Author Topic: [IC] Keeblast TKL [Updated-Discord channel]  (Read 40464 times)
Offline Toriaki
« on: Mon, 08 February 2021, 18:46:42 »
Introducing Keeblast TKL
An anodized aluminum case with full brass bottom, hot swap PCB and a gasket mount plate.
Update x2
Ladies and gents!
In order go give you updates more often, we've created a modest discord server.
You can access it through this link: https://discord.gg/sGKJY5aZvM
Feel free to come along!
Update
Ladies and gents,
We're getting the last parts to the CNC very soon! (Prototype even closer!)
We're also having and E-White option and not an anodized white (aparently, that's not even a thing).
And we'll implement some of your suggestions:
- Split left shift support
- Split right shift support
- Split backspace support
If you don't see your suggestion here, don't worry, we're still going through them!
261831-0
261833-1
261835-2
261837-3
261839-4
261841-5
261843-6
261845-7
261847-8
261849-9
261851-10
Specifications
Case
Anodized aluminum top and body;
Both regular and WKL top available;
Full brass bottom (optional aluminum bottom);
Internal cork dampener;
Typing angle: 6º;
Colors considered (dependent on anodization services, to be confirmed):
        White Soul (matte white)        Classic Blue (blue)        Coal (matte black)        Bok Choy (green)        Burgundy (red)        Peach Bud (pink)        Pak Choi (purple)        Excalibur (gray)
Plate
ANSI and ISO support;
USB-C connection;
Aluminum or brass body.
PCB
ISO or ANSI available;
QMK and VIA compatible;
Per key RGB led;
Hot swap;
Considering a black version.
Includes knob, rotary encoder and OLED screen.
Does not include keycaps or switches!
Expected price for this kit:
Aluminum bottom version - TBD
Brass bottom version - TBD
Prototype coming soon!
Please register your interest and leave any tips/suggestions by filling this form!
https://docs.google.com/forms/d/e/1FAIpQLSeZa4vfQqu8kMrTjFCScfuKVilZEU1_Lg2gvVXm-oostUWTXA/viewform?usp=sf_link
Thank you <3
« Last Edit: Wed, 30 June 2021, 06:06:18 by Toriaki »
Offline Alejo1707
  • Gimme some more caps!
Re: [IC] Keeblast TKL
« Reply #1 on: Mon, 08 February 2021, 18:51:11 »
A TKL Sat75
Sent from my GM1917 using Tapatalk
Offline Oggi
« Reply #2 on: Mon, 08 February 2021, 18:51:57 »
kinda sus
Offline geohammy
« Reply #3 on: Mon, 08 February 2021, 18:53:07 »
Good price
Unagi, Bias, Dolphin, XTAL
Join the YVKB Discord:
https://discord.gg/pCjDYqup6r
Offline frostykoala
  • consider Nightlight
    • Check out some Renders :)
« Reply #4 on: Mon, 08 February 2021, 18:53:23 »
this is a TKL, looks interesting especially with that price point
Offline Xerpocalypse
« Reply #5 on: Mon, 08 February 2021, 18:58:49 »
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
« Reply #6 on: Mon, 08 February 2021, 18:59:04 »
i see tkl im interested
But need to see proto
Offline eniigma
    • Storefront:
« Reply #7 on: Mon, 08 February 2021, 18:59:35 »
Ne screws avail?
Very interested to see if you can hit that price point
Offline Ustinj
« Reply #8 on: Mon, 08 February 2021, 19:04:35 »
looks like it needs to be ironed out a bit, but the tkl with knob + oled there has been on the mind for a while, good idea - not many people typically use those three keys anyway
Offline Alejo1707
« Reply #9 on: Mon, 08 February 2021, 19:06:40 »
True, I use print screen and be done with those.
Offline MidnightSnek
« Reply #10 on: Mon, 08 February 2021, 19:07:47 »
How are you getting this board's pricepoint so low?
Offline fropsie
« Reply #11 on: Mon, 08 February 2021, 19:14:32 »
I think it is best to go back to the drawing board with this and come back with a more flushed out idea.
For starters, just after looking at your renders you don't seem to have actually implemented any screws into the design. As a big FYI here, you need screws to put the board together, unless you're thinking of magnets, which won't be able to hold that massive bottom together with the case top.
(Also haven't seen a USB port in any of the renders - but I am going to give the benefit of the doubt in that it is somewhere on the rear of the case top that we just can't see from the render angles provided)
For the flex cut in your plate, I would suggest moving the top most cut above row 3 rather than keeping it below, as not doing so can result in pretty inconsistent flex - this isn't me just talking out of my ass, but out of experience testing flex cut positioning on a range of formfactors.
In regards to your estimated pricing, I implore you to just delete that section right now. You evidently have no clue how much these units will cost as you put a mere 40 euro price difference between a brass bottom vs alu bottom board, in which just by looking at the design, that would be massive f*cking piece of brass. Estimated prices are generally better once you have a good idea as to what your board would cost to machine plus hardware/packaging/PCBs/etc.
There are a few things that I personally am not fond of with this design, but that is not my place to say.
Please take this back to the drawing board and spend some more time on this project to push it in the right direction.
GLWIC
Offline vnflynn
« Reply #12 on: Mon, 08 February 2021, 20:21:39 »
Colors looking good but TKL Satisfaction75
Offline keeganzero
  • huhu
« Reply #13 on: Mon, 08 February 2021, 21:04:05 »
Overall feels uninspired.  Hopefully your prototype does more justice then the renders do.
Offline kk73715
  • Why are you even reading
« Reply #14 on: Mon, 08 February 2021, 21:06:08 »
what was the listed price point before the post was edited?
Offline Alejo1707
« Reply #15 on: Mon, 08 February 2021, 21:15:55 »
2 dollars  ;D
Offline Chippy
  • sus chef
« Reply #16 on: Mon, 08 February 2021, 22:06:21 »
Interesting...going to wait to read this when it's more thought-out with better renders before I judge this and call it a tkl satisfaction.
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline powwu
    • Discord
« Reply #17 on: Mon, 08 February 2021, 22:11:03 »
Offline oathsworn
« Reply #18 on: Tue, 09 February 2021, 01:01:02 »
Interested, would def be on one of my to cop lists if it's hotswap and usb isn't in the center ^-^
Offline Toriaki
« Reply #19 on: Tue, 09 February 2021, 02:38:24 »
A TKL Sat75
Fair enough, but the point was actually to remove the same keys that were replaced with the encoder and OLED.
Thank you for your feedback.
Offline Toriaki
« Reply #20 on: Tue, 09 February 2021, 02:39:22 »
kinda sus
Brass bottom has been ejected.
Offline Toriaki
« Reply #21 on: Tue, 09 February 2021, 02:40:50 »
Thank you very much, kind sir.
Has you probably have already read, we might have had a couple of premature points featured, but we'll keep in touch.
Offline Toriaki
« Reply #22 on: Tue, 09 February 2021, 02:41:33 »
We hope to speak to you soon, gentleman!
Offline Toriaki
« Reply #23 on: Tue, 09 February 2021, 02:42:35 »
Ne screws avail?
Yep, we should have worked a little better on the details, mostly a detail that holds the whole board 😂
We'll get in touch and keep this thread updated.
Thank you for your interest.
Offline Toriaki
« Reply #24 on: Tue, 09 February 2021, 02:44:03 »
Yes, after the feedback we've been getting, we sure will change things and improve the existing concept.
The knob and oled were added exactly for that reason, as far as I know, there aren't a lot of people using those top keys.
Thank you for your coment!
Offline Toriaki
« Reply #25 on: Tue, 09 February 2021, 02:46:48 »
We were working with some quotes we got but it was a bit premature to advance with those prices, since we were not considering some factors. (That's why the price tags were removed).
Still, we'll do our best not to go up a lot regarding that matter.
Thank you for your feedback!
Offline Toriaki
« Reply #26 on: Tue, 09 February 2021, 02:53:37 »
GLWIC
Kind sir, thank you a lot for your comment. To me, this is the most constructive feedback we're gotten so far.
You are right in so many levels.
We'll get back to you on the plate matter, if you don't mind giving a little hand.
Yes, the screws are missing, even though we're doing our best to keep as many hidden as we possibly can (we probably can't go as far as getting no screws visible, but we sure we'll try).
And you're right, the usb port is on the top left, and also hidden in renders.
Regarding the biggest issue you addressed, the pricing, we were working with some quotes we were given, including packaging, all the metal parts, CNCing, etc, etc, but it has come to our attention that we forgot a couple variables on the equation and therefore, thank you for imploring us to delete the price 😂
We will take the board for a "couple of rides" before updating you guys on it and hopefully we'll have some protos soon.
Thank you very much for your comment, it was an eye opener in so many ways and you gives us the will to continue improving until we find a sweetspot for the most part.
Offline Toriaki
« Reply #27 on: Tue, 09 February 2021, 02:55:36 »
Thank you for your comment!
Is that because it resembles the Satisfaction board?
That was not the point, our only goal was to remove the top keys with something we considered more functional.
Offline Toriaki
« Reply #28 on: Tue, 09 February 2021, 02:57:21 »
We'll get back to you, hopefully with something you guys don't address directly to satisfaction, because that wasn't the point at all.
Offline Toriaki
« Reply #29 on: Tue, 09 February 2021, 02:58:13 »
We're looking forward to make improvements and get back to you guys!
Offline PotatoTM
« Reply #30 on: Tue, 09 February 2021, 02:58:53 »
Looking forward to seeing the protos! Like the layout, rarely use the 3 keys the knob/panel replace.
Offline Toriaki
« Reply #31 on: Tue, 09 February 2021, 03:10:48 »
Thank you!
It was for that exact reason we added the knob and the oled, to get a bit more fuctionality on the board.
Offline lolpes
« Reply #32 on: Tue, 09 February 2021, 03:48:38 »
I've been following the development of this project closely and before the IC was posted.
It does look promising and hopefully, by producing the prototype, the maker can learn and iron out a lot of the concerns showcased here. If anything it will be a great learning experience.
Offline Toriaki
« Reply #33 on: Tue, 09 February 2021, 05:19:36 »
Thank you for your kind words! <3
Exactly our thoughts!
Offline VipermanGT2
« Reply #34 on: Tue, 09 February 2021, 05:43:54 »
Technically not a TKL, soooo...kinda sus.
Offline Toriaki
« Reply #35 on: Tue, 09 February 2021, 05:59:03 »
Are we really going that way? 😂
Offline Oggi
« Reply #36 on: Tue, 09 February 2021, 06:14:49 »
Offline Toriaki
« Reply #37 on: Tue, 09 February 2021, 06:41:02 »
kinda sus
What?
Well, I guess it was a bad reference if you didn't get it 😐
« Last Edit: Tue, 09 February 2021, 06:43:38 by Toriaki »
Offline Rocket
« Reply #38 on: Tue, 09 February 2021, 10:38:52 »
How much would you anticipate this to weigh?
Offline OLED knob
« Reply #39 on: Tue, 09 February 2021, 10:41:06 »
Oled and knob im in.
Offline Toriaki
« Reply #40 on: Tue, 09 February 2021, 11:35:12 »
According to the CAD software, about 3kg (or around 6.6lbs), which is not light at all, but we thing it'll pay off.
Offline Toriaki
« Reply #41 on: Tue, 09 February 2021, 11:35:25 »
Offline ex-machina
« Reply #42 on: Wed, 10 February 2021, 04:04:34 »
observing this topic :D
Offline Toriaki
« Reply #43 on: Wed, 10 February 2021, 04:14:11 »
Offline Prelim
« Reply #44 on: Wed, 10 February 2021, 04:28:25 »
looking great, eager to see the next developments  :thumb:
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline Toriaki
« Reply #45 on: Wed, 10 February 2021, 04:29:17 »
Thank you very much, Mr. Prelim. <3
Offline Dunne
    • Dunne
« Reply #46 on: Wed, 10 February 2021, 05:11:10 »
newspaper
Offline Toriaki
« Reply #47 on: Wed, 10 February 2021, 05:53:20 »
newspaper
Not a spoon then. I like it.
« Last Edit: Wed, 10 February 2021, 06:06:12 by Toriaki »
Offline rokon07
  • Reddit: u/rokon-07 | Discord: rokon07#2203
« Reply #48 on: Wed, 10 February 2021, 13:02:50 »
Great placement on the Oled and knob. Looking forward to more updates.
Keycult 1/60 Rev.1 | KL90 | Keycult 2/65 Red| Keycult No2 Contemporary Red | Sat75 | Rama M60a
Offline Toriaki
« Reply #49 on: Wed, 10 February 2021, 13:04:16 »
Thank you! Looking forward to giving you guys updates soon!
