Author Topic: [IC] IRON165 by Smith + Rune, Round 2 (MORE BOARDS OFFERED, GB TOMORROW!!)  (Read 181264 times)
Offline voxkey
New year, new Iron165! Prototypes are done, group buy date is set! We’ve come prepared.
Group Buy Thread
Smith + Rune Website
Join Smith + Rune Discord
Follow us on Instagram
After the success of the Iron180 group buy we were left with some big questions. What do we roll out at the beginning of the year? A new Iron in a different layout, or perhaps another new series of boards entirely, but we decided a revisit to our debut board made the most sense.
The Iron180 saw many little tweaks and improvements over the original Iron165, and we’re continuing that trend of optimization again for round 2.
Timeline, Vendors, and Quantities
Group Buy Start Time
The group buy will go live on February 27th, 2021 at 10 AM EST worldwide!
Countdown Timer
Vendors, Pricing, and Quantities
We're very proud to announce we've partnered up with CannonKeys in the US, DeskHero in Canada, MyKeyboard in the EU, and ILUMKB in the AP/China market to handle sales once again.
If you are unsure which vendor covers the country you live in, please reach out to the vendors directly to confirm.
Vendor Links
CannonKeys - North/Central/South America Vendor (excluding Canada) - About CannonKeys Raffle Queue
500 boards, region locked, CannonKeys hybrid FCFS/raffle checkout. Limit 1 per household.
$424 USD
DeskHero - Canadian Vendor
150 boards, region locked for first ten minutes.
$566 CAD
MyKeyboard EU - European Vendor
300 boards, region locked, Koi raffle system
Click here for Koi Raffle System info
The raffle will take place here:
https://www.koi-raffle.com/
To join the raffle you need to join the Koi Raffle System Discord. The following link should be the invite, otherwise google for it: https://discord.gg/yxqVMrw
After joining the discord you need to verify yourself in the registration channel (should be the only channel you can see) to verify just press the thumbs up reaction on the bot-post in that channel like over 9k others have. After doing so you will get the verified role (your name is blue and you can access the verified channel).
Next you head to the website (koi-raffle.com) and log in with your discord account.
If you followed the steps above and are verified on the server it should work and your discord username, hash and email will be displayed at the top of the website.
To change the email you will have to change your discord email and re-log into the website.
Once the raffle starts it will be displayed on the koi-raffle website and allow you to join. The raffle will not be visible to you if you are not verified on the server!
If you win an invoice will be sent to the displayed email.
The raffle will remain open for 12 hours.
€424 w/VAT included
iLumkb - AP Vendor
500 boards, region locked, FCFS
$566 SGD
Iron165 Changes for Round 2
  • Deeper gasket pockets, allowing the same poron gaskets, but with less overall compression, making the case easier to assemble
  • 0.25mm top case height increase, to better hide keycaps that aren’t as deep as GMK, while still maintaining the same overall switch height
  • Better, beefier, longer screws
  • Removal of cable channel
  • Revised PCB with VIA compatibility **NOT HOTSWAP**
  • Further optimized consistency aluminum plate
  • All aluminum construction
  • Many other minor tweaks to optimize machining
Iron165 Features
  • 7 Degree Typing Angle
  • Full Gasket Isolation Mount
  • Bottom Accent Plate w/exposed rune logo
  • Low-Profile Front Height (less than 17.25mm)
  • Seamless Case Design
  • QMK/VIA compatible PCB, designed in collaboration with Gondolindrim
  • Unified C3 USB-C daughterboard (centered on case)
  • Optimized plate for consistency on every key press (see analysis below)
Iron165 Colors
Each board comes with a black anodized aluminum base and contrasting aluminum accent plate and aluminum badge. Please refer to the renders for a visual depiction.
  • Midnight Teal
  • Graphite
  • Red
Addons and Extras (All prices in EUR include VAT)
  • Extra PCB w/daughterboard and JST cable - $60 USD / €60 EUR / $80 CAD / $79 SGD
  • Extra Aluminum Plate - $40 USD / €40 EUR / $53 CAD / $53 SGD
  • Forged Carbon Plate - $50 USD / €50 EUR / $67 CAD / $66 SGD
  • Stainless Steel (mirror polished) Weight and Badge Set - $175 USD / €175 EUR / $232 CAD / $235 SGD
  • Copper Weight and Badge Set - $100 USD / €100 EUR / $133 CAD / $135 SGD
  • Brass Weight and Badge Set - $90 USD / €90 EUR / $119 CAD / $120 SGD
Additional Information
- Badges and weights will only be sold as addon sets to simply order fulfillment across all vendors due to the increased quantities offered. We're planning to order many extra badges for the online store though for those original Iron165 owners who'd like a new and different badge.
- We are adding a small pocket to make it compatible with other JST 65% PCBs on the market. This should help ensure that even if we run out of stock on PCBs that a suitable replacement can be found in a pinch.
Supported Layouts
There will be three plate layout options, semi-fixed. All plates support split backspace and stepped caps. ISO plates may not be available from all vendors.
  • Tsangan (7u bottom row)
  • ANSI (6.25u bottom row)
  • ISO
What's In The Box
  • Iron165 Keyboard
  • Aluminum Plate
  • PCB, USB-C Daughterboard, and JST cable
  • Gaskets and all mounting hardware
  • Iron165 custom carrying case
Optimized Plate, the Process, and FEA analysis
Keyboard plate FEA analysis was needed to measure deflection and try to achieve a uniform plate deflection distribution across the keyboard. You can read more about our process and testing methodology in the original Iron165 IC.
https://geekhack.org/index.php?topic=101470.0
FAQ
Wait! Where’s the Iron265!?!?!
While we did make a bunch of optimizations to the Iron165, we didn’t feel it warranted a full version bump. The naming convention we follow is series name + version number + layout.
Okay, cool, it’s a 165 and not a 265, but how will be tell them apart?
Visually this should be quite easy, especially because this one is not the SE (special edition) version, which means no giant through-hole weight, but an entirely differently designed bottom accent.
Gotcha, so this is just Iron165, not Iron165 SE, and kinda like the Iron180 with no designation after it?
Yep, you got it :)
So this doesn’t have a crazy amount of brass like the SE, so will this be less expensive?
That’s the hope! We don’t have any pricing info yet, so we can’t really talk about it as a new, affordable Iron, but that’s the goal.
SE, FE, no designation, I’m still a bit confused.
The goal is that long-term our naming system will scale as more boards get released. Currently a board with no designation is representative of the standard version of that board. We’ve reworked this a bit since our first release where we referred to the SE as the standard edition, which in hindsight didn’t make much sense. We’ve since decided to repurpose SE to mean a special edition. In the case of the Iron165 SE, that meant a liberal use of brass throughout.
Why not just use the round number in the naming convention?
At first glance, this seems like a great solution until it isn’t. What I mean by that is it might not mean much. Let’s say we run the 165 in the future but nothing changes and no improvements were made, and then a year later we run it again with some improvements. It would become very confusing to track changes across multiple runs.
Sounds good! But where is the PC!?! I’ve seen pics! I’ve seen leaks!
The Iron165 PC will be released as an in-stock board later in the year and will be much more limited in number. More info on this board coming soon.
I have a question about something that isn’t covered here!
Make sure to check out the original Iron165 IC here: https://geekhack.org/index.php?topic=101470.0
Or shoot us an email, visit our instagram, or join our Discord. Links are at the top.
Interest Check Disclaimer
Keep in mind this is an interest check. Nothing, including options, pricing, etc, is final until the GB starts. This IC represents the most correct, up-to-date information we have regarding the Iron165 at this time. Some things may change.
We will be announcing any changes, if any, here first, and on Discord as well.
Renders
Prototypes
Proof of concept, please refer to the renders for colors offered in this round
Addon Weight and Badge Set Prototypes
Special Thanks
  • LBaron, the other half of Smith + Rune!
  • Mods, admins, and of course, the Inner Circle, best team ever!
  • The entire Smith + Rune community, a bright light in a sometimes very dark world
  • Everyone who has supported us this far. We couldn't have got to this point without you!
« Last Edit: Fri, 26 February 2021, 11:19:31 by voxkey »
Offline yoniwolf1202
Re: [IC] IRON165 by Smith + Rune, Back for Round 2!
« Reply #1 on: Mon, 01 February 2021, 17:01:48 »
Ayyy
Offline ThePanduuh
  • Discord @thepanduuh
« Reply #2 on: Mon, 01 February 2021, 17:01:53 »
FirstSecond, heck yeah!
Edit after reading through: Looks like some great improvement over R1! The screws were already much beefier than most boards I've built, and the deeper gasket pocket for less compression sounds like a helpful assembly bit.
« Last Edit: Mon, 01 February 2021, 17:06:12 by ThePanduuh »
I have some keyboards, mostly resin.
I like CAD. Making things is fun. [W] Projects
Offline stopitsme
« Reply #3 on: Mon, 01 February 2021, 17:02:04 »
rr
Offline Draxion
« Reply #4 on: Mon, 01 February 2021, 17:02:14 »
Gib me
Offline Idod
  • Formerly templa23
« Reply #5 on: Mon, 01 February 2021, 17:02:18 »
BIG NUT
Offline 7empest
  • ༼ つ ◕ ◕ ༽つ
« Reply #6 on: Mon, 01 February 2021, 17:02:23 »
Well these colors are dope... damn just got the iron180... now i gotta get this too? RIP wallet... in stock PC tho???? oh yeaaaaaa
« Last Edit: Thu, 04 February 2021, 20:27:05 by 7empest »
Offline iinko_mk
  • Status: broke
« Reply #7 on: Mon, 01 February 2021, 17:03:04 »
This is pog
Offline ZongZiWang
« Reply #8 on: Mon, 01 February 2021, 17:03:12 »
Just need it! Glad there are more options but also really wish the original plum color can come back someday.
Offline Demagine
« Reply #9 on: Mon, 01 February 2021, 17:03:37 »
RNGesus please bless me this once
Offline Beenoman
« Reply #10 on: Mon, 01 February 2021, 17:04:06 »
gib
Offline Ireojimayo
  • Yo dayo
« Reply #11 on: Mon, 01 February 2021, 17:04:14 »
Super Excited for this, hope you consider Deskhero as a vendor again, like with Iron 180
Offline kuro0renji
« Reply #12 on: Mon, 01 February 2021, 17:04:18 »
Take my money!
Offline keebnewb
« Reply #13 on: Mon, 01 February 2021, 17:04:38 »
Red good  ;D
Offline Ihso
« Reply #14 on: Mon, 01 February 2021, 17:04:44 »
My body is ready
Offline kohalified
« Reply #15 on: Mon, 01 February 2021, 17:05:13 »
GOTTA STRIKE WHILE THE IRON IS HOT
« Last Edit: Mon, 01 February 2021, 17:13:05 by kohalified »
Offline Pach
« Reply #16 on: Mon, 01 February 2021, 17:05:31 »
jesus christ
also HYPE!!!!
Offline Dragxt
« Reply #17 on: Mon, 01 February 2021, 17:06:29 »
Wooooo!
Offline misswaffle
« Reply #18 on: Mon, 01 February 2021, 17:06:43 »
Yes please
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
« Reply #19 on: Mon, 01 February 2021, 17:08:08 »
This time I need one for sure!
Offline IOVERCALLHISTIOCYTES
« Reply #20 on: Mon, 01 February 2021, 17:08:18 »
ready to take an L
Offline aaronlau
« Reply #21 on: Mon, 01 February 2021, 17:08:45 »
In. Will complete the "Holy Trinity" of my collection.
Offline dRnRcRr
« Reply #22 on: Mon, 01 February 2021, 17:09:16 »
Let's go round 2
Offline voxkey
« Reply #23 on: Mon, 01 February 2021, 17:09:40 »
Colors haven't been decided yet. These are just prototypes we had made to confirm the changes.
When we get closer to deciding on colors, we'll have them rendered and get anodizing samples.
Stay tuned! :)
Offline DeMechanica
« Reply #24 on: Mon, 01 February 2021, 17:10:04 »
Be still, my beating heart
Offline AnguisInterAves
  • In pursuit of THOCC
« Reply #25 on: Mon, 01 February 2021, 17:10:14 »
I want. Give now.
Offline Xanira
  • Where am I? Who am I?
« Reply #26 on: Mon, 01 February 2021, 17:10:49 »
time to not win :)
Offline Ramen Champ
« Reply #27 on: Mon, 01 February 2021, 17:11:00 »
Cool!
twitch.tv/ramenchamp_
Offline dr_huru
    • Dr Huru's Twitch Channel
« Reply #28 on: Mon, 01 February 2021, 17:11:30 »
yes please
Offline Perch
« Reply #29 on: Mon, 01 February 2021, 17:11:47 »
I've been waiting so long
Offline ligongduck
« Reply #30 on: Mon, 01 February 2021, 17:12:28 »
Here we go!
Offline //gainsborough
  • MATRIXの日常
« Reply #31 on: Mon, 01 February 2021, 17:12:45 »
Yo
Offline CookieFlow
« Reply #32 on: Mon, 01 February 2021, 17:13:57 »
٩(◕‿◕)۶ yay
Offline MonsterM
« Reply #33 on: Mon, 01 February 2021, 17:15:03 »
Waiting...
Offline tacotemptations
« Reply #34 on: Mon, 01 February 2021, 17:17:23 »
can't wait to take the L on e-white or plum <3
Offline Zach
« Reply #35 on: Mon, 01 February 2021, 17:18:00 »
dope
Whale x2 | Salamander | E6.5 x2 | E8.5 | Nunu | 2.0 ADD | 8XV2.0 | 1.2 OG | Noah | Polaris | Vega | Infinitum | KFE CE | Jaguar | Frog  | Whale75 | Mode80 | Kei | Mode65 | E7v2 SE | Dolphinv3 | *165 | *Tomo | *Cloudline | *Kage | *Bias | *3.0
Offline NathanAlphaMan
« Reply #36 on: Mon, 01 February 2021, 17:21:15 »
Tfw it's not called 265
Offline hkiri
« Reply #37 on: Mon, 01 February 2021, 17:22:20 »
ResidentSleeper
Offline ohwe
  • no
« Reply #38 on: Mon, 01 February 2021, 17:23:01 »
I am viewing with a reasonable level of intent. I'm kidding. Prepping for the L
Current rotation: Rama U80-A, Rama Kara, Mode65 (Maroon/Brass)
Offline ServedWithRice
« Reply #39 on: Mon, 01 February 2021, 17:24:56 »
Beyond Interested!! Been waiting for R2 for more than a year after missing the extras. Not a huge fan of the red, wouldn't mind  e-white.
Offline mikagee
  • Nobody helps me
« Reply #40 on: Mon, 01 February 2021, 17:29:01 »
I shouldn't be looking for another board but.....
Offline Agilr
  • Never stop achieving
    • Discord Server
« Reply #41 on: Mon, 01 February 2021, 17:31:35 »
Putting past the potato quality images, surely there were enough effort to realise the boards aren't even centered in the photos right?
Seems like an oversight for something that people consider 'high-end'
Offline Vaiur
« Reply #42 on: Mon, 01 February 2021, 17:36:21 »
Must buy.
CB87:Sakabato Black/Red/Brass | Think6.5v2 Deep Ocean 1u | Alpine65 eWhite | Vega Grey | RAMA u80a SEQ2 Sage | Iron165 r2 Graphite | Mode80 Lotus | Geon Frog F12 Black | Keycult 2/65 Purple Unfinish | Geon F2-84 Black | JJW Cloudline Navy/Silver | Iron165 r2 PC Atomic Purple
Offline baccaan
« Reply #43 on: Mon, 01 February 2021, 17:36:47 »
Here we go again. Still have PTSD from the 180 drop last year.
Offline Zoba
« Reply #44 on: Mon, 01 February 2021, 17:38:09 »
Nice board, can't wait!
Offline pixelpusher
« Reply #45 on: Mon, 01 February 2021, 17:42:12 »
 :thumb:
Offline anticlockwise5
« Reply #46 on: Mon, 01 February 2021, 17:50:23 »
In!
Sent from my SM-G981U1 using Tapatalk
Offline bball2
« Reply #47 on: Mon, 01 February 2021, 17:52:28 »
Hope you guys include deskhero for the group buy once again!
Offline reaLFX
« Reply #48 on: Mon, 01 February 2021, 17:55:55 »
hotswap option plz
Offline MrMar
    • Instagram
« Reply #49 on: Mon, 01 February 2021, 17:59:50 »
