Author Topic: Question regarding DZ60 vs DZ60 ANSI?  (Read 1997 times)
Offline yam
« on: Thu, 25 February 2021, 03:30:01 »
KBDfans sells two DZ60rgb PCBs but I have no idea what the difference is. I would like to have a 2.25u left shift, 6.25u space bar, 1u question mark, and either a 2.75u or 1.75u right shift key.
Am I supposed to buy the “DZ60rgb” or “DZ60rgb ANSI”? And which plate am I supposed to buy with it? The way KBDFans has it laid out makes me so much more confused.
Appreciate the help
Offline yui
Re: Question regarding DZ60 vs DZ60 ANSI?
« Reply #1 on: Thu, 25 February 2021, 03:58:01 »
what you ask is pretty standard for ANSI layout, so i would expect that both would fit your needs, although the ANSI one only supports 2.75 right shift it seems and the normal one only 1.75with 2 keys on the right, it is pretty much the only difference i see, although you could wait for other to maybe correct or confirm what i am saying, given that i do own neither.
