Author Topic: CLOSED  (Read 2308 times)
Offline GateronShaun
CLOSED
« on: Sun, 07 February 2021, 03:43:02 »
CLOSED
« Last Edit: Sun, 07 February 2021, 23:06:28 by GateronShaun »
Offline whirlwind
Re: [IC] GMK Timesuit
« Reply #1 on: Sun, 07 February 2021, 03:57:04 »
Reserved
Offline Afresh
« Reply #2 on: Sun, 07 February 2021, 04:27:38 »
Offline dandruff
« Reply #3 on: Sun, 07 February 2021, 04:39:26 »
Besides your pictures being small and unusual layout for the keys, I took a quick look over it and:
- For the alt alphas kit, space out the ones on the right side by row numbers \| should be in R3 and R4 not side by side (same with arrow keys in base kit, unless we're going with CHAD R1 arrows)
- No 2nd B anywhere
- 2nd 2.25 shift key for layouts like 660 (I think)
- Your control key in place of caps lock is the wrong color
- So is your 1u R4 FN Key
- Spacebar kit is (no offense) terrible.... you have no support for alice layout/ergo etc. Most spacebar kits sell for compatibility rather than just pretty spacebar accents. And honestly, I can't tell if you're just adding in 6.25u/7u black space bars even though those are already in your base kit. I don't understand your spacebar kit makes sense at all. (Unless you just hate those users... ofc...)
prob more but yeah! GLWIC
Offline Biskwit157
« Reply #4 on: Sun, 07 February 2021, 05:12:55 »
It might be better to make a separate iso kit (or at least add a red enter iso key in the white alpha variant)
Offline LittleAad
  • Hello
« Reply #5 on: Sun, 07 February 2021, 07:18:39 »
F for Alice support  :(
Offline treeleaf64
« Reply #6 on: Sun, 07 February 2021, 13:30:20 »
Leader of the Gateron gang
Disclaimer:
May display immature behavior
May talk in third person
Treeleaf's Youtube Channel!
https://www.youtube.com/channel/UCAVQHinK0K-AjLlbc7MZjfA?view_as=subscriber
Offline psxndc
« Reply #7 on: Sun, 07 February 2021, 14:21:24 »
- No 2nd B anywhere
I consider this a feature, not a bug.
Offline Shiba1337
« Reply #8 on: Sun, 07 February 2021, 14:49:37 »
I tried to give you help on this
just saying
 :-X
Offline Arithmetics
« Reply #9 on: Sun, 07 February 2021, 15:51:59 »
blah
Offline NovaRMK
« Reply #10 on: Sun, 07 February 2021, 16:04:51 »
Probably should have spent a little more time in the development phase before posting ic...
Offline Ashen_21
« Reply #11 on: Sun, 07 February 2021, 17:41:29 »
I like the idea behind this set, but if it was really supposed to be the time suits, they're more prodominately white over the black that was used for the alphas. I feel like it would make sense to have that alt alphas as the base alphas, and change the accent on the escape and enter to be the black. Otherwise GLWIC!
