Author Topic: [IC]GMK Pepperoni - GB closed :(  (Read 55621 times)
Offline cojojo11
Re: [IC]GMK Pepperoni - GB September 2021 + More updates soon
« Reply #50 on: Tue, 03 August 2021, 01:58:11 »
What are the prices for the kits?
Offline hoychaa
  • DG Keycap Trust - GMK Pepperoni
« Reply #51 on: Sun, 08 August 2021, 03:23:08 »
Working on it right now! Thank you for your interest!
Offline Mrtunafishie
Re: [IC]GMK Pepperoni - NEW RENDERS W/DESKMATS! 03/05
« Reply #52 on: Fri, 20 August 2021, 20:12:15 »
I definitely will be looking forward to this! The date is coming up soon!  :) :) :)
Hey guys, I've updated the novelties designs.
Per feedback I've received from many of you, here are the changes
1. Decided not to follow Pepperoni arrow keys, but instead pizza slices pointing to each respective directions
2. Added 1.50u sized keycaps for WKL users out there (myself included)
3. Deleted Backspace novelties
4. Updated "Enter" keys with "Pepperoni" and a pizza slice from the pie.
5. 65% users or Macro users will have access to 1.00u sized Pepperoni slices covering from R1 to R4
6. Added new 1.00u key designs (Brick Pizza Oven and a Pizza Peeler) in R2
6-1. If you guys want to, I could also have the new 1.00u keys to be in R1
How do you feel about the updates?
Your feedback will be great for my IC! Thanks :)
Offline hoychaa
« Reply #53 on: Sat, 21 August 2021, 04:49:33 »
YAASSSS Thank you for your support! :cool:
Offline edwyn
  • I create stuff for CONCEPT & IDEA
    • CONCEPT & IDEA
« Reply #54 on: Sat, 21 August 2021, 12:20:38 »
theme isn't for me but really appreciate your mat designs!
Offline LexGrizzly
    • GrizzlyGaming
« Reply #55 on: Sat, 21 August 2021, 12:35:15 »
That red deskmat is SICK.
Offline DuellM
  • Keyboard Fatty
« Reply #56 on: Sat, 21 August 2021, 14:54:41 »
Pizza Slice Rama When?  ^-^
Offline hoychaa
« Reply #57 on: Mon, 23 August 2021, 22:04:41 »
Thank you so much! :D
Offline hoychaa
« Reply #58 on: Mon, 23 August 2021, 22:05:48 »
Just as I saw your post, I emailed them about potential collab for an artisan
Offline hoychaa
« Reply #59 on: Mon, 23 August 2021, 22:06:16 »
I know right?? Just requested samples for the deskmats
Offline DuellM
  • Keyboard Fatty
« Reply #60 on: Mon, 23 August 2021, 22:12:06 »
Awesome
Offline hoychaa
Re: [IC]GMK Pepperoni - GB September 17th 2021 + New Deskmat!!
« Reply #61 on: Thu, 26 August 2021, 03:27:12 »
Hey guys, let me introduce you a new deskmat design! Hope you like it! :thumb:
Pepperoni Universe (NEW)
« Last Edit: Thu, 26 August 2021, 07:00:07 by hoychaa »
Offline konstantin
  • Formerly constexpr
« Reply #62 on: Thu, 26 August 2021, 09:04:06 »
Basekit(Updated)
Hey fam, you should probably change that 00 key to a brown R4 1u Fn key before the GB starts, because otherwise the 65% and 75% users among your buyers are going to be left without an Fn key that they can use in their right column. This is because the nav cluster and right column use brown keys, whereas the only R4 1u Fn key that you have in the set is a red one, so it won't fit in with the rest of the keys in the column. Also, the 00 key in and of itself isn't very useful at all, so this change won't be detrimental.
Edit: Here's an example in another sets that has different colored right column mods:
Ideally, you would have also included a red R1 1u Delete key for 60%s (example circled in yellow), but it's probably too late for that now...
« Last Edit: Thu, 26 August 2021, 09:14:55 by konstantin »
Offline hoychaa
« Reply #63 on: Thu, 26 August 2021, 23:02:28 »
Basekit(Updated)
Thanks for the feedback :) I will update this in the basekit
« Last Edit: Fri, 27 August 2021, 21:47:25 by hoychaa »
Offline Kelly
Re: [IC]GMK Pepperoni - GB September 17th 2021 + Base kit, novelties update!
« Reply #64 on: Sun, 29 August 2021, 02:53:50 »
looks great! :cool: :cool:
Offline hoychaa
« Reply #65 on: Mon, 06 September 2021, 02:52:30 »
Thank you so much! Check out the artisans too  :cool:
Offline hoychaa
Re: [IC]GMK Pepperoni - GB September 17th 2021 + Artisans
« Reply #66 on: Sat, 11 September 2021, 00:52:00 »
Pricing announcement!
Offline hoychaa
« Reply #67 on: Thu, 16 September 2021, 07:04:53 »
DailyClack pricing added!
Offline hoychaa
Re: [IC]GMK Pepperoni - Initial Thoughts
« Reply #68 on: Fri, 24 September 2021, 21:33:29 »
03/01/2021 - Initial Post
03/05/2021 - Added Renders with Deskmats. Following up with feedbacks for Novelties designs.
03/08/2021 - Novelties design update posted in comments
03/09/2021 - 1. Base and Spacebar Kit Updated. Base kit now includes an extra B and a shift key for Alice users. Spacebar kit adjusted accordingly.
                    2. Novelties design update posted in comments
03/28/2021 - Finalized Kit Revisions, along with some render updates
04/03/2021 - Vendors Announced!
04/11/2021 - Vendors Finalized. New Renders with Novelties on Pizza65!!
08/23/2021 - New Artisans Collabs!
08/25/2021 - GB date updated to 17 September 2021
08/26/2021 - New Deskmat!! Pepperoni Universe
08/27/2021 - Asero Fundry alu artisan update!
08/29/2021 - Base kit and novelties updated. Basekit to include brown "Fn" instead of "00" and Novelties to meet GMK standards
09/06/2021 - Artisans updated
09/25/2021 - Sandun Artisan update
