Author Topic: Copam K-430 converter compatibility  (Read 59223 times)
Offline hasu
  • @tmk
Re: Copam K-430 converter compatibility
« Reply #50 on: Sun, 09 May 2021, 21:57:31 »
I believe the converters is not picky and just need a decent USB cable.
The cables will work for the converters if they can be used for the phone or other devices normally.
I guess the cause is not only the cables perhaps, USB  port, power supply, OS ...
The debug log indicates the K-430 doesn't send anything unfortunately.
With replugging the keyboard several times at various speed you can emulate the latemodel24's procedure somehow, perhaps.
I guess specific power cycles timing may casues something, but I can't find reasonable factor there so far.
Also, try this old firmware for XT support only, it may show different info on hid_listen.
https://github.com/tmk/tmk_keyboard/blob/6b71d88150f143b767b6ede7bd9008332d8ae181/converter/xt_usb/binary/xt_usb_unimap.hex
Offline Drag0nFly
« Reply #51 on: Tue, 11 May 2021, 10:05:03 »
Flashed the adapter successfully from the IBM PC firmware to the XT –
Code: [Select]
Pushed button on adapter to put it into firmware update mode
martin@ciraxis ~/tmk_keyboard> sudo dmesg -T|tail
[Tue May 11 14:54:12 2021] elogind-daemon[1341]: Watching system buttons on /dev/input/event17 (t.m.k. IBM PC keyboard converter)
[Tue May 11 14:54:12 2021] elogind-daemon[1341]: Watching system buttons on /dev/input/event7 (t.m.k. IBM PC keyboard converter)
[Tue May 11 14:54:12 2021] elogind-daemon[1341]: Watching system buttons on /dev/input/event16 (t.m.k. IBM PC keyboard converter Consumer Control)
[Tue May 11 15:02:37 2021] usb 3-1.1: USB disconnect, device number 114
[Tue May 11 15:02:45 2021] usb 3-1.1: new full-speed USB device number 115 using ehci-pci
[Tue May 11 15:02:45 2021] usb 3-1.1: New USB device found, idVendor=03eb, idProduct=2ff4, bcdDevice= 0.00
[Tue May 11 15:02:45 2021] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[Tue May 11 15:02:45 2021] usb 3-1.1: Product: ATm32U4DFU
[Tue May 11 15:02:45 2021] usb 3-1.1: Manufacturer: ATMEL
[Tue May 11 15:02:45 2021] usb 3-1.1: SerialNumber: 1.0.0
martin@ciraxis ~/tmk_keyboard> sudo dfu-programmer atmega32u4 erase --force
Erasing flash...  Success
Checking memory from 0x0 to 0x6FFF...  Empty.
martin@ciraxis ~/tmk_keyboard> sudo dfu-programmer atmega32u4 flash xt_usb_unimap.hex
Checking memory from 0x0 to 0x68FF...  Empty.
0%                            100%  Programming 0x6900 bytes...
[>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>]  Success
0%                            100%  Reading 0x7000 bytes...
Validating...  Success
0x6900 bytes written into 0x7000 bytes memory (93.75%).
martin@ciraxis ~/tmk_keyboard> sudo dfu-programmer atmega32u4 reset
[Tue May 11 15:03:58 2021] usb 3-1.1: USB disconnect, device number 115
[Tue May 11 15:03:58 2021] usb 3-1.1: new full-speed USB device number 116 using ehci-pci
[Tue May 11 15:03:58 2021] usb 3-1.1: New USB device found, idVendor=feed, idProduct=6512, bcdDevice= 0.01
[Tue May 11 15:03:58 2021] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[Tue May 11 15:03:58 2021] usb 3-1.1: Product: XT keyboard converter
[Tue May 11 15:03:58 2021] usb 3-1.1: Manufacturer: t.m.k.
[Tue May 11 15:03:58 2021] input: t.m.k. XT keyboard converter as /devices/pci0000:00/0000:00:1d.0/usb3/3-1/3-1.1/3-1.1:1.0/0003:FEED:6512.00B3/input/input260
[Tue May 11 15:03:58 2021] hid-generic 0003:FEED:6512.00B3: input,hidraw4: USB HID v1.11 Keyboard [t.m.k. XT keyboard converter] on usb-0000:00:1d.0-1.1/input0
[Tue May 11 15:03:58 2021] input: t.m.k. XT keyboard converter as /devices/pci0000:00/0000:00:1d.0/usb3/3-1/3-1.1/3-1.1:1.1/0003:FEED:6512.00B4/input/input261
[Tue May 11 15:03:58 2021] hid-generic 0003:FEED:6512.00B4: input,hidraw5: USB HID v1.11 Mouse [t.m.k. XT keyboard converter] on usb-0000:00:1d.0-1.1/input1
[Tue May 11 15:03:58 2021] input: t.m.k. XT keyboard converter System Control as /devices/pci0000:00/0000:00:1d.0/usb3/3-1/3-1.1/3-1.1:1.2/0003:FEED:6512.00B5/input/input262
[Tue May 11 15:03:58 2021] input: t.m.k. XT keyboard converter Consumer Control as /devices/pci0000:00/0000:00:1d.0/usb3/3-1/3-1.1/3-1.1:1.2/0003:FEED:6512.00B5/input/input263
[Tue May 11 15:03:58 2021] hid-generic 0003:FEED:6512.00B5: input,hidraw6: USB HID v1.11 Device [t.m.k. XT keyboard converter] on usb-0000:00:1d.0-1.1/input2
[Tue May 11 15:03:58 2021] hid-generic 0003:FEED:6512.00B6: hiddev0,hidraw7: USB HID v1.11 Device [t.m.k. XT keyboard converter] on usb-0000:00:1d.0-1.1/input3
[Tue May 11 15:03:58 2021] input: t.m.k. XT keyboard converter as /devices/pci0000:00/0000:00:1d.0/usb3/3-1/3-1.1/3-1.1:1.4/0003:FEED:6512.00B7/input/input264
[Tue May 11 15:03:59 2021] hid-generic 0003:FEED:6512.00B7: input,hidraw8: USB HID v1.11 Keyboard [t.m.k. XT keyboard converter] on usb-0000:00:1d.0-1.1/input4
There was not much information to be obtained by hid_listen though. (Man, is this the world's weirdest keyboard or what?)
I repeatedly disconnected and reconnected it to the adapter, pressed all the keys, and reconnected the adapter to USB a couple of times as well.
Code: [Select]
martin@meraxes ~ $ sudo hid_listen
Waiting for device:...................................
Listening:
Keyboard init.
[C]Keyboard start.
FF FF FF FF FF
Device disconnected.
Waiting for new device:..
Listening:
Keyboard init.
[C]Keyboard start.
FF FF FF FF
Listening:
Keyboard init.
[C]Keyboard start.
FF
Listening:
Keyboard init.
[C]Keyboard start.
Listening:
Keyboard init.
[C]Keyboard start.
FF
btw. – is this the right firmware to put the adapter back into IBM AT/XT mode: https://github.com/tmk/tmk_keyboard/blob/master/converter/ibmpc_usb/binary/ibmpc_usb_atmega32u4.hex
Offline hasu
  • @tmk
« Reply #52 on: Tue, 11 May 2021, 10:53:04 »
The converter receives FF, it is not normal at all.
It seems to place pulse on clock line at least, but there is nothing on data line.
The keyboard is not completely dead but has hardware failure or something? I don't have idea.
Yes.
Offline Drag0nFly
« Reply #53 on: Tue, 11 May 2021, 11:01:25 »
It appeared to have received the FF signals when the plug was disconnected + reconnected to the adapter a couple of times. Tried this in order to “trick” it into XT-mode to minic what @latmodel24 saw with his board.
btw.- still haven't gotten a reply from @MandrewDavis (the third person I know who has this board, and who was quite technically proficient). He hasn't been on the board for quite a while, but would probably have some pointers as to how this thing works.
Hoping I won't have to introduce the board to my sledgehammer, but it seems more and more tempting as time goes by...! ;)
Spent quite some time restoring it (case and keys) as well...
Offline latemodel24
« Reply #54 on: Tue, 11 May 2021, 22:50:47 »
deleted
« Last Edit: Tue, 11 May 2021, 22:52:32 by latemodel24 »
Offline Drag0nFly
« Reply #55 on: Wed, 12 May 2021, 06:30:13 »
I ended up selling mine, but It was crazy that mine was doing something on hid_listen, but nobody else's was.
That I certainly can understand. Obviously one cannot rule out a malfunction with the board, but seeing that myself and the member who had a K-430 NOS (@MandrewDavis) saw identical behavior, it did at least seem weird.
I'm a little reluctant to put in on eBay but will reassess the options here. Maybe a kind soul with several Zenith boards wants to have it in his or her collection as a rarity item. ;-)
Offline svaya
« Reply #56 on: Fri, 14 May 2021, 07:00:28 »
I have the same keyboard and for me it works with an passive AT to ps2 connected to an active PS2 to USB converter.
Offline Drag0nFly
« Reply #57 on: Fri, 14 May 2021, 07:20:10 »
Interesting – which active PS/2 to USB converter are you using, @svaya?
Offline svaya
« Reply #58 on: Thu, 03 June 2021, 09:57:07 »
I tried it both with an active XT converter and a AT adapter, it only works with the AT adapter and active PS/2 converter.
I am using this generic ps2 converter
https://www.emag.ro/cablu-adaptor-usb-tata-la-2-conectori-ps2-lungime-31cm-caips2/pd/DFVGCGBBM/
Offline Drag0nFly
« Reply #59 on: Sat, 05 June 2021, 13:47:00 »
Thanks for the extra info @svaya. Curious that it works with a combined mouse + keyboard adapter, and not the XT.
Do you remember how the keyboard behaved when using the active XT converter and AT adapter? (On mine I could only toggle the Caps Lock & Num Lock leds, and no info on hid_listen). My K-430 could obviously have some kind of defect though, but it seems it would be useful to try to connect it with a similar adapter as yours. Perhaps I can find one in my stash of old cables/converters.
Since an active XT adapter (do you know the type, btw.?) is more advanced – it certainly appears mighty strange that an *AT-to-PS/2 passive adapter* + a *PS/2-keyboard-and-mouse-to-USB-combo* adapter works better. But then again, things are not always logical... :)
Offline svaya
« Reply #60 on: Mon, 07 June 2021, 15:37:26 »
I used a PC/XT 5DIN keyboard to USB Soarer's Keyboard Converter, it flashed a bit the lights at the beginning and I could toggle Caps and Num, but couldn't type anything. I think there is a chance that your keyboard isn't dead. The ps2 to USB was a 1.5$ dollar cheap I think the transport was more than the cost of it. The fact that it has also the mouse usually tells that is active and not passive.
Offline Drag0nFly
« Reply #61 on: Mon, 07 June 2021, 16:49:28 »
That is pretty much the exact behaviour I am seeing also with my K-430 using both the Soarer XT/AT adapter and also @hasu's TMK IBMPC adapter; I'll try to get hold of an identical PS/2+mouse to USB combo converter as yours to test – probably off of eBay.
Thanks for the valuable input. :thumb:
Offline hasu
  • @tmk
« Reply #62 on: Wed, 09 June 2021, 09:24:58 »
Drag0nFly,
I updated IBMPC converter firmware with some changes recently, this may show something helpful on debug output, perhaps. Try the latest firmware.
https://geekhack.org/index.php?topic=103648.msg3055384#msg3055384
Offline Drag0nFly
« Reply #63 on: Wed, 09 June 2021, 17:25:22 »
Thanks for supplying a newer firmware @hasu. I flashed the adapter now and notice it did provide a little more output.
The first entry is from connecting the keyboard to the adapter while the USB is already connected to the computer. The subsequent two are from disconnecting and reconnecting the USB adapter with the keyboard already hooked up.
Notice that the two are different.
Code: [Select]
Waiting for device:
Listening:
60195 ERR:20 ISR:C000 e20
60723 ERR:20 ISR:C000 e20
Waiting for new device:......
Listening:
TMK:2a0471fd/LUFA
USB configured.
Keyboard start.
I739 A3741 wFF R R R R R R R R R R
4133 ERR:11 ISR:0000 X4634
Listening:
TMK:2a0471fd/LUFA
USB configured.
Keyboard start.
I427 A3428 wFF R R R R R R R R R R
3820 ERR:11 ISR:0000 X4321
Waiting for new device:...................................................................⏎
One change is that now only Caps Lock can be toggled. (Before the Num Lock was available to be toggled as well.)
Offline hasu
  • @tmk
« Reply #64 on: Wed, 09 June 2021, 17:58:46 »
No helpful info unfortunately. The keyboard doesn't seem to work in terms of converter.
what does this mean actually?
You can press CapsLock key on the keyboard and toggle its indicator?
Or just blink LED on startup and the key doesn't anything?
Offline Drag0nFly
« Reply #65 on: Wed, 09 June 2021, 18:52:00 »
I can press the CapsLock key on the keyboard and toggle its indicator. On prior firmware, and with the Soarer, I could toggle both the CapsLock and NumLock LED.
Offline hasu
  • @tmk
« Reply #66 on: Wed, 09 June 2021, 19:35:55 »
Interesting.
That doesn't show anything on hid_listen? If not, the keyobard itself controls the indicator internally for some reason.
Indicators on normal AT or PS/2 keyboards are controled by command(wED) from host and hid_listen shows debug output like below.
Code: [Select]
r58 wED rFA w04 rFA rF0 r58
The keyboard doesn't like startup command sequece of the firmware and stops working, perhaps. This is plain PS/2 converter firmware which doesn't issue any command at startup, this may show difference.
* ps2_usb_32u4.hex (63.76 kB - downloaded 281 times.)
Try this also. This is IBMPC converer firmware with 30sec wait before issueing commands. This shows something if the keyboard sends something. BAT code 'AA' is usually expected. Also try pressing some keys.
* ibmpc_usb_atmega32u4.hex (58.8 kB - downloaded 281 times.)
Connect keyboard with converter first and then plug into USB port when doing these tests.
« Last Edit: Wed, 09 June 2021, 19:38:36 by hasu »
Offline Drag0nFly
« Reply #67 on: Thu, 10 June 2021, 12:17:39 »
Did not get anything from the ps/2 firmware unfortunately.
Code: [Select]
sudo hid_listen
Waiting for device:...........................................................................
Listening:
TMK:f03668da+/LUFA
USB configured.
Keyboard start.
Listening:
TMK:f03668da+/LUFA
USB configured.
Keyboard start.
Output from the IBMPC firmware with the added 30sec delay:
Code: [Select]
Waiting for device:
Listening:
Listening:
TMK:f03668da+/LUFA
USB configured.
Keyboard start.
I449 A30451 wFF R R R R R R R R R R
30843 ERR:11 ISR:0000 X31344
Listening:
TMK:f03668da+/LUFA
USB configured.
Keyboard start.
I589 A30590 wFF R R R R R R R R R R
30982 ERR:11 ISR:0000 X31483
Listening:
TMK:f03668da+/LUFA
USB configured.
Keyboard start.
I613 A30615 wFF R R R R R R R R R R
31007 ERR:11 ISR:0000 X31509
Listening:
TMK:f03668da+/LUFA
USB configured.
Keyboard start.
I544 A30545 wFF R R R R R R R R R R
30937 ERR:11 ISR:0000 X31439
btw.-I can toggle all three LEDs. They seem to be affected by which state the keyboard is in. That is, I had to powercycle it a couple of times, and they behave consistently. Especially the NumLock can get "out-of-sync". Once the proper state is restored, all can be toggled.
Curiously, if one of the LEDs were not able to be toggled before the power-cycle, they also do not light up during initialization.
And again, no output from pressing other keys, and small variations in the output after each power cycle (each with a wFF, which seems to be hid_listen's way of saying "WTF") ;)
« Last Edit: Thu, 10 June 2021, 12:20:03 by Drag0nFly »
Offline Drag0nFly
« Reply #68 on: Sun, 08 August 2021, 13:05:39 »
> ¡Update! <  ;D
I finally got myself another XT keyboard (actually, one that is AT/XT switchable and which I set to XT-mode, dubbed "8088" on the keyboard (the AT mode is identified as "80286" (not accurate, but the switching works.)
In any case, the results were extremely interesting (at least to me). I first tried @hasu's TMK adapter, with the most recent IBM PC firmware.
I connected the _other_ keyboard first (set to XT-mode), then plugged in the USB. Pressed a few keys, and disconnected. The disconnect is logged as:
Code: [Select]
[OVR]
36090 ERR:F0 ISR:FFC0 !FF! rFF
[OVR]
in hid_listen.
I subsequently unplugged the DIN-connector (*leaving the USB-side connected*) and connected the Copam K-430.
Lo and behold – it not only produced codes with hid_listen, but *actual keys registered*. At least for a while, until I apparently hit too many keys, or the keyboard went into a reset state. (I thought it was the Scroll-Lock key that did this, but I am not sure.)
The output from the Copam when using @hasu's TMK adapter (again, with the IBM PC firmware, not XT-specific firmware) follows below:
Code: [Select]
[OVR]
[OVR]
43926 ERR:20 ISR:C000 [RST] I43927
43927 PRT:22 ISR:0000 e20
44025 ERR:20 ISR:C000 e20
44851 ERR:20 ISR:C000
44852 PRT:21 ISR:0000 rAA A44853 wFF rAA
44856 PRT:22 ISR:AAC0 X45358 rAA W45362 wF2 R R R R R R R R R R R46255
46255 ERR:11 ISR:AAC0 S46256 L46256 r1E r9E r1E r9E r1E r9E r1E r9E r10 r90 r10 r90 r10 r90 r10 r90 r10 r90 r11 r91 r11 r91 r11 r91 r0F r8F r0F r8F r0F r8F r0F r8F r0F r8F r0F r8F r0F r8F r10 r90 r10 r90 r10 r90 r11 r91 r11 r91 r03 r83 r03 r83 r04 r84 r04 r84 r05 r85 r05 r85 r05 r85 r06 r86 r06 r86 r06 r86 r4B rCB r4B rCB r4B rCB r4B rCB r4B rCB r4B rCB r4B rCB r4B rCB r4C rCC r4C rCC r4C rCC r4C rCC r4C rCC r4C rCC r4C rCC r0E r8E r0E r8E r0E r8E r0E r0E
142 PRT:23 ISR:0EE0 r0E
223 PRT:22 ISR:0EC0 r0E r0E r0E r0E r0E
704 ERR:20 ISR:0E80 [RST] I705
706 PRT:22 ISR:0000 e20
785 ERR:20 ISR:0E80 e20
865 ERR:20 ISR:0E80 e20
946 ERR:20 ISR:0E80 e20
1059 ERR:20 ISR:1D00 e20
1130 ERR:20 ISR:0F00 e20
1214 ERR:20 ISR:8E80 e20
1288 ERR:20 ISR:0E80 e20
1455 ERR:20 ISR:8E80 e20
1555 ERR:20 ISR:0E80 e20
2278 ERR:20 ISR:8E80 e20
2369 ERR:20 ISR:0E80 e20
2460 ERR:20 ISR:8E80 e20
2554 ERR:20 ISR:0E80 e20
2738 ERR:20 ISR:8E80 e20
2888 ERR:20 ISR:1E80 e20
2960 ERR:20 ISR:9E80 e20
3051 ERR:20 ISR:1E80 e20
3112 ERR:20 ISR:9E80 e20
3212 ERR:20 ISR:1E80 e20
3386 ERR:20 ISR:9E80 e20
3527 ERR:20 ISR:1180 e20
4162 ERR:20 ISR:9180 e20
4266 ERR:20 ISR:1180 e20
4338 ERR:20 ISR:9180 e20
4428 ERR:20 ISR:1180 e20
4765 ERR:20 ISR:9180 e20
4867 ERR:20 ISR:2080 e20
4959 ERR:20 ISR:A080 e20
5059 ERR:20 ISR:2080 e20
5110 ERR:20 ISR:A080 e20
5220 ERR:20 ISR:2080 e20
5739 ERR:20 ISR:A080 e20
5830 ERR:20 ISR:2480 e20
5921 ERR:20 ISR:A480 e20
5992 ERR:20 ISR:2480 e20
6098 ERR:20 ISR:A480 e20
6108 ERR:20 ISR:2480 e20
6188 ERR:20 ISR:1F80 e20 A30706 wFF R R R R R R R R R R
31098 ERR:11 ISR:0000 X31600
The keys that registered (in my terminal) were:
Code: [Select]
aaaaqqq33444555
I also pressed some function keys and arrow keys.
After the last error messages, the Copam stopped responding. I unplugged the TMK and re-tried with my Soarer.
With the Soarer I was able to test every key on the board multiple times – they _all_ register but curiously *do not* produce key events to the OS (i.e, no actual output as was seen – although briefly – with the TMK earlier!)
Output when using the Soarer adapter follows:
Code: [Select]
r0E +2A d2A
r8E -2A u2A
r0E +2A d2A r8E -2A u2A
r0E +2A d2A
r8E -2A u2A
R05
r86
rC6
r86
rC6
r8D
rCD
r8D
rCD
r8D
rCD
r8D
rCD
r8D
rCD
r8D
rCD
r8D
rCD
r8D
rCD
R06 R06 R05
R06 R06 R05
r89
rC9
r89
rC9
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
r82
rC2
r82
rC2
r87
rC7
r87
rC7
R06 R06 R06 R05
R06 R06 R06 R05
r88
rC8
r88
rC8
r88
rC8
R06 R05
R06 R05
R06 R05
R06 R05
r89
rC9
r89
rC9
r89
rC9
r89
rC9
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
r8A
rCA
r8A
rCA
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
r8B
rCB
r8B
rCB R06 R06 R06 R05
R06 R06 R05
r8B
rCB
r8B
rCB
r8B
rCB
r8B
rCB
r8E
rCE
r8E
rCE
r8E
rCE
R06 R05
R06 R05
R06 R05
R06 R05
r8F
rCF
r8F
rCF
r8F
rCF R06 R05
R06 R05
R06 R06 R06 R06 R05
R06 R06 R06 R06 R05
R06 R06 R06 R05
R06 R06 R06 R05
R06 R06 R06 R06 R05
R06 R05
R06 R06 R06 R05 R06 R05
r90
rD0 R06 R05
R06 R05
r91
rD1 R06 R05
R06 R05
R06 R05
R06 R05
r91
rD1
r91
rD1
r91
rD1
r91
rD1
R06 R05
r91 R06 R05
R06 R05 rD1
r91
R06 R05
rD1
R06 R05 r91
rD1 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
r92
rD2 R06 R05
R06 R05
r92
rD2 R06 R05
R06 R05 R06 R05
R06 R05
R06 R05
R06 R05
r93
rD3
R06 R06 R06 R05
R06 R06 R06 R05
R06 R06 R05
R06 R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05 r97
rD7 r96
r97 rD6
rD7
R06 R05
R06 R05 R06 R06 R06 R05
R06 R05 R06 R06 R05
R06 R05
R06 R06 R06 R05
R06 R06 R06 R05
r97
rD7
R06 R06 R06 R05
R06 R06 R06 R05
r98
rD8
r98 rD8 r98
rD8
R06 R05
R06 R05 r9A
rDA r99
rD9 R06 R06 R05
R06 R06 R05
r9A R06 R06 R05
rDA R06 R06 R05 r9A R06 R06 R05
rDA R06 R06 R05
rA1
rE1
rA1
rE1
R06 R06 R05
R06 R06 R05
R06 R05
R06 R06 R05
rA0
rE0
rA0
rE0
R06 R05
R06 R05
R06 R05
R06 R05
r9F
rDF
r9F
rDF
R06 R06 R06 R06 R05
R06 R06 R06 R06 R05
R06 R06 R06 R06 R05
R06 R06 R06 R06 R05
r9E
rDE
r9E
rDE
R06 R05
R06 R05
R06 R05
R06 R05
r9D
rDD
r9D
rDD
r9D
rDD
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R05
R06 R05
r94
rD4
r94
rD4
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
r81
rC1
r81
rC1
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
r82
rC2
r82
rC2
r82
rC2
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
r83
rC3
r83
rC3
r83
rC3
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
r84
rC4
r84
rC4
r84
rC4
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
r85
rC5
r85
rC5
r85
rC5
r85
rC5
R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
r86
rC6
r86
rC6
r86
rC6
r95
rD5
r95
rD5
r95
rD5
r95
rD5
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
rA3
rE3
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R06 R05
rA3
rE3
R06 R06 R05
R06 R06 R06 R05
R06 R06 R05
R06 R06 R06 R05
rA4
rE4
rA4
rE4
rA4
rE4
rA4
rE4
r9B
rDB
r9B
rDB
r9B
rDB
r9B
rDB
rA5
rE5
rA5
rE5
rA5
rE5
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
rA6
rE6
rA6
rE6
rA6
rE6
rA6
rE6
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
rA7
rE7
rA7
rE7
rA7
rE7
rA7
rE7
R06 R06 R06 R05
R06 R06 R06 R05
R06 R06 R06 R05
R06 R06 R06 R05
rA8
rE8
rA8
rE8
rA8
rE8
rA8
rE8
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
rA9
rE9
rA9
rE9
rA9
rE9
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R06 R06 R05
R06 R06 R06 R05
R06 R06 R06 R05
R06 R06 R06 R05 rA6
rE6
rA6
rE6
rA5
rE5
rA5
rE5
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R05
R06 R06 R05
R06 R06 R05
r9C
rDC
r9C
rDC
r9C
rDC
r9C
rDC
r9C
rDC
r9C
rDC
r9C
rDC
r9C
rDC
r8D
rCD
r8D
rCD
r8D
rCD
r95
rD5
r95
rD5
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R05
R06 R05
r92
rD2
r92
rD2
r92
rD2
R06 R05
R06 R05
R06 R05
R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R06 R05
R06 R06 R06 R05
R06 R06 R05
R06 R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R05
R06 R05
R06 R06 R05
R06 R05
R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R06 R05
R06 R06 R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
rA1
rE1
rA1
rE1
rA1
rE1
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
rA0
rE0
rA0
rE0
rA0
rE0
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
r9F
rDF
r9F
rDF
r9F
rDF
R06 R06 R06 R06 R05
R06 R06 R06 R06 R05
R06 R06 R06 R06 R05
R06 R06 R06 R06 R05
R06 R06 R06 R06 R05
R06 R06 R06 R06 R05
r9E
rDE
r9E
rDE
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
r9D
rDD
r9D
rDD
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
r94
rD4
r94
rD4
r94
rD4
R06 R05
R06 R05
R06 R05
R06 R05
r81
rC1
r81
rC1
r81
rC1
r81
rC1
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
r82
rC2
r82
rC2
r82
rC2
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
r83
rC3
r83
rC3
r83
rC3
R06 R06 R05
R06 R06 R06 R05
R06 R06 R05
R06 R06 R06 R05
R06 R06 R05
R06 R06 R05
r84
rC4
r84
rC4
r84
rC4
r84
rC4
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
r85
rC5
r85
rC5
r85
rC5
r85
rC5
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R05
R06 R06 R05
r86
rC6
r86
rC6
r86
rC6
r95
rD5
r95
rD5
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
r80
rC0
r80
rC0
r80
rC0
r80
rC0
r80
rC0
rA2
rE2
R06 R06 R05
R06 R06 R05
R06 R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
rA2
rE2
R06 R05
R06 R05
R06 R05
R06 R05
rA2
rE2 rA4
rE4
rA4
rE4
R06 R05
R06 R05
R06 R05
R06 R05
rA4
rE4
rA4
rE4
rA4
rE4
rA4
rE4
rA4
rE4
rA4
rE4
rA3
rE3
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R06 R05
R06 R06 R05
R06 R06 R05
rA4
rE4
rA4
rE4
rA3
rE3
rA3
rE3
r9B
rDB
r9B
rDB
r9B
rDB
r9B
rDB
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
rA6
rE6
rA6
rE6
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
rA5
rE5
rA5
rE5
rA5
rE5
rA7
rE7
rA7
rE7
R06 R06 R06 R05
R06 R06 R06 R05
R06 R06 R06 R05
R06 R06 R05
rA8 rE8
rA8
rE8
rA8
rE8
rA8
rE8
rA8
rE8
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
rA9
rE9
rA9
rE9
rA9
rE9
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05 rA6
rE6
rA6
rE6
rA5
rE5
rA5
rE5
R06 R06 R06 R05
R06 R06 R06 R05
R06 R06 R06 R05
R06 R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R06 R05
R06 R06 R06 R05
R06 R05 R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
r9A
rDA
r9A
rDA
R06 R06 R05
R06 R06 R05
r9C
rDC
r9C
rDC
r9C
rDC
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
rA1
rE1
rA1
rE1
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
r9C
rDC
r9C
rDC
r9C
rDC
r9C
rDC
r90
rD0
R06 R06 R05
R06 R06 R05
R06 R06 R05
R06 R06 R05
Again, this is me pressing every key from left-to-right about three times each, then repeating the cycle.
This worked for approx a minute (maybe two at the most), and the board goes back to registering nothing.
I thought this was quite interesting, as I have never – no matter how many times I've tried – with this Copam board to get any keys to register anything whatsoever (be it an error code or not) with hid_listen.
I will test again after leaving the board unplugged for a while. Unless it actually still has some kind of defect, it must have logic on the board to switch it into some mode where only CapsLock, ScrollLock and NumLock register (internally), and no keycodes are passed on.
Hope some of this ranting was useful, and sorry for posting in the middle of summer when people probably are on vacation. I just couldn't wait, as I've spent quite some time with this board (not just testing, but restoring as well). :)
« Last Edit: Sun, 08 August 2021, 13:14:13 by Drag0nFly »
Offline hasu
  • @tmk
« Reply #69 on: Sun, 08 August 2021, 22:35:48 »
> ¡Update! <  ;D
I just want to confirm:
- Does the another XT keyboard work well with both Soarer's and TMK converter?
- What's model number and manufacturer of the keyboard?
Code: [Select]
[OVR]
[OVR]
in hid_listen.
I can't know why plugging and unplugging the antoher XT keyboard makes different result, because TMK converter just starts new keyboard-initializing process again when a keyobard is removed and new one is plugged.
Doesn't the converter work without the another XT keyboard? Posting debug log would be helpful.
Code: [Select]
I43927
Code: [Select]
aaaaqqq33444555
[/code]
Pressed keys in the log were recognized by the converter like below.
Code: [Select]
aaaaqqqqqwww<tab><tab><tab><tab><tab><tab><tab>qqqww2233444555<Keypad-4><Keypad-4><Keypad-4><Keypad-4><Keypad-4><Keypad-4><Keypad-4><Keypad-4><Keypad-5><Keypad-5><Keypad-5><Keypad-5><Keypad-5><Keypad-5><Keypad-5><Backspace><Backspace><Backspace><Backspace>...
And it seems the covnerter missed one of signals of Backspace and kept out of sync after that.
Code: [Select]
r0E +2A d2A
r8E -2A u2A
r0E +2A d2A
r8E -2A u2A
R05
r86
rC6
r86
rC6
r8D
rCD
r8D
rCD
r8D
rCD
r8D
rCD
r8D
rCD
r8D
rCD
r8D
rCD
r8D
rCD
R06 R06 R05
R06 R06 R05
r89
rC9
r89
rC9
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R06 R05
It seems Soarer's converter received a few Backspace and lost sync after that as well as TMK.
R05 and R06 indicates timeout and start bit error respectively.
https://github.com/tmk/tmk_keyboard/wiki/Soarer's-Converter#error-codes
Do you remember what keys you pressed actually at very beginnig of the log?
« Last Edit: Sun, 08 August 2021, 22:37:29 by hasu »
Offline hasu
  • @tmk
« Reply #70 on: Sun, 08 August 2021, 22:54:07 »
Also, this is the latest build of my working repository. It is not released in binary form, only source code is available.
IBMPC converter is changed largely since then, it may show different result. Try it when you have time.
https://raw.githubusercontent.com/tmk/tmk_keyboard/copam_k430_test/converter/ibmpc_usb/binary/copam_44ee4f3f.hex
Offline Drag0nFly
« Reply #71 on: Mon, 09 August 2021, 07:11:49 »
> ¡Update! <  ;D
Hi @hasu - thanks for your reply!
The other keyboard works with both Soarer and your TMK converter, yes. I tried both AT ("80216") and XT ("8088") modes.
The board is a NTC KB-6252EA (https://deskthority.net/wiki/NTC_KB-6251#KB-6252)
btw-I notice the K-430 has an updated Wiki page on Deskthority, where it is now stated it's using the AT protocol (*NOT* XT), https://deskthority.net/wiki/Copam_K-430
AT is what is printed on the PCB on mine as well. Just to add more confusion... :)
Code: [Select]
[OVR]
[OVR]
in hid_listen.
The Copam does not work (so far) without the other keyboard having been connected first.
Which debug log do you mean btw.? – I posted pretty much all information I had. :)
Code: [Select]
I43927
Code: [Select]
aaaaqqq33444555
Code: [Select]
Code: [Select]
r0E +2A d2A
r8E -2A u2A
r0E +2A d2A
r8E -2A u2A
R05
r86
rC6
r86
rC6
r8D
rCD
r8D
rCD
r8D
rCD
r8D
rCD
r8D
rCD
r8D
rCD
r8D
rCD
r8D
rCD
R06 R06 R05
R06 R06 R05
r89
rC9
r89
rC9
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R05
R06 R06 R05
Ok – that is interesting. Almost seems as if the board is expecting some signal in return from the host-side, and gets confused if it doesn't get any.
aaaaqqq33444555 is the sequence I saved. I am not sure which others specifically, but will make sure to record this accurately if this re-occurs. Basically I was not expecting any output from the board, since I've tested it about 50 times by now with no success until now.
Offline hasu
  • @tmk
« Reply #72 on: Mon, 09 August 2021, 08:25:04 »
I mean debug print output in hid_listen.
Offline Drag0nFly
« Reply #73 on: Mon, 09 August 2021, 08:36:39 »
AFAIKS, hid_listen does not accept any parameters–
Code: [Select]
hid_listen -h
Waiting for device:.⏎
hid_listen --help
I looked at the homepage, but cannot see any documentation for its usage. Sorry if there is something I am missing.
Offline hasu
  • @tmk
« Reply #74 on: Mon, 09 August 2021, 09:06:08 »
No, I just want you to post output of hid_listen as you did :)
Can you try two test procesures below with this firmware?
https://geekhack.org/index.php?topic=111510.msg3073560#msg3073560
Test A.
1. run 'hid_listen'
2. plug the converter only
3. plug Copam into the converter
4. wait 10 sec
5. press Q, W and E key one by one
6. press radome keys(optional)
Test B.
1. run 'hid_listen'
3. plug another keyboard(NTC) into the converter
5. wait 10 sec
6. press Q, W and E key one by one
7. unplug the another keyboard(NTC)
8. plug Copam into the converter
9. wait 10 sec
10. press Q, W and E key one by one
11. press radome keys(optional)
Please post hid_lsiten outputs without omitting as possible.
Including this version display part would be especially helpful if there is it.
Code: [Select]
Listening:
TMK:44ee4f/LUFA:d6a7df
USB configured.
Loop start.
Offline Drag0nFly
« Reply #75 on: Mon, 09 August 2021, 09:12:24 »
Tried the copam_44ee4f3f.hex firmware, but there was no change from before.
I haven't been able to reproduce the behaviour I saw yesterday. The only thing I've noticed (with the working Nan-Tan keyboard) is that the TMK firmware appears to re-map the "<" key (to the right of the Left shift) as ' (tick). This only occurs when the keyboard is in XT mode. If it's in AT mode the mapping is correct.
With the Soarer, the keys are mapped correctly (i.e, < > and | §)
Apart from this, your firmware works best as the arrow-keys produce numbers on the Soarer (again, in XT mode). Just mentioning this, as there should be a quick way to fix the < > + mapping.
For the < + > (shift + <): (which outputs ' *)
Code: [Select]
Waiting for device:
Listening:
r56 'rD6 r36 r36 r56 *rD6 rB6
For the | + § (which outputs < >)
Code: [Select]
r29 <rA9 r36 r29 >rA9 rB6
Offline Drag0nFly
« Reply #76 on: Mon, 09 August 2021, 09:16:58 »
Test A (nothing interesting, unfortunately). I plugged the TMK in, which produced the output below. Waited 10 seconds, then pressed Q, W & E.
Code: [Select]
./hid_listen.mac
Listening:
A6423 wFF R R R R R R R R R R
6815 ERR:11 ISR:0000 X7316
35259 ERR:20 ISR:C000
35259 PRT:22 ISR:0000 rFF W35260 w
Offline Drag0nFly
« Reply #77 on: Mon, 09 August 2021, 09:20:18 »
Not much luck today. Test B-
Code: [Select]
Listening:
USB configured.
Loop start.
I175 A3176 wFF R R R R R R R R R R
3568 ERR:11 ISR:0000 X4069
17914 ERR:20 ISR:7000
34732 ERR:20 ISR:AA80
34870 ERR:20 ISR:1080
35802 ERR:20 ISR:9080
35929 ERR:20 ISR:1180
36659 ERR:20 ISR:9180
36786 ERR:20 ISR:1280
41529 ERR:20 ISR:9280
49596 ERR:20 ISR:E000
The space in the output is when the NanTan was unplugged, and the Copam re-plugged. Nothing is printed, and nothing except the Caps Lock + Num Lock keys register.
Offline Drag0nFly
« Reply #78 on: Mon, 09 August 2021, 09:24:07 »
btw. (and this is probably not useful), I believe when the Copam Keyboard actually output something I was able to toggle Scroll Lock. Now it does not register (only NumLock and CapsLock)
Offline hasu
  • @tmk
« Reply #79 on: Mon, 09 August 2021, 09:45:38 »
Can you reproduce it with previous firmware?
Hmm, the firmware was changed much since the last one, so it may work differently perhaps.
This is off topic and I want to focus on Copam here. Please report a bug in the IBMPC converter thread or github.
Offline hasu
  • @tmk
« Reply #80 on: Mon, 09 August 2021, 09:54:12 »
Agree. The logs show errors, it means the keyboard sends signals somehow.
It seems that the LED indicators are handled by the keyboard itself,  but I'm not sure about how the keys actually behave.
Offline hasu
  • @tmk
« Reply #81 on: Mon, 09 August 2021, 10:03:05 »
Code: [Select]
Listening:
USB configured.
Loop start.
With the firmware NanTan keyboard didn't even register any key on computer ?
Offline Drag0nFly
« Reply #82 on: Mon, 09 August 2021, 10:15:14 »
No, the keys were registered. I also noticed the "ERR" messages.
Offline hasu
  • @tmk
« Reply #83 on: Mon, 09 August 2021, 10:29:49 »
hmm, that is weird...
The converter should display something(like 'r10' for Q key for example) when it recieves a key successfully.
And the log shows the converter couldn't recognize the keyboard at all, I believe the converter don't register any key in that case.
Could you try the test again if you have time?
Offline Drag0nFly
« Reply #84 on: Mon, 09 August 2021, 10:46:17 »
It seems hid_listen on OSX is less verbose than Linux. I'd disregard the output from it. (It was just more convenient to use, as it's where I am typing from)
I re-flashed earlier firmware from June 10th, but the behaviour is the same.
Offline Drag0nFly
« Reply #85 on: Mon, 09 August 2021, 10:49:18 »
I'll try the test again also. It will not be straight away, as I've just dismantled the Nan Tan keyboard for cleaning/restoration.
At least I might be able to verify that the Copam on its own will not work. (Although the combination of both keyboards today yielded nothing useful.)
Offline Drag0nFly
« Reply #86 on: Mon, 09 August 2021, 11:58:26 »
(and thanks for the assistance so far @hasu – it is greatly appreciated!)  :thumb:
Offline hasu
  • @tmk
« Reply #87 on: Wed, 11 August 2021, 00:49:53 »
It would be better to test on Linux or Windows if possible.
I don't have Mac and didn't test 'hid_listen'. Debug process would be very difficult if hid_listen doesn't work well on Mac.
Anyway, no rush at all. Take time for your restoration!
Offline Drag0nFly
« Reply #88 on: Fri, 13 August 2021, 14:09:51 »
(Sorry about the OSX output, it was only for the last two tests. I'm not going to use it again, and the machine which actually captured the output from the Copam was one of my Linux systems.)
In any case; I ran a multitude of tests (around 20) today hoping that I could again re-create the behaviour. Long story short, I could not. I am including the output again, as it was incomplete last time for the "A" & "B" tests.
Test A:
Code: [Select]
Listening:
TMK:f03668da+/LUFA
USB configured.
Keyboard start.
I525 A30527 wFF R R R R R R R R R R
30919 ERR:11 ISR:0000 X31420
Test A, (switched to newer firmware, same result):
Code: [Select]
Listening:
USB configured.
Loop start.
I525 A3526 wFF R R R R R R R R R R
3918 ERR:11 ISR:0000 X4419
Test B: (NTC in XT/8088 mode)
Code: [Select]
Listening:
TMK:f03668da+/LUFA
USB configured.
Keyboard start.
500 PRT:22 ISR:AAC0 I501
501 PRT:22 ISR:0000 rAA A502 wFF R R R R R R R R R R
894 ERR:11 ISR:0000 X1395 rAA W1396 wF2 R R R R R R R R R R R2288
2289 ERR:11 ISR:AAC0 S2289 L2289 r10 r90 r11 r91 r12 r92
15703 ERR:20 ISR:C000 [RST] I15703
15704 PRT:22 ISR:0000 e20
15725 ERR:20 ISR:C000 e20 A
Test B (again), after I put NTC keyboard in AT ("80286") mode
Code: [Select]
Listening:
TMK:f03668da+/LUFA
USB configured.
Keyboard start.
I556
18294 ERR:20 ISR:C000 e20
18301 ERR:20 ISR:FF00 e20
18304 ERR:20 ISR:FC00 e20
18307 ERR:20 ISR:FF00 e20
18310 ERR:20 ISR:FE00 e20
18313 ERR:20 ISR:FE00 e20
18316 ERR:20 ISR:FF00 e20
18319 ERR:20 ISR:FC00 e20
18322 ERR:20 ISR:FC00 e20
18326 ERR:20 ISR:FE00 e20
18337 ERR:20 ISR:F800 e20
18341 ERR:20 ISR:F800 e20
18344 ERR:F0 ISR:FFC0
18345 PRT:22 ISR:0000 !FF! rFF A18346 wFF isr:FF00
18350 ERR:12 ISR:FF00 X18851
18852 PRT:10 ISR:EA90 rAA W18852 wF2 rFA rAB r83 R19358
ID:AB83(AT) S19358 wED rFA w00 rFA L19364 r15 rF0 r15 r1D rF0 r1D r24 rF0 r24
Test B (switched to newer firmware, same result), again in AT mode:
Code: [Select]
Listening:
USB configured.
Loop start.
Listening:
USB configured.
Loop start.
I304 A3305 wFF R R R R R R R R R R
3697 ERR:11 ISR:0000 X4198
11993 ERR:20 ISR:E000
12123 ERR:20 ISR:F000
12124 PRT:23 ISR:0000 rFF W12124 wF2 rFA rAB r83 R12629
12629 PRT:10 ISR:A0D0 S12630 wED rFA w00 rFA L12636 r15 rF0 r15 r1D rF0 r1D r24 rF0 r24
After this I did the same tests with the Soarer, as well as two PS/2 to USB mouse+keyboard adapter dongles I had (one of which was reported to work by another member with the Copam). The one which worked best was my Aten branded one (it handled the "<" + ">" key correctly, which the generic adapter did not.
It did work perfectly with the NTC (albeit only in AT mode, not XT, but this is expected). The Copam behaved identically as with the Soarer and the TMK (only the three LED keys register.)
This time the Scroll Lock was active and working (dead during last tests), so I was incorrect in assuming it indicated that a "mode" had been set or that the keyboard had initialized properly.
The firmware version (TMK:f03668da+/LUFA) should also be identical (I notice it was not in the output I provided earlier, but I still had the screenbuffer from when I tested on the other host; I've saved all of it in case it's of further use. I thought for a moment that the two firmware versions were different, as I flashed the TMK a couple of months ago)
The curious thing is that the disconnect is not visible in the hid_listen log anymore when running newer firmware (which is unrelated to the Copam). Perhaps it was a coincidence.
I am including the start of the capture below (omitting the section which captured the NTC). (NOTE: this is the start if the capture from earlier, which logged keycodes from the Copam after the NTC was swapped with it on the TMK and Soarer firmwares)
Code: [Select]
Listening:
TMK:f03668da+/LUFA
USB configured.
Keyboard start.
531 PRT:22 ISR:AAC0 I532
532 PRT:22 ISR:0000 rAA A533 wFF R R R R R R R R R R
925 ERR:11 ISR:0000 X1426 rAA W1427 wF2 R R R R R R R R R R R2319
2320 ERR:11 ISR:AAC0 S2320 L2320
« Last Edit: Fri, 13 August 2021, 14:18:09 by Drag0nFly »
Offline hasu
  • @tmk
« Reply #89 on: Sat, 14 August 2021, 00:26:04 »
hmm, Copam keyobard doesn't seem to send any signal now(as before). We will have to find test procedure which can be reproduced using the NTC keyboard consistently.
Offline Drag0nFly
« Reply #90 on: Thu, 09 September 2021, 08:37:47 »
Hi @hasu,
I did quite a lot of further testing with the NTC keyboard – running in both XT and AT mode – and the Copam, but was unable to reproduce. I am unsure if I am on the same firmware which worked before, as this has been changed around quite a lot during testing. I should at least be seeing something.
A thought I am having is since the Copam is reported as being AT (and *not* XT) as thought before (https://deskthority.net/wiki/Copam_K-430), I was wondering if there is some variant of AT-only firmware for the TMK I could try (similar to the XT-only firmware you provided). It appears both the Soarer and the TMK default to XT in the event of an unknown keyboard.
Perhaps this is a longshot, but it might be worth trying if there is an 'experimental' version of the TMK firmware for AT-boards (e.g, in the case of other problematic AT keyboards tested earlier)
Offline hasu
  • @tmk
« Reply #91 on: Thu, 09 September 2021, 09:22:54 »
TMK "AT-only firmware" is ps2_usb converter.  You can find its firmware in this post.
https://geekhack.org/index.php?topic=111510.msg3057534#msg3057534
Source code is available here.
https://github.com/tmk/tmk_keyboard/tree/master/converter/ps2_usb
Offline Drag0nFly
« Reply #92 on: Thu, 09 September 2021, 12:53:14 »
Thanks, but I tried the ps2 firmware already: https://geekhack.org/index.php?topic=111510.msg3057731#msg3057731
Offline hasu
  • @tmk
« Reply #93 on: Thu, 09 September 2021, 20:56:53 »
Yes, you already did and that is what I wanted to say. PS/2 is equivalent to AT protocol. Did I read your previous post wrong way?
Your keyobard seems to me to be a XT keyboard from dedbug logs so far, but it can support AT somehow as others and the wiki say. You can try more other cheap PS/2 converters in the market to find one working with yours. It may be worth.
And you said the ATEN converter works with the Copam somewhat, right? Do you see other keys than '<>' register something? It may give us a clue. You can use tool like SwitchHitter or Aquakeytest to see undisplayable keys.
https://geekhack.org/index.php?topic=111510.msg3074824#msg3074824
Offline Drag0nFly
« Reply #94 on: Fri, 10 September 2021, 14:13:01 »
Ok, no problem @hasu. I thought for a moment that the test with the ps/2 firmware had not been noticed.
And no, the Copam does not work with the Aten converter. There was another member on here (@svaya) who indicated that his Copam K-430 worked with a generic AT-to-PS/2 + mouse+keyboard adapter, but I have not been able to 100% verify this (if the keyboard is indeed XT it would be strange, but I am thinking there might be different revisions of the board if so is the case.)
I did also buy a generic PS/2 mouse+keyboard adapter off of eBay, but it did not work with the Copam (tested repeatedly). Then again, my keyboard appears to enter a state where it does not want to talk to any connected computer unless some magic(tm) happens.
Obviously, I have yet to find what this magic is. Since it worked before with both the TMK and the Soarer (albeit for a short period of time, but most/all keys registered), I hoped to reproduce this but so far no luck...
Offline Drag0nFly
« Reply #95 on: Tue, 05 October 2021, 11:19:13 »
Hi @hasu,
Some actual news for this – finally. (and also big thanks to @svaya for sending a PS2 adapter which really helped this process.)
(Spoiler alert: this was a lesson in Occam's Razor if I ever saw one...)
I performed a number of tests for this board today, knowing that the specific adapter I was sent worked on another Copam K-430. I did a number of tests (10+), but to my dismay I could not get it working, after swapping around the various adapters I have (the Soarer, TMK, Aten AT/PS2 + two generic AT/PS2 adapters)
Then, *just after I was about to give up, keys started registering(!)*. I had moved the keyboard around a number of times during testing, and it turned out that once it had some weight on the internal 6-pin connector – when the cable was indirectly being pressed down because the heavy curled-cable was helping it due to the keyboard placement (hanging off the back) – it had contact. Color me stunned.  :eek:
Now, I've looked at the whole PCB several times to check for loose solder joints, especially for the cable, but all were solid. (Also applied DeOxit on all contact points.) Turning to a magnifier glass to look closer at the bottom side of the internal 6-pin cable, it appears that one of the cable pins (the blue one) inside the internal connector facing the PCB-side did not have proper contact as the metal had moved slightly up (the part touching the stiff pin on the PCB connector).
I then proceeded to pressing down on the metal part (top-side) with a very thin screwdriver and (re-)applied DeOxit (done a number of times before on the PCB), and I then re-tested the board with my other adapters. And – (to my amazement) the Soarer registered every key – except PrintScrn – (albeit, and unsurprisingly, with an error code, as reported by others). The other adapter I bought, which looks similar to the generic one I just received *also worked*.(!)  – every key registered, except the Scroll Lock, but I think that behaviour is a little special on this board.
Finally, I tested the TMK adapter and it (*drumroll*) also worked as well (!!) (scroll lock registered on this one, but for some reason not the Print Screen key), which works on the generic PS2 adapters (with a passive AT-to-PS2 plug). So @hasu, it turns out that your adapter had indeed worked all along, and I owe you a bit of an apology for not noticing this problem earlier. You were also right regarding the hardware issue.
I am still quite stunned (and frankly moderately embarrassed) that it actually was a matter of one pin inside the plug having intermittent contact, and that your adapter worked all along. But at least all the testing was not for nothing.
I think if I did not have the “known-working” adapter I would not have spent such a long time re-testing it (approx. an hour this time), and probably not noticed this silly cable problem; which finally explained why the keyboard was working earlier. Also interesting was that the Aten adapter (more expensive, did *not* work, and it behaved as when I tried the NTC keyboard in XT-mode (all LED lights flickering, same as for the NTC)
What is also funny (or perhaps, scary) is that this issue would probably not even have been noticed either if the top case was mounted on the keyboard (due to the downward pressure it would cause on the 6-pin cable, similar to pressing down on it slightly with a finger). Since I was restoring the keyboard, the case had been removed, as well as all the keycaps.
So, bottom line, the persistence paid off. I frankly thought that there was little hope for this board at this point. Now I have to decide how to solve the (non-existing) AltGr key, so that special keys can be used probably by remapping another, and look at why the PrintSrcn key does not work (both on the Soarer and the TMK), but curiously registers on the PS2 adapters. :)
But that issue is somewhat minor compared to the problems experienced earlier with the K-430...
« Last Edit: Tue, 05 October 2021, 16:56:03 by Drag0nFly »
Offline hasu
  • @tmk
« Reply #96 on: Tue, 05 October 2021, 19:38:39 »
Great to hear.
Use hid_listen to debug the keys(ScrollLock and PrintScreen) with Soarer's and TMK converter, once the keyboard starts working consistently :D
Offline Drag0nFly
« Reply #97 on: Wed, 06 October 2021, 14:02:21 »
Yes, it was a surprise indeed. I have now tested the keyboard a number of times, and it behaves consistently, both with your TMK adapter and the two generic PS/2 adapters.
Curiously, with hid_listen, no output is seen when pressing PrintScrn though. However, I know this key registers – and works – as it behaves correctly on both the PS/2 adapters, where the key is mapped to “screenshot” on my Linux machine.
The same behaviour is seen with the Soarer (no output with hid_listen)
EDIT: as I am writing this, I see from my older pictures of the board (I still have the caps removed) that what I thought was PrintScrn is actully SysRq (yes, a dedicated key for System Request). Somehow I think this key is being ignored with the TMK and Soarer firmware - at least in XT mode. See attached image.
The key for PrintScrn is actually to the right of "9" on the NumPad (presumably activated via Shift+*). However, it only produces ⋅ (hid_listen: 36 r36 r37 ⋅rB7 rB6)
The "correct way" also does not work on the other adapters.
277083-0
Scroll Lock and Num Lock work properly with the TMK firmware. I am including some hid_listen output below –
Code: [Select]
TMK:147575/LUFA:d6a7df
USB configured.
Loop start.
I558
620 PRT:10 ISR:AA90 rAA
624 PRT:22 ISR:AAC0 rAA A3559 wFF R R R R R R R R R R
3951 ERR:11 ISR:0000 X4452 rAA W4456 wF2 R R R R R R R R R R R5349
5349 ERR:11 ISR:AAC0 S5350 L5350 r1F r9F r20 rA0 r20 rA0 r20 rA0 r20 r1F rA0 r20 r9F rA0 r0E r8E r0E r8E r0E r8E r0E r8E r0E r8E r0E r8E r0E r8E r46 rC6 r46 rC6 r46 rC6 r46 rC6 r46 rC6 r46 rC6 r3A rBA r3A rBA r46 rC6 r3A rBA r46 rC6 r3A rBA
r46 rC6 r46 rC6 (Scroll lock)
r45 rC5 r45 rC5  (Num lock)
r36 r36 r37 ⋅rB7 rB6 (Shift + * on numpad, should – presumably – do PrintScrn. But SysRq is probably better to be re-mapped to this as on the PS/2 adapters, as it is never really used)
« Last Edit: Wed, 06 October 2021, 14:20:06 by Drag0nFly »
Offline Drag0nFly
« Reply #98 on: Wed, 06 October 2021, 14:06:19 »
btw., I presume ID:FFFF(XT) is some kind of standard identifier (being all hex Fs), as the keyboard should speak AT seeing that it works with the generic adapters (or it speaks both, but that sounds unlikely)
Offline hasu
  • @tmk
« Reply #99 on: Wed, 06 October 2021, 22:28:40 »
Interesting. Confirmed that Copam K-430 is AT/XT auto-switching finally.
First, the keyboard sends 'AA' intentionally with parity error on AT protocol and expects behaviour like below:
- AT host including normal PS/2 converters reply with 'FE' and the keyboard continues communication on AT protocol, I guess.
- XT host can recognize it as 'AA' ignoring preceding two redundant 0 pulses.
https://github.com/tmk/tmk_keyboard/wiki/IBM-PC-Keyboard-Converter#aa-with-prity-error
TMK converter doesn't detect the parity error and the keyboard switches to XT protocol immediately.
As for SysReq key it was introduced in IBM AT 84-key keyboard and didn't exists on IBM XT keyboard. The keyboard doesn't support the key in XT protocol unfortunately.
Maybe I'll fix my firmware for the parity error to support AT/XT auto-swithching keyboards later.
As for the Keypad* key, it is true on IBM PC/XT computer. PrintScreen function is handled by host when Shift and Keypad*  are pressed. PrintSreen key doesn't exits in original IBM XT keyboard. Later, some of clone XT keyboards introduced PrintScreen key but Copam K-430 didn't. TMK converter doesn't handle the Shift and Keypad* combination because it is not good for key remap.
Microsoft documented about how PrintScreen key should behave on XT protocol(Scan Code Set 1), see Note 4 if you are interested.
https://web.archive.org/web/20201112031338/download.microsoft.com/download/1/6/1/161ba512-40e2-4cc9-843a-923143f3456c/scancode.doc
« Last Edit: Wed, 06 October 2021, 22:36:56 by hasu »
