Author Topic: [IC] Ink Blossom Deskmats - GB LIVE  (Read 25927 times)
Offline fromscratchusa
  • Keyboard Bag Tailor, I work with Keycap Designers.
    • FromScratch - Mechanical Keyboard Bags
Re: [IC] Ink Blossom Deskmats
« Reply #50 on: Fri, 26 March 2021, 10:24:27 »
Now this is cute
Also, I like the transparency.
Offline Sarazan97
« Reply #51 on: Fri, 26 March 2021, 10:46:10 »
Did you get the design of the geometric lines from another deskmat? https://www.instagram.com/p/CJnmzienG9L/?igshid=1vk7vvsp52z28 it looks identical :/
look closer, they’re actually pretty different, and that’s just a common style of border
Actually you're right, I'm sorry i didn't see it before. At first glance they looked the same, but there are some differences
Offline bricks
« Reply #52 on: Tue, 06 April 2021, 14:58:58 »
aaaahhh I'm so glad you decided to go through with it!  How many colorways should we anticipate on seeing when gb opens up?
Offline AshF
Re: [IC] Ink Blossom Deskmats - GB LIVE
« Reply #53 on: Wed, 05 May 2021, 17:18:53 »
Dammmmmitttttt!
Can't believe I missed this!! The level of frustration is unreal
Sent from my ASUS_I003D using Tapatalk
