Author Topic: [GB] LZ : Phase (All shiped)  (Read 34472 times)
Offline pandaman97
Re: [GB] LZ : Phase
« Reply #50 on: Mon, 01 March 2021, 03:43:07 »
$544 for a keyboard has less than 12 points or less than 3mm on the surface exposed are considered as normal condition.. hm.. and this not even a large GB. What a massive pain at QCing!
Offline ai06L
  • SEE YOU, SPACE COWBOY
Re: [GB] LZ : Phase
« Reply #51 on: Mon, 01 March 2021, 05:44:35 »
How do you send the email to the google sheet? I can't seem to find either the email, or a button that is to send an email for a change.
Thank you
(edit) just found it
hey man is lifezone2@gmail.com? thanks
Collection: Keycult No.1, 8XV2.0 Additional Ano silver WKL, FC660C Novatouched, Polaris, 8XV2.0 Additional coated black CWKL, Vega E-white, Vega Grey, Novatouch, Jelly Epoch SE
Waiting to ship: Cruelworld 60, 8XV3.0 light grey WKL
Offline AfroMax
Re: [GB] LZ : Phase
« Reply #52 on: Mon, 01 March 2021, 07:35:41 »
will it have the same problem of switches touching the weight and actuating a few keys at the same time and the other problems or were they fixed for phase ?
Offline DukeEsquire
Re: [GB] LZ : Phase
« Reply #53 on: Mon, 01 March 2021, 10:51:26 »
I thought the Physix was a bit underwhelming as a board, especially given the price. I had a lot of the same complaints as JYMV, especially with the cheap design of the internal weight. I ended up just keeping the plastic wrap on it, but that felt like such a compromise for a board that I paid nearly $700 shipped.
I also didn't find the mounting system particularly good or bad. Someone could have told me it was top mounted and I would have believed them.
Basically, the board is "fine", but for $700, I expected more than "fine".
Offline LifeZ
  • LifeZone
Re: [GB] LZ : Phase
« Reply #54 on: Tue, 02 March 2021, 06:00:04 »
LZ Limited
Offline LifeZ
  • LifeZone
Re: [GB] LZ : Phase
« Reply #55 on: Tue, 02 March 2021, 06:43:19 »
I reviewed the issues raised.
There are two phenomena where multiple keys are entered together.
It is caused by a short of the main MCU and a short of the switch leg.
If there is no problem with the main MCU, it is very likely a switch problem.
There are many types of switches.
Which switch did you put together?
LZ Limited
Offline slayer12
Re: [GB] LZ : Phase
« Reply #56 on: Tue, 02 March 2021, 08:58:34 »
I removed the internal weight right after assembling. It is the worst design in the Physics and I don't think that LZ should keep it in Phase.
The flat surface of the internal weight provide a lot of resonance which make Physics sound much worse compared to other LZ boards.
Anyway, after replacing the weight with a sound dampened foam, I am quite happy with the result.
Offline King4477
Re: [GB] LZ : Phase
« Reply #57 on: Tue, 02 March 2021, 10:02:12 »
I did the same actually. Physix is my favorite keeb for daily use and I've never missed the internal weight. Sounds great with 2mm foam.
Maybe the weight for the Phase should be thinner, even if just at the center row where switches are more likely to touch the weight given flex in the plate.
Offline LifeZ
  • LifeZone
Re: [GB] LZ : Phase
« Reply #58 on: Wed, 03 March 2021, 01:16:43 »
Order Confirm & Edit Deadline : ~8. March 2021
Order list release
https://docs.google.com/spreadsheets/d/1zjUgfsua4eKMouqy-5RniPharoJakIM6hpkelPDUrI8/edit?usp=sharing
If there is no pc kit left, it can be modified to alu kit.(or cancel)
If you want to modify your order, please send an e-mail to the form below. (not a GH pm.)
mail title: Phase, user name (order no.)
old order:
case color: Deep Navy(PC kit)
switch plate: Alu(black)
.. and add order
new order:
case color: Metalic Silver(Alu kit)
switch plate: Alu(Red)
add: pcb x1
add: switch plate (CF)
and
I made a small playground.
Discord : https://discord.gg/B8HbTa9ztj
(edit)
« Last Edit: Sun, 07 March 2021, 22:12:49 by LifeZ »
LZ Limited
Offline FinalEleven
Re: [GB] LZ : Phase
« Reply #59 on: Sun, 07 March 2021, 21:57:22 »
Discord link expired.
Is there a new invite link?
Offline LifeZ
  • LifeZone
Re: [GB] LZ : Phase
« Reply #60 on: Sun, 07 March 2021, 22:14:28 »
Discord : https://discord.gg/uyemgmVej4
(edit)
« Last Edit: Mon, 08 March 2021, 02:17:51 by LifeZ »
LZ Limited
Offline hoanglh94
Re: [GB] LZ : Phase
« Reply #61 on: Mon, 08 March 2021, 02:14:28 »
Offline Eoen
Re: [GB] LZ : Phase
« Reply #62 on: Sat, 10 July 2021, 17:56:20 »
Hey LZ,
Any updates on the run? Feels like we should be approaching delivery soon.
Offline verity
Re: [GB] LZ : Phase
« Reply #63 on: Sat, 10 July 2021, 18:42:19 »
Hey LZ,
Latest update + some pictures from the discord.
Offline Eoen
Re: [GB] LZ : Phase
« Reply #64 on: Sun, 11 July 2021, 01:42:52 »
Hey LZ,
Cheers
Offline LifeZ
  • LifeZone
Re: [GB] LZ : Phase (70% shiped)
« Reply #65 on: Thu, 26 August 2021, 08:18:42 »
#. Change the defult inner plate (STS to ALU)
  --> Included in all alu kit orders (except pc kits).
and
Add a replacement test sample plate (Brass,Finshed Electroless Nickel Plating)
This is for a typing test, and the finish is not good.
Brass typing feels good (extremely personal).
Total inner plate 2 type (Alu, Brass)
Shipping update.
We have updated the first shipping in the order list.
1st shiped : 8/24 (Tuesday)
And Vietnam is on lockdown, so all deliveries are suspended for the time being. After the suspension is lifted, we start shipping.
Expected after September 6
Extra kits will be sold after all shipments are complete. A and B
LZ Limited
Offline haxyer
« Reply #66 on: Fri, 27 August 2021, 22:29:09 »
my led indicators on the right for caps lock and scroll lock dosen't seem to light up, do I need to do something to set it up ?
Offline 2QT2BSTR8
« Reply #67 on: Fri, 27 August 2021, 23:15:03 »
Did you try soldering the leds with the legs the other way around?
I did this with my PhysiX and it did the charm.
Offline Mr_BeastQuake
    • Reddit
« Reply #68 on: Sat, 28 August 2021, 00:56:28 »
This is why I always just solder in sip sockets. That and swapping out colors.
FYI for led:
(+) = long leg
(-) = short leg
Offline _rubik
« Reply #69 on: Sat, 28 August 2021, 12:40:38 »
huh. Not sure why but I've never considered sip sockets for LEDs. That's a big brain move
Offline hoanglh94
« Reply #70 on: Mon, 06 September 2021, 07:02:39 »
can anyone provide me an invite link to the discord?
Also where can I find the shipping list?
Offline xeoomd
« Reply #71 on: Mon, 06 September 2021, 10:10:13 »
Update shipping status here https://docs.google.com/spreadsheets/d/1zjUgfsua4eKMouqy-5RniPharoJakIM6hpkelPDUrI8/edit#gid=0
Offline haxyer
« Reply #72 on: Mon, 06 September 2021, 19:57:04 »
yes, you are right. there are circle and square pads for different legs on the pcb. thanks! learnt to test the led with the pads before soldering, there is also led cutouts on the top shell so i used 2 3mm led and it fits perfectly
Offline LifeZ
  • LifeZone
Re: [GB] LZ : Phase (All shiped)
« Reply #73 on: Wed, 29 September 2021, 01:44:02 »
All last shipments have departed.
There was a little delay. Thank you for waiting. :cool:
LZ Limited
Offline ShandonCodes
« Reply #74 on: Thu, 30 September 2021, 12:51:19 »
Can't wait to see on of these in person!
