Author Topic: [IC] GMK Hazakura 🌸 | GB LIVE !  (Read 233929 times)
Offline chocomint
Re: [IC] GMK Hazakura
« Reply #50 on: Thu, 11 March 2021, 02:53:47 »
hot
Offline Xemnova
« Reply #51 on: Thu, 11 March 2021, 03:13:02 »
Lovely looking set! Only comments -
In the base set neither of the tilde keys have the ろ sublegend, and as someone else mentioned in the latin kit it appears on the extra mod colored tilde key.
Offline misononyan
« Reply #52 on: Thu, 11 March 2021, 03:28:38 »
no mention that the sublegends/novelties will be pad printed/uv printed in the original post?
pretty weird, i think it's essential that people would know that the subs have much lower lifespan than the main legends
Offline Lyfe
« Reply #53 on: Thu, 11 March 2021, 04:11:03 »
Do strongly consider removing the numpad to keep costs low
Offline e_v_o8
« Reply #54 on: Thu, 11 March 2021, 04:38:26 »
Completely in for this, can't wait!
Offline prettydouchebag
« Reply #55 on: Thu, 11 March 2021, 08:40:37 »
Chomuwu = Best UwU
Damn you for running this in the same month as my fiancee's bday. The choice is clear regardless, but still.
Offline jagger27
  • ne 1.5U supers???
« Reply #56 on: Thu, 11 March 2021, 09:02:49 »
Beautiful base kit. You love to see it.
Offline Pontus
« Reply #57 on: Thu, 11 March 2021, 10:07:06 »
I like pink
I like this set :)
Offline JPoc
« Reply #58 on: Thu, 11 March 2021, 10:58:08 »
those are some beautiful renders
Offline GingGing
« Reply #59 on: Thu, 11 March 2021, 11:11:00 »
Finally a good quality pink flower themed set!
Offline BapoDonu
« Reply #60 on: Thu, 11 March 2021, 14:56:49 »
One mistake I see is in the latin kit, where the ろ is in the mod tilde key. That's about it but I'm looking forward to getting the latin and novelties kit.
Messed up the renders but now its fixed thanks for pointing it out
Offline Pylon
« Reply #61 on: Thu, 11 March 2021, 19:49:11 »
Is GMK's pad printing that precise? They absolutely need to nail the alignment to get that gate novelty done, and odds are good they're not able to do that key.
« Last Edit: Thu, 11 March 2021, 19:53:36 by Pylon »
Offline BapoDonu
« Reply #62 on: Fri, 12 March 2021, 11:12:04 »
Here are some pics from GMK Royal Alpha which show an example of UV print:
SOURCE: https://www.itheat.com/activity/thread-13324105-1-1.html check it out there are a lot of nice pictures.
Judging from this and other previous runs I believe alignment wont be an issue.
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #63 on: Fri, 12 March 2021, 17:34:18 »
cool 📸
Offline MichelKami
« Reply #64 on: Sat, 13 March 2021, 22:27:06 »
I'm in
Offline BapoDonu
« Reply #65 on: Sun, 14 March 2021, 17:21:07 »
Update:
Tweaked renders to make the hiragana subs more visible O.O
New vendor added for Asia - ZFrontier
40% kit is in the works will post soon !
Thanks for reading <3
Offline swifthunting
Re: [IC] GMK Hazakura 🌸 | Fixed renders.
« Reply #66 on: Mon, 15 March 2021, 00:32:14 »
No idea how printing for the novelties would work but wow, these are stunning, i'm in. GLWIC!
Offline VellFlamm
« Reply #67 on: Mon, 15 March 2021, 06:56:34 »
Love to hear that 40% kit is coming.
FYI, Hazakura(葉桜 leaf sakura) literally means Cherry that all the petal has fallen, and is now filled with fresh leaves.
So it is a bit weird name to give to a pink set tbh. But it is a nice-looking set.
Offline BapoDonu
Re: [IC] GMK Hazakura 🌸 | 40% kit
« Reply #68 on: Mon, 15 March 2021, 14:56:24 »
Update:
40s kit added
- "send" placeholder for a new icon.
1U novelty in the works:
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
« Reply #69 on: Mon, 15 March 2021, 19:44:53 »
I love pink!
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline shawnlyx
« Reply #70 on: Mon, 15 March 2021, 23:58:52 »
Plans for a cat rama?
Offline sup3r170va
« Reply #71 on: Tue, 16 March 2021, 06:07:33 »
Update:
40s kit added
Thanks. Looks good. For the 40s kit, suggest white 1u spacebars instead of pink.
I also second the suggestion of adding Rama keycaps. Hopefully both R1 1u as well as enter.
Offline Nukz
  • ig: nukzak
« Reply #72 on: Tue, 16 March 2021, 13:08:54 »
A bit better than pattiserie! GLWIC! :thumb:
Offline CookieFlow
« Reply #73 on: Tue, 16 March 2021, 15:25:12 »
Gib cute Rama (^• ω •^)
Yes Rama did some Rose Gold cat.
But you never see Pink Ramas (even Pink PVD), I feel it could be really nice.
Offline Chubby_potat0
« Reply #74 on: Tue, 16 March 2021, 18:07:56 »
really into those kitty novelties <3
Offline BapoDonu
« Reply #75 on: Wed, 17 March 2021, 18:15:56 »
owo
Offline Pylon
« Reply #76 on: Wed, 17 March 2021, 19:01:22 »
Sublegends are not a good example of the alignment you need to achieve on some of the novelties need though. If a UV printed sublegend is 0.3mm off of where it's supposed to be no one is really going to notice because there's a lot of whitespace between them and the main legend. Whereas on some of the novelties like the gate and one of the flower novelties, the alignment between the double shot and UV printed legends needs to be extremely precise, or you end up with fairly visible misalignment. E.g. on the gate novelty, if there ends up being a small amount of misalignment you get this:
I would recommend double checking with GMK that their UV pad printing is precise enough to not have something like the above happen.
« Last Edit: Wed, 17 March 2021, 19:03:08 by Pylon »
Offline Pach
« Reply #77 on: Wed, 17 March 2021, 19:49:43 »
Wow those novelties are nice. Never thought a change from 2 to 3 colors on a cap could look so much better.
Offline BapoDonu
« Reply #78 on: Wed, 17 March 2021, 19:51:45 »
I am checking with GMK, if there could be a potential issue with misalignment on the torii gate it will be reworked for that to be minimized.
Offline Xemnova
« Reply #79 on: Thu, 18 March 2021, 00:13:58 »
oooo 40's support, also the 1u kitty novelty looks like it will be cute, look forward to seeing the finalized design of it - the novelties in the novelty kit were already very nice. glad that you boosted the contrast of the sublegends, they were super hard to see initially
Offline Kacperoni
« Reply #80 on: Thu, 18 March 2021, 01:14:39 »
Definitely getting the novelties. Some more options of maybe Rama keycaps?
Offline BapoDonu
Re: [IC] GMK Hazakura 🌸 | Deskmat
« Reply #81 on: Thu, 18 March 2021, 23:54:21 »
Update:
-Added desk mat
Collab with Shirouu :3
Offline splodeybaloney
« Reply #82 on: Fri, 19 March 2021, 00:24:34 »
Woah ok I'm 1000% in for a shirouu deskmat at least
Offline shawnlyx
« Reply #83 on: Fri, 19 March 2021, 08:05:47 »
Kitty mat!! Now for a Kitty Rama!!
Offline CookieFlow
« Reply #84 on: Fri, 19 March 2021, 14:38:32 »
Update:
-Added desk mat
Cute mat
Now make cute Rama
   ٩(◕‿◕)۶
Thanks <3
Offline BapoDonu
« Reply #85 on: Sun, 21 March 2021, 09:34:29 »
Wanted to share some pics of GMK Originative Japanese for those who have not seen it before
Offline spoopycheezy
« Reply #86 on: Sun, 21 March 2021, 13:45:22 »
not enough pink sets! cant wait for gb
Offline engyshow
« Reply #87 on: Mon, 22 March 2021, 02:35:23 »
Looks nice, love the color way :)
Looks really good on the Pepper too!
Offline ThatCometGuy
« Reply #88 on: Mon, 22 March 2021, 11:34:17 »
Idk who is this set made after, however it reminds me of Miko therefore I want it, really good novelties and colorway.
Offline Octotrash
« Reply #89 on: Wed, 24 March 2021, 21:48:20 »
Reserved! It's so cute
Offline fromscratchusa
  • Keyboard Bag Tailor, I work with Keycap Designers.
    • FromScratch - Mechanical Keyboard Bags
« Reply #90 on: Thu, 25 March 2021, 01:57:03 »
Novelties of the year? The cat is so cute!!!
Offline BapoDonu
Re: [IC] GMK Hazakura 🌸 | Whimsy support, updated novelties
« Reply #91 on: Sun, 28 March 2021, 12:49:10 »
Update:
Whimsy support added :
1st 2.25 spacebar in base 2nd in 40s kit
Added R1 1U novelty and 2 R4 1U.
Quotes requested.
Offline Sicowa
« Reply #92 on: Sun, 28 March 2021, 13:48:42 »
1u cats are too cute chomuwu  :eek:
Collection: Khajit 60, Leopold FC980C, Pepper, Ex. Visa, Daedalus
pfp:https://twitter.com/kuroseP/status/1305179874429079553?s=19
Offline Ciantha
« Reply #93 on: Sun, 28 March 2021, 14:29:52 »
Update:
What is the reason behind the additional spacebars in the 40s kit being mod colored instead of alpha colored? As it is you'd end up with mismatched bars if you wanted to put 2x 2.25 on a whimsy.
Offline BapoDonu
« Reply #94 on: Sun, 28 March 2021, 14:50:08 »
Update:
Yes.
Fixed.
Offline ShenKichin
« Reply #95 on: Sun, 28 March 2021, 16:40:24 »
Behold my next build. GMK Hazakura Mountain
265558-0
Offline BapoDonu
Re: [IC] GMK Hazakura 🌸 | RAMA COLLAB 1/3
« Reply #96 on: Mon, 29 March 2021, 12:01:49 »
Update:
RAMA X HAZAKURA
COLLAB 1/3
Offline manic#1447
« Reply #97 on: Mon, 29 March 2021, 12:05:30 »
yooo that Rama looks amazing!!
Offline LeblancCafe
« Reply #98 on: Mon, 29 March 2021, 13:12:46 »
yes.
Offline CookieFlow
« Reply #99 on: Mon, 29 March 2021, 14:57:52 »
Update:
RAMA X HAZAKURA
COLLAB 1/3
Yay cute, would have prefered the main color of the cap to be maybe Pink instead of white
But excited to see what is coming next !
« Last Edit: Mon, 29 March 2021, 18:40:23 by CookieFlow »
