Author Topic: I can't register to geekhack because I don't know the answer of 2 of the securit  (Read 178919 times)
Offline esterhazy
I am fairly new to the custom mechanical keyboard community and want to register to geekhack to look for groupbuys that aren't already over. But the one problem is that I have to answer 3 security questions, and don't know the answer of 2 em. Can someone help me with them?
The first one I don't know:
A popular keyswitch type, which has been increasingly cloned in recent years:
I thought it was cherry mx but it said it was wrong
The second one:
A popular keyboard format (abbrev, 3 letters) which omits the numberpad normally present on a fullsize keyboard:
I literally have no clue what the answer is
I am probably just stupid but eh.
« Last Edit: Sat, 13 February 2021, 14:25:10 by esterhazy »
Offline of_sam
Re: [IC] GMK Voodoo
« Reply #1 on: Sat, 13 February 2021, 12:19:16 »
When I think of voodoo, it's not a witch on a broom.
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline Afresh
Re: [IC] GMK Voodoo
« Reply #2 on: Sat, 13 February 2021, 12:20:37 »
same, I think whole project could use better name
Offline geohammy
Re: [IC] GMK Voodoo
« Reply #3 on: Sat, 13 February 2021, 12:30:24 »
Really cool set, but idk about the name Voodoo
Unagi, Bias, Dolphin, XTAL
Join the YVKB Discord:
https://discord.gg/pCjDYqup6r
Offline esterhazy
Re: [IC] GMK Voodoo
« Reply #4 on: Sat, 13 February 2021, 12:37:09 »
Thank you for your feedback, i will meditate on that
Offline esterhazy
Re: [IC] GMK Voodoo
« Reply #5 on: Sat, 13 February 2021, 12:38:28 »
thank you for your feedback, Afresh!
Offline StanleyLelnats
Re: [IC] GMK Voodoo
« Reply #6 on: Sat, 13 February 2021, 12:40:31 »
The name and timing of this IC being near mardi gras made me think it was going to be New Orleans themed
Offline psxndc
[IC] GMK Voodoo
« Reply #7 on: Sat, 13 February 2021, 12:41:02 »
First, really appreciate that the 40s/ortho kit has an R3 1u for something other than tab and ESC. Raise key is typically the same color as lower though unless you’re going for a gradient.
Second, agree about the name given this is witch themed. Maybe GMK Cauldron? GMK EON (eye of newt)?
Tbh, the colors aren’t for me, but I think the IC has some real promise. GL!
« Last Edit: Sat, 13 February 2021, 12:43:04 by psxndc »
Ortho. Always.
Offline esterhazy
Re: [IC] GMK Voodoo
« Reply #8 on: Sat, 13 February 2021, 12:44:06 »
your opinion will really help me out, thank you very much
Offline jobicoppola
Re: [IC] GMK Voodoo
« Reply #9 on: Sat, 13 February 2021, 12:45:32 »
Really like the colors but agree the name and the witch imagery make no sense together.  Still an interesting set though.
Offline esterhazy
Re: [IC] GMK Voodoo
« Reply #10 on: Sat, 13 February 2021, 12:48:26 »
I will think these days of a new name, i see all are complaining about the name, maybe you are all right, thank you for your feedback :thumb:
Offline nu_types
  • Formerly Iredeus
Re: [IC] GMK Voodoo
« Reply #11 on: Sat, 13 February 2021, 12:55:13 »
GMK Cauldron
Offline esterhazy
Re: [IC] GMK Voodoo
« Reply #12 on: Sat, 13 February 2021, 12:56:28 »
Hello all of you, i see that you guys are saying that i should probably change my new and i kinda think you are right, i really apreciate your feedbacks and advices, i will take some time these days to think about a new name for my set and to rework some of my renders, i apologize for the inconvenience ;)
Offline esterhazy
Re: [IC] GMK Voodoo
« Reply #13 on: Sat, 13 February 2021, 13:01:12 »
I posted a Name Suggestions Form, you can suggest me new names for the set, thank you! :thumb:
Offline MIGHTY CHICKEN
Re: [IC] GMK Voodoo
« Reply #14 on: Sat, 13 February 2021, 13:01:40 »
Good colors just needs a name change
edit: where tf post go
« Last Edit: Sat, 13 February 2021, 19:25:03 by MIGHTY CHICKEN »
Offline esterhazy
Re: [IC] GMK Voodoo
« Reply #15 on: Sat, 13 February 2021, 13:11:00 »
Thank you for your feedback!
Offline esterhazy
Re: [IC] GMK Voodoo
« Reply #16 on: Sat, 13 February 2021, 13:19:47 »
Offline LittleAad
  • Hello
Re: [IC] GMK Voodoo
« Reply #17 on: Sat, 13 February 2021, 13:38:24 »
Your color matching is interesting. The pictures of the colors that you matched to are completely different than the renders. There is a possibility that this is due to my monitor but it shouldn't show up different on the same screen... I suggest you change this to prevent confusion. You also have a random 1.5u r4 super key in your base kit and you do not have mod tilde or pipe. Not sure why you have a 1u backspace either. You have a green spacebar in the spacebars kit when it should be the dark blueish color. Also, you have two 1u spacebars but no 3-1-3 spacebar support.
Offline esterhazy
Re: [IC] GMK Voodoo
« Reply #18 on: Sat, 13 February 2021, 13:42:15 »
Thank you very much Aad for you feedback, i will consider this in the next update :thumb:
Offline esterhazy
Re: [IC] GMK Voodoo
« Reply #19 on: Sat, 13 February 2021, 13:55:42 »
Offline pixelpusher
Re: [IC] GMK Witch
« Reply #20 on: Sat, 13 February 2021, 13:56:01 »
I like the yellow you use in your banner.  Seems to accent the caps better than green.  But when I think of a witch on a broom, green does make sense.  Not sure about the renders.  That doesn't look like GMK DY does in real life, it looks like a dark lavendar to me.  And the RAL Dark color looks way lighter in the renders too.  Maybe think about yellow on dark mods and option for yellow or green accents?  Dunno.  Just feels low contrast to me at the moment.
Offline esterhazy
Re: [IC] GMK Witch
« Reply #21 on: Sat, 13 February 2021, 13:57:23 »
Thank you for your advice my guy :thumb: ;)
Offline sGhost
Re: [IC] GMK Witch
« Reply #22 on: Sat, 13 February 2021, 14:13:06 »
I'd change paths my guy.
https://imgur.com/a/s43fNNK
Offline gilbert
this just sad... at least stand up to your mistakes
Offline marcofriedrichs
  • Discord: Marco#8888
    • marcofriedrichs.com
You're embarrassing yourself, mate
Offline LittleAad
  • Hello
Buddy, admit what you did wrong... you’re making a fool of yourself
Offline Ella
  • Why is it called an oven
what kinda 4d chess you playing here?
Offline jobicoppola
oof well someone needs to make a set with similar colors and add some yellow, it seems to be a common palette used by witches :)
Offline pixelpusher
I feel like someone has stolen my personal information... :eek:
Offline jobicoppola
lol what just happened here?
Offline Skok
Offline Auxo
  • Formerly CJD_Anthony
Re: [IC] GMK Witch
« Reply #31 on: Sat, 13 February 2021, 15:14:42 »
Offline dgneo
  • Supervillain
thought i was having a stroke reading the end of the thread and then the post title
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
The second one:
I'mma be real dawg, if you don't know this one, dont post in this category.
Offline Lil
    • designedbydark
The second one:
262193-0
262195-1
262197-2
262199-3
262201-4
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
include me in the screenshot
Offline BapoDonu
Poor guy not being able to register :(((
Offline Achromous
  • noesc.co.uk
    • NOESC
This isn't your finest moment, I'm going to give you the answer of one of the questions though because I'm helpful.
It's the ISO code of Tokelau.
Offline Havattack
what.
I am probably just stupid but eh.  Hey, at least you recognize it. It's amazing how many people think they are smart.
 The 1st question: You have the correct answer, but you're being too specific, use only one of the words.
The second question: Do you not know about google? Just search for " popular keyboard layouts" and pick the one that is only 3 letters.
« Last Edit: Sat, 13 February 2021, 16:10:31 by Havattack »
Offline geohammy
wtf happened here
Offline Barri
  • Praise the Lord of Bones
wtf happened here
I'm so confused
Anyways, the original geekhack devs should be ashamed of themselves for implementing such poor UI/UX, those 'security questions' are a joke to modern web development. They aren't preventing automation in any way, but are creating an unnecessary inconvenience to regular users.
the answers are 'usb',  'mx',  and 'tkl'.
I'm more-so confused as to why other threads comments are showing up here and How he made this post without knowing the answers or registering an account...
« Last Edit: Sat, 13 February 2021, 16:35:52 by Barri »
Offline glarses
i agree
Offline TheInverseKey
  • You can run but you cannot hide!
I see that you are missing an essential part you your post the "Y".
Offline Pontus
Who’s going to help him register?  :-X
Offline Nuclear Nachos
  • Anima and Animus
wtf happened here
I'm so confused
he made a questionable ic and then changed the title/message to something else to hide it pretty sure
Offline HoodrowThrillson
Why this dude dirty delete.
Gonna get clowned on in the next IC, see you there!
[Mostly] Retired from Keyboards
Typing on: TKL One - Zealios v1 - 55g TX Springs, TX Films, Lubed with 205g0 - Xiami Beige Cadet + RGB
Collection: IDB60 (gone), Austere (gone), Matrix 1.2og (gone), Matrix 2.0add (gone), RS (so lit), Infinitum (gone), THRILL Proto (destroyed), Matrix 2.0add xmas Starry Night (gone), RS60 (traded), MC65 (traded), Jane v1 CE (gone), GSKT-00 (gone), TKL One Poly (returned), TKL One, RS60, Serenity Proto, Boulevard Proto
Offline Tyson
The second one:
I’m so confused, this entire IC was here and you randomly deleted it claiming you can’t register? But clearly your register because you posted on GeekHack with your account?!?
Offline herfalerf
whew, what a ride!
Offline antx1701
After reading the thread, then re-reading, I am still very confused.
Offline heyimpanda
this is the **** i browse geekhack for
