Author Topic: [GB] IRON165 by Smith + Rune, Round 2  (Read 34215 times)
Offline voxkey
« on: Thu, 25 February 2021, 10:11:55 »
Smith + Rune Website
Join Smith + Rune Discord
Follow us on Instagram
Original IC Post
Timeline, Vendors, and Quantities
Group Buy Start Time
The group buy will go live on February 27th, 2021 at 10 AM EST worldwide! We expect a conservative fulfillment time of January 2022.
Countdown Timer
Vendors, Pricing, and Quantities
We're very proud to announce we've partnered up with CannonKeys in the US, DeskHero in Canada, MyKeyboard in the EU, and ILUMKB in the AP/China market to handle sales once again.
If you are unsure which vendor covers the country you live in, please reach out to the vendors directly to confirm.
CannonKeys - North/Central/South America Vendor (excluding Canada) - About CannonKeys Raffle Queue
500 boards, region locked, CannonKeys hybrid FCFS/raffle checkout. Limit 1 per household.
$424 USD
DeskHero - Canadian Vendor
150 boards, region locked for first ten minutes
$566 CAD
MyKeyboard EU - European Vendor
300 boards, region locked, Koi raffle system
Click here for Koi Raffle System info
The raffle will take place here:
https://www.koi-raffle.com/
To join the raffle you need to join the Koi Raffle System Discord. The following link should be the invite, otherwise google for it: https://discord.gg/yxqVMrw
After joining the discord you need to verify yourself in the registration channel (should be the only channel you can see) to verify just press the thumbs up reaction on the bot-post in that channel like over 9k others have. After doing so you will get the verified role (your name is blue and you can access the verified channel).
Next you head to the website (koi-raffle.com) and log in with your discord account.
If you followed the steps above and are verified on the server it should work and your discord username, hash and email will be displayed at the top of the website.
To change the email you will have to change your discord email and re-log into the website.
Once the raffle starts it will be displayed on the koi-raffle website and allow you to join. The raffle will not be visible to you if you are not verified on the server!
If you win an invoice will be sent to the displayed email.
The raffle will remain open for 12 hours.
€424 w/VAT included
iLumkb - Asia Pacific Vendor
500 boards, region locked, FCFS
$566 SGD
Iron165 Changes for Round 2
  • Deeper gasket pockets, allowing the same poron gaskets, but with less overall compression, making the case easier to assemble
  • 0.25mm top case height increase, to better hide keycaps that aren’t as deep as GMK, while still maintaining the same overall switch height
  • Better, beefier, longer screws
  • Removal of cable channel
  • Revised PCB with VIA compatibility **NOT HOTSWAP**
  • Further optimized consistency aluminum plate
  • All aluminum construction
  • Many other minor tweaks to optimize machining
Iron165 Features
  • 7 Degree Typing Angle
  • Full Gasket Isolation Mount
  • Bottom Accent Plate w/exposed rune logo
  • Low-Profile Front Height (less than 17.25mm)
  • Seamless Case Design
  • QMK/VIA compatible PCB, designed in collaboration with Gondolindrim
  • Unified C3 USB-C daughterboard (centered on case)
  • Optimized plate for consistency on every key press (see analysis below)
Iron165 Colors
Each board comes with a black anodized aluminum base and contrasting aluminum accent plate and aluminum badge. Please refer to the renders for a visual depiction.
  • Midnight Teal
  • Graphite
  • Red
Addons and Extras (All prices in EUR include VAT)
  • Extra PCB w/daughterboard and JST cable - $60 USD / €60 EUR / $80 CAD / $79 SGD
  • Extra Aluminum Plate - $40 USD / €40 EUR / $53 CAD / $53 SGD
  • Forged Carbon Plate - $50 USD / €50 EUR / $67 CAD / $66 SGD
  • Stainless Steel (mirror polished) Weight and Badge Set - $175 USD / €175 EUR / $232 CAD / $235 SGD
  • Copper Weight and Badge Set - $100 USD / €100 EUR / $133 CAD / $135 SGD
  • Brass Weight and Badge Set - $90 USD / €90 EUR / $119 CAD / $120 SGD
Additional Information
- Badges and weights will only be sold as addon sets to simply order fulfillment across all vendors due to the increased quantities offered. We're planning to order many extra badges for the online store though for those original Iron165 owners who'd like a new and different badge.
- We are adding a small pocket to make it compatible with other JST 65% PCBs on the market. This should help ensure that even if we run out of stock on PCBs that a suitable replacement can be found in a pinch.
Supported Layouts
There will be three plate layout options, semi-fixed. All plates support split backspace and stepped caps. ISO plates may not be available from all vendors.
  • Tsangan (7u bottom row)
  • ANSI (6.25u bottom row)
  • ISO
What's In The Box
  • Iron165 Keyboard
  • Aluminum Plate
  • PCB, USB-C Daughterboard, and JST cable
  • Gaskets and all mounting hardware
  • Iron165 custom carrying case
Optimized Plate, the Process, and FEA analysis
Keyboard plate FEA analysis was needed to measure deflection and try to achieve a uniform plate deflection distribution across the keyboard. You can read more about our process and testing methodology in the original Iron165 IC.
https://geekhack.org/index.php?topic=101470.0
Renders
Addon Weight and Badge Set Prototypes
For more renders, prototype pictures, and discussion, please check out the IC thread or join our Discord.
Original IC Post
Special Thanks
  • LBaron, the other half of Smith + Rune!
  • Mods, admins, and of course, the Inner Circle, best team ever!
  • The entire Smith + Rune community, a bright light in a sometimes very dark world
  • Everyone who has supported us this far. We couldn't have got to this point without you!
« Last Edit: Fri, 26 February 2021, 15:02:00 by voxkey »
Re: [GB] IRON165 by Smith + Rune, Round 2
« Reply #1 on: Fri, 26 February 2021, 10:21:47 »
Approved :thumb:
Offline Auracity
« Reply #2 on: Fri, 26 February 2021, 10:23:57 »
lit
Offline dRnRcRr
« Reply #3 on: Fri, 26 February 2021, 11:08:11 »
Love it. GL everyone
Offline nurakh
« Reply #4 on: Fri, 26 February 2021, 12:38:16 »
I hope I can get one
Offline Capsy
« Reply #5 on: Fri, 26 February 2021, 16:57:47 »
Hypeeeeee
Sent from my Pixel 4a (5G) using Tapatalk
Offline Chippy
  • sus chef
« Reply #6 on: Fri, 26 February 2021, 17:13:43 »
here we go
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline dRnRcRr
« Reply #7 on: Fri, 26 February 2021, 23:34:12 »
Teal Gang
Offline slayermusiq
« Reply #8 on: Fri, 26 February 2021, 23:34:23 »
Let's go! Much love for the S+R Community <3
Offline trumanomar
« Reply #9 on: Sat, 27 February 2021, 05:21:11 »
Let's go, GL EVERYONE
Offline nathanchere
« Reply #10 on: Sat, 27 February 2021, 08:59:35 »
Good luck!
Offline nathanchere
« Reply #11 on: Sat, 27 February 2021, 09:03:00 »
****. ILimkb sold out in under 2 minutes
Offline bball2
« Reply #12 on: Sat, 27 February 2021, 09:23:05 »
I think deskhero was under a minute?
Super happy that a Canadian vendor is getting boards for group buys like this! Jerrold and the team over at desk hero really do a great job. They spent a bunch of time testing different systems yesterday to make sure things run smooth, got feedback from users, and are active/friendly on discord through the whole process.  :thumb:
« Last Edit: Sat, 27 February 2021, 10:55:15 by bball2 »
Offline haystack
« Reply #13 on: Sat, 27 February 2021, 09:25:28 »
Did my part to free up a spot by bailing on Cannon Keys at the part where the cart price for the basic keyboard was US$585. Obviously I missed a memo.
Offline tonetizzley
« Reply #14 on: Sat, 27 February 2021, 09:45:02 »
Got lucky and landed one though CK! So hyped for midnight teal. I'm usually pretty conservative with my color choices so this is uncharted territory
Offline Kings
« Reply #15 on: Sat, 27 February 2021, 10:05:49 »
I was curious about this as well. Price on GB post was different than what was on CannonKeys. Must have been a last minute change?
Offline DukeEsquire
« Reply #16 on: Sat, 27 February 2021, 10:08:18 »
It was a price error. They are refunding people the extra amount.
Offline DukeEsquire
« Reply #17 on: Sat, 27 February 2021, 10:09:08 »
Oof. It was a price error and they are fixing it for everyone.
I saw the same thing, but went with it anyways.
Offline YESWEKEN
« Reply #18 on: Sat, 27 February 2021, 10:32:49 »
Will badges be available anywhere for purchase without having to buy the weight along with it?
I didn't get in on a R2 board so the extra weight+badge set that's currently available on Cannon Keys is kinda pointless for me...
Offline bball2
« Reply #19 on: Sat, 27 February 2021, 10:38:52 »
Looks like it, from the interest check:
"We are only selling weight & badges as a bundle right now during the GB.  We will be ordering a lot of extra badges only to stock in our S+R store incase any R1 or R2 owners are looking for just a badge."
https://geekhack.org/index.php?topic=110985.msg3018367#msg3018367
Offline YESWEKEN
« Reply #20 on: Sat, 27 February 2021, 10:40:07 »
awesome,. thanks
Offline Kings
« Reply #21 on: Sat, 27 February 2021, 11:26:05 »
That's great to hear. Where did you find this out?
Offline HelloThisIsDog
« Reply #22 on: Sat, 27 February 2021, 11:50:26 »
It’s posted everywhere in the smith and rune discord
Offline lbaron
« Reply #23 on: Sat, 27 February 2021, 12:21:28 »
Thank you everyone who participated today. The only hiccup I know of was the pricing error on the back end of CK pulling from iron180. That was fixed midway through the GB and refunds have begun to be issued to those affected by it.
Offline Rockets.
« Reply #24 on: Sat, 27 February 2021, 13:00:28 »
SO pumped I got my hands on a teal, thank you Desk hero <3
Offline lakeboredom
« Reply #25 on: Sat, 27 February 2021, 15:39:14 »
Offline RobbyRobsen
« Reply #26 on: Sat, 27 February 2021, 23:03:44 »
Just out of curiosity - can you list the number of EU raffle participants to see the odds against one has lost/won?
Also: are we notified if we didn't win the raffle?
Offline MediocreTurtle
« Reply #27 on: Sun, 28 February 2021, 06:55:42 »
No emails if you don't win
Offline Llamakob
« Reply #28 on: Sun, 28 February 2021, 15:37:00 »
IIRC necroman said 1/3 in the MKB discord
« Reply #29 on: Sun, 28 February 2021, 15:42:58 »
Cool, won the raffle. Now to hope that paying goes smooth tomorrow and then waiting begins
Offline AshF
« Reply #30 on: Mon, 01 March 2021, 02:21:42 »
Couldn't be happier paying for an invoice
Sent from my ASUS_I003D using Tapatalk
Offline El_Jackador
« Reply #31 on: Mon, 01 March 2021, 04:25:41 »
I had a spot and because I didn't check my emails between 8pm last night and 9am this morning, I lost my spot.
You literally have to be in the mykeybaords discord to know whats going on as the information from Smith and Rune isn't enough
This is really sad
Offline DEG_2196
« Reply #32 on: Mon, 01 March 2021, 06:52:55 »
This is really sad
Damn, that's a tough one. I was lucky enough to secure one from MKB but I made sure i was in ALL the relevant discords before GB start. Smith + Rune aren't responsible for vendor communications.
Offline El_Jackador
« Reply #33 on: Mon, 01 March 2021, 07:23:43 »
This is really sad
Yeah, you're right! I honestly didn't even know mykeyboards had a discord so I thought I was fully prepared but sadly it just wasn't meant to be!
Offline darthcapn
« Reply #34 on: Tue, 02 March 2021, 10:30:38 »
What is the color code for the midnight teal
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline AshF
« Reply #35 on: Tue, 02 March 2021, 12:15:37 »
SK:1296SeriouslyBeautiful
Thank me later
Offline cigs_coffee
« Reply #36 on: Tue, 02 March 2021, 12:26:08 »
This is really sad
Tough one. Allowing a grace period of 24h should be affordable? Grace period for payment of the invoice was 6hours? Guess i was just lucky checking mails at the right time.
ps. mail modified to make my point clearer
« Last Edit: Tue, 02 March 2021, 12:38:11 by cigs_coffee »
Offline darthcapn
« Reply #37 on: Tue, 02 March 2021, 12:26:47 »
Thank me later
I was not able to find anything for sk1296 :o was that a reply to my color question?
Offline El_Jackador
« Reply #38 on: Tue, 02 March 2021, 12:31:55 »
This is really sad
Tough one. A grace period of 24h should be affordable? Grace period for payment of the invoice was 6hours? Guess i was just lucky checking mails at the right time.
It wasn't a grace period of 24 hours, you had between 8pm and 9am the next day if you knew thats when the emails were sent out and I wasn't on the mykeyboards discord
Offline nathanchere
« Reply #39 on: Tue, 02 March 2021, 14:50:32 »
Yeah it's quite ****ty. There's no good reason why they can't give at least 48 hours to pay, especially given that there's no forewarning if you actually 'won' in the raffle and ****-house communication in general from them. I would say to email them in this instance and hope for the best but given my previous experience with MyKeyboards customer service I wouldn't expect much.
Offline gex
« Reply #40 on: Wed, 03 March 2021, 19:16:35 »
payment deadline was not 9am but 8pm so most of the people had more than 20 hours to pay. as it was announced on their discord:
All invoices are OUT.   Everyone has till 02/03/2021 20:00 CET to pay their invoices. Not paid by then and your invoice will get cancelled.
well, last comment was about the payment but the original was about the config form.
« Last Edit: Wed, 03 March 2021, 19:27:06 by gex »
Offline LASERman Projects
  • Soldering is my native language.
« Reply #41 on: Wed, 10 March 2021, 06:05:27 »
The rules on the raffle were clear announcing ahead there will be only hours to pay the invoice.
There was clear email saying you have won the spot.
There was standard PayPal invoice email.
In my case it was nearly 18 hrs to pay.
It is pretty clear those sought after boards are acquired by paying special attention.
Offline GingGing
« Reply #42 on: Thu, 11 March 2021, 11:07:48 »
Finally R2!
Offline Biskwit157
« Reply #43 on: Wed, 13 October 2021, 12:25:09 »
How's it going?
Offline TjarleN
« Reply #44 on: Thu, 14 October 2021, 00:27:35 »
How's it going?
Update from the smith and rune discord (2 weeks ago):
Iron165 r2
Kinda sorta big news here. Tops and bottoms are done machining! Weights, plates, etc still have a ways to go, but we’re on track!
Collection: HHKB Pro 2 type-s, HHKB Pro 2, Evija, IBM SSK, F77, G80-5000, Corne V3, Nasu, W1-AT
Ordered: Safa, Crin, Glare
Offline honoka
« Reply #45 on: Sat, 16 October 2021, 17:23:35 »
You are required to update here aswell.
Ban them
Offline lbaron
« Reply #46 on: Thu, 21 October 2021, 14:18:40 »
Aluminum parts are now in anodizing.
Offline lbaron
« Reply #47 on: Sat, 18 December 2021, 10:48:14 »
Keeping fingers crossed that boards will ship out of China before CNY. Even if they ship after we should still be on track to meet Q1 2022 delivery.
Offline lbaron
« Reply #48 on: Fri, 25 February 2022, 09:15:46 »
Two batches of boards shipped before CNY, two slated to ship this week (manufacturer is awaiting confirmations from vendors) and two next week (S+R is part of the last shipment). However, due to some local cases of Covid near the manufacturer (not their employees) they are being forced to shut down for 1-2 weeks which will delay the final two shipments.
Offline honoka
« Reply #49 on: Sat, 26 February 2022, 03:02:48 »
Nice. Thanks for the update
