable guy one make one (and with a colored aviator too..) and have it on my doorstep in a few weeks.
« Last Edit: Mon, 01 February 2021, 15:05:57 by Havattack »
