Author Topic: Things to know about the Model M?  (Read 6233 times)
Offline McStuff
« on: Sat, 14 August 2010, 01:31:10 »
I'm currently waiting on a model m that I snagged off ebay, and I have a few questions. First is, I keep hearing about rivets, but I dont know what that refers to. What are they and what do they do? Second, whats the best way to clean it? Lastly, is there anything else I should know about it?
Offline ThirdLap
« Reply #1 on: Sat, 14 August 2010, 03:02:42 »
Quote from: McStuff;212479
The Model M' uses plastic rivets to hold the top part of the internal keyboard assembly to a metal plate.  Over time these plastic rivets can weaken and fail, with the heads of the rivets falling off.  The end result is at best a less solid-feeling board, and at worst the board will become problematic or stop functioning all together.
Find a thin-walled 5.5mm (7/32") driver.  You can order one of these on the internet, or simply go to Osh or Sears and purchase a thin-walled 7/32" socket.  They can be difficult to find, but they're out there.
Remove the four screws on the back of the board and separate the two plastic halves.  Soak the top half in a solution of hot water and your cleaner of choice. I use OxiClean and dish detergent. You could also just throw it (the top plastic piece) in the dishwasher.
I prefer not to soak the rear plastic piece, as doing so could destroy the 'birth certificate' label on the back.  Instead, clean it by hand with some soapy water, avoiding disturbing the label.
Meanwhile, remove all of the keycaps by pulling firmly on each key. Soak them in a similar solution. If you have an M with the single-piece keys, the keys can still be removed (takes a bit more effort), but you will see a spring inside of a cylinder after removing them. Don't worry, the keys will simply snap back in place.
Use compressed air and Q-tips to clean the remaining keyboard assembly.
After soaking the plastic parts for a bit, use a scouring pad to remove any marks/glue/old tape/etc.  Model Ms clean up fairly easily, and I've yet to find one that doesn't look close to new after a bit of effort.
Depending on how dirty they were, the keys might require no more effort than simply soaking them and allowing them to dry.  If they are still dirty after soaking, use an old toothbrush to remove any remaining grime.
Let everything dry, then reassemble.
Some PS/2 to USB adapters are screwy, and will stop working.  I had to return one and purchase another, which has worked flawlessley. Try to find one of the adapters listed on this page.
They're as loud as their reputation.  Expect others in your household to comment on this.
They are as awesome as you've heard.  Enjoy it.
Hope this helps.
Offline hyperlinked
« Reply #2 on: Sat, 14 August 2010, 03:07:11 »
Thanks Thirdlap! I was going to ask this same question soon myself. I'm about to pick up a stash of 4 Model M's and I'm expecting to need to do a little cleaning and refurbishing before they're ready for the world.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline McStuff
« Reply #3 on: Sat, 14 August 2010, 03:13:11 »
Quote from: ThirdLap;212484
Remove the four screws on the back of the board and separate the two plastic halves.  Soak the top half in a solution of hot water and your cleaner of choice. I use OxiClean and dish detergent. You could also just throw it in the dishwasher.
Meanwhile, remove all of the keycaps by pulling firmly on each key. Soak them in a similar solution. If you have an M with the single-piece keys, the keycaps can still be removed (takes a bit more effort), but you will see a spring inside of a cylinder after removing them. Don't worry, the keys will simply snap back in place.
Some PS/2 to USB converters are screwy, and will stop working.  I had to return one and purchase another, which has worked flawlessley. Try to find one of the ones listed on this website.  I'll see if I can find the url.
Hope this helps.
Wow, this was a very thorough and good reply. Thanks for all the info. Also, I plan to use it with a PS2 port anyway, so I wont have any problems with converters.
Offline ThirdLap
« Reply #4 on: Sat, 14 August 2010, 03:21:22 »
Quote from: McStuff;212487
No prob. FWIW, the PS/2 port on my motherboard (Gigabyte MA790XT-UD4P) does not recognize my M, or any of my old PS/2 keyboards for that matter.  Apparently some modern motherboards have this issue.
Offline ThirdLap
« Reply #5 on: Sat, 14 August 2010, 03:23:39 »
Quote from: hyperlinked;212486
Glad I could help.  I've found refurbishing old Ms to be really enjoyable, as the process is incredibly straight-forward and they always seem to turn out looking great.
Offline McStuff
« Reply #7 on: Sat, 14 August 2010, 16:24:38 »
Quote from: ThirdLap;212489
Hmm, interesting. I snagged a 95, so I'd think it would work. We'll see.
Offline ch_123
« Reply #8 on: Sat, 14 August 2010, 20:59:33 »
Power draw for Model Ms remained constant AFAIK, even with the newer electronics used in 42H' style keyboards and Unicomps.
Offline McStuff
« Reply #9 on: Sat, 14 August 2010, 22:47:25 »
Couldn't you replace the plastic rivets with metal rivets if you wanted a more solid connection?
Offline wellington1869
« Reply #10 on: Sat, 14 August 2010, 22:53:45 »
Quote from: McStuff;212709
yes its been done. in the mods section i think.
using: ms 7000/Das 3
Offline McStuff
« Reply #11 on: Sat, 14 August 2010, 23:50:36 »
Quote from: ripster;212729
Here.
Now the IronMan of keyboards.  Indestructable except by spilled beers.
Interesting. What's the reason on using screw/nuts instead of rivets? Easy disassembly?
Offline McStuff
« Reply #12 on: Sun, 15 August 2010, 00:09:42 »
Quote from: ripster;212740
It's in the mod description but basically strength and ability to easily do different other mods like changing which keys are active (International Mini mod), spring swaps, tightening/loosening to taste.
Plus, it looks awesome.  Please post further questions in the mod thread.
Ah, makes sense. Also, I don't really have any other questions. I'll probably do the mod when I'm bored one day.
« Reply #13 on: Sun, 15 August 2010, 09:42:45 »
Nuts and bolts are easier to fix if you make a mistake. To remove a rivet, you need to drill it, and the heat from the friction could easily melt the plastic beyond repair.
Offline ThirdLap
« Reply #14 on: Sun, 15 August 2010, 19:31:39 »
Quote from: ripster;212542
Nice cleaning guide ThirdLap.   I added link to your post in the "All About Keys" wiki.
Cool, glad I could help.
Offline McStuff
« Reply #15 on: Wed, 18 August 2010, 16:25:59 »
My glorious new keyboard just arrived. I'm typing on it right now! The feel is definitely unique, and it's definitely a bit loud. However, it could definitely use a cleaning. I got lucky because I checked, and it has two piece keycaps :) It also worked straight out of the box with PS2. I've also tested all keys in Aquakeytest and there are no problems.
Offline McStuff
« Reply #16 on: Wed, 18 August 2010, 16:32:35 »
Quote from: ripster;214069
Welcome to the Mechanical Keyboard Klub!
Now I gotta run to Sears and get a driver to clean this thing. It's been used, that's for sure.
Offline EverythingIBM
« Reply #17 on: Wed, 18 August 2010, 16:53:51 »
Quote from: McStuff;214073
Here's a tip: don't flip the keyboard upside down and shake it, 'cause, dirt and stuff can go to the top of the keycaps, and fall down into the spring assembly. It actually can happen even with rubber domes.
Offline aegrotatio
« Reply #18 on: Wed, 18 August 2010, 17:20:35 »
Quote from: EverythingIBM;214086
Oh, wow, I never thought of that, you're right!!  I'm going to try to remember this tip.
Thanks!!
Daily Drivers: Ducky DK1087XM || DSI ASK-6600 || Rosewill RK-9000 BL, BR, BL, and RE || ABS M1 || Das Keyboard Silent || HHKB Lite and Lite 2 || DSI Big Font (kids love it)
Yearning for: Any ALPS keyboard || Any tenkeyless mechanical keyboard
Permanent collection: Poker Blue and Brown || Adesso MKB-125B || SIIG MiniTouch Geek Hack Space Saver || Chicony 5181 Monterey Blue || Chicony 5191 Clone Cherry Blues || Key Tronic 3600 || Unicomp Endurapro & SmarTrex || A crate of IBM Model M and Model M Space Saving boards || NeXTstation Slab || Amiga 3000 || BTC-5100C black and beige || SIIG MiniTouch Plus black and beige
Retired collection: SIIG MiniTouch Monterey Blue || Razer BlackWidow
Offline ch_123
« Reply #19 on: Wed, 18 August 2010, 18:05:47 »
For one, I can't really imagine dust getting into the barrels that easily. Even if they did, the membrane is covered by a rubber sheet, so it's far better sealed than a rubber dome keyboard.
« Reply #20 on: Wed, 18 August 2010, 18:19:46 »
Quote from: ripster;214121
I shake upside down all the time my kids filthy Unicomp, but end with a few sideways shakes.  No problems yet.
I think I'd do that with a unicomp one as well if I was lazy. But not a good IBM one.
Quote from: ch_123;214139
It's not DUST that is an issue, it's crumbs and crud, it gets into the springs. You still don't really want anything in there... it's best to unscrew the board and clean it out properly.
My rubber dome keyboard that I used to shake out all the time, had LOADS of grime in the membrane after doing the up-side-down shake. Stuff even got inside the LED assembly... I had to spray the whole thing down; but I wouldn't do that with my model M.
Offline ch_123
« Reply #21 on: Wed, 18 August 2010, 18:21:25 »
What if it was an IBM branded Unicomp?
Offline aegrotatio
« Reply #22 on: Wed, 18 August 2010, 23:21:31 »
Jesus, I really think I'm gonna hafta get a bonafide key puller so I can inspect every one of my Model M springs because I clean them by first turning upside down and tapping on the table, and then using a can of spray air.  The thousand or so bucking spring assemblies in my basement need my attention soon, I think.
Offline McStuff
« Reply #23 on: Thu, 19 August 2010, 00:10:40 »
Just waiting on the bottom part of the keycaps to dry. Everything else is clean. Next time I do this, I'm gonna get a keycap puller because the bottom parts are a bit difficult to get off.
Offline McStuff
« Reply #24 on: Thu, 19 August 2010, 02:10:29 »
Everything is cleaned up, and this keyboard looks basically brand new. In agreement from what I've heard, this thing is hefty and built like a tank. It is fairly loud, but not too annoying for me. I do like the feel, but the actuation force is a little high for my taste. Who knows? Maybe I'll grow to like it. I might also pick up something with cherry blues or similar because I think that'd be close, but with less force required. I've also swapped the caps to colemak without any issues of uneven tops.
Offline phototristan
    • https://www.youtube.com/phototristan
« Reply #25 on: Thu, 19 August 2010, 12:30:06 »
Quote from: McStuff;214302
You get use to it. After using a Model M, I can hardly use anything else b/c they feel too light. I tried a Cherry Blue and Cherry Brown, each didn't feel very good compared to the Model M.
I can type all day on a Model M and while I sometimes feel like my fingers are getting a workout, I have no fatigue or pain or anything. Heck, maybe the Model M is even good for you.
Offline ManjyomeThunder
« Reply #26 on: Thu, 19 August 2010, 13:42:13 »
Quote from: phototristan;214518
So I'm guessing you're done with the Realforce then? :P
-edit-
Nevermind, read your signature. Heh.
Current Favorite:  Noppoo Choc Mini with Cherry MX Blues
"Storage": ABS M1, Unicomp Customizer 104, Razer Lycosa, (3) Dell AT101W, GeekHack Space Saver
Other stuff: Razer DeathAdder, eXactMat
« Reply #27 on: Thu, 19 August 2010, 13:56:55 »
Quote from: ManjyomeThunder;214566
-edit-
If I can find tenkeyless Realforce in white, I may buy one.
« Reply #28 on: Thu, 19 August 2010, 14:05:45 »
Quote from: phototristan;214576
I just saw the white/grey Realforce 86U (not sure what key is apparently missing) on elitekeyboard's front page, but it's apparently sold out. Darn. :P
-edit-
It's the right Windows key, as if anyone used it to begin with.
Offline WhiteRice
« Reply #29 on: Thu, 19 August 2010, 14:12:00 »
Do NOT feed the model M after midnight
« Reply #30 on: Thu, 19 August 2010, 14:49:12 »
It's funny, I used to hate white/beige keyboards but now they are my favorite. Black keys start looking shiny too fast and black also shows dust quicker. There's nothing I hate more than to approach a black keyboard and see all they keys shiny.
Offline MissileMike
« Reply #31 on: Thu, 19 August 2010, 14:50:44 »
The Unicomp grey keys are good for this.  Not as nice looking as black on black, but a good compromise between looks and feasibility.
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
« Reply #32 on: Thu, 19 August 2010, 14:58:44 »
Quote from: MissileMike;214609
True. I liked them quite a bit when I had a Black Customizer 104. Did you notice they have a bit of glitter in them? I think they call the color 'metallic'.
« Reply #33 on: Thu, 19 August 2010, 15:29:15 »
Quote from: phototristan;214615
I notice the glitter on my customizer, was wondering if I was the only one. Heh.
Offline MissileMike
« Reply #34 on: Thu, 19 August 2010, 15:59:55 »
I don't notice it one bit... weird
Offline ch_123
« Reply #35 on: Thu, 19 August 2010, 16:03:50 »
You have to look at them up close with good lighting. I think it might be a side effect of their dying process - I think they took the beige keys and dyed them that grey colour. In the nibbed keys on my Unicomp (F, J, Numpad 5) the keys had a sort of brownish tinge to them.
I think they would look smarter if they used a darker gray colour, though I suppose that the brighter gray colour gives better contrast.
Offline itlnstln
« Reply #36 on: Thu, 19 August 2010, 16:09:19 »
It would be pretty sweet if they looked like the Topre keys.  The black keys they have are too dark, IIRC.  Skcheng had Unicomp put the black legends on the black keys, but I remember him saying they were too hard to see.  I wonder where that guy is anyway.
