Author Topic: [IC] GMK Taiga | GB Starts on the 22nd of July  (Read 240014 times)
Offline autocast
Re: [IC] GMK Taiga | Re-added 40's support in base
« Reply #200 on: Sun, 13 June 2021, 05:13:45 »
Swoon
Offline Oggi
« Reply #201 on: Sun, 13 June 2021, 05:17:02 »
Consider putting nav subs on the numpad please! GL
I’ve thought about this, however I’m trying to minimize the amount of new Cyrillic molds I need to do (hence no F-row) so the kit can be kept at a reasonable price
Offline Bub
    • big bub's beepers
« Reply #202 on: Sun, 13 June 2021, 08:08:33 »
maybe something to consider in a r2 ;)
Offline mr_foggy
  • neue = nope
« Reply #203 on: Tue, 06 July 2021, 09:20:50 »
cyrillic mods!! omg 100% in
Offline Oggi
« Reply #204 on: Tue, 06 July 2021, 09:23:27 »
quick update, sent everything in for quotes, so now we just wait
Offline brunosan_.
« Reply #205 on: Tue, 06 July 2021, 10:01:11 »
Excited for this, Have you planned on putting the Cyrillic Legends as an alternate alpha kit?
Offline konstantin
  • Formerly constexpr
« Reply #206 on: Tue, 06 July 2021, 10:02:41 »
Кириллический* базовый :)
I wish I had seen this before, but there is a R4 1u Алт/Alt key missing from both base kits (and it's really quite important to have that key). Also, the R1 and R3 1u \/ keys in Cyrillic base should be alpha-colored, like the corresponding \| keys in Latin base are. Kitting looks great otherwise.
Edit: There is also a legend discrepancy between R2 1u Кон and R1 1u Кнц. Both keys should use the same legend. I think Кнц makes more sense, but you could just as well have the whole word, Конец, on there (although you may not want to, for symmetry with the abbreviated Нач legend).
Edit 2: The Cyrillic Num Lock legend appears to be using small caps (ЦИФР); it should use regular lowercase letters instead (Цифр).
Edit 3: This is likely just a rendering oversight, but one pair of homing alpha keys in each base kit, А/О and F/J, appear to be rendered as regular non-homing keys instead of scooped keys. It's obvious what the intent here was, but you might wanna fix this just in case, to avoid any confusion with GMK (since an actually scooped 5 key is also present in the kits).
« Last Edit: Tue, 06 July 2021, 10:26:06 by konstantin »
Offline paperassgasket
« Reply #207 on: Sun, 11 July 2021, 22:29:07 »
I agree with everything he said. ^^^
Offline grezeh
« Reply #208 on: Mon, 12 July 2021, 10:22:42 »
There were some "rendering mistakes", but i'm not sure how many (just was making a few remarks in discord the other day). Also agree/suggested "Кон" instead of "Кнц", but it seems not everyone thinks the same or/plus it's a designers choice. Good eye on homing keys.
Offline andreiborisov
« Reply #209 on: Mon, 12 July 2021, 13:06:51 »
"Кон" is going to be in the final version
Offline grezeh
« Reply #210 on: Thu, 15 July 2021, 14:21:42 »
 :thumb: Good! A cherry on top would be Cedar Cone novelty in base. Spent a lot of my childhood there- collecting cedar cones for nuts was one of the most memorable things, along with forest/mountain walks.
Offline HelloThisIsDog
« Reply #211 on: Mon, 09 August 2021, 13:42:23 »
Still really looking forward to this. Is there any news?
Offline Krolyk
« Reply #212 on: Mon, 09 August 2021, 14:49:07 »
Think he's still waiting for quotes. Been watching this like a hawk.
Sent from my SM-N986U using Tapatalk
Offline maximize
« Reply #213 on: Fri, 20 August 2021, 09:35:24 »
Oggi, your date formats in the post are all over the place lmao. MM/DD/YY and DD/MM/YY switch basically every update. Would be nice if you put the latest info in the main or second post!
« Last Edit: Fri, 20 August 2021, 09:40:46 by maximize »
Offline sup3r170va
« Reply #214 on: Fri, 20 August 2021, 10:14:05 »
No cryllic sub legend option?
Offline tarokeebs
  • TMOv2r2 || Kikuichimonji
« Reply #215 on: Fri, 20 August 2021, 14:37:41 »
renders looking nice :thumb:
collection: tmov2 | kikuichimonji
Offline jagger27
  • ne 1.5U supers???
« Reply #216 on: Sat, 02 October 2021, 21:19:53 »
Any updates?
Offline ggggggg
  • schmeiß die forties durch den club
« Reply #217 on: Sun, 03 October 2021, 00:36:49 »
Any updates?
(Seeing this thread bumped made my heart skip a beat)
I think they're still waiting on quotes from GMK last I checked...
Offline Bub
    • big bub's beepers
« Reply #218 on: Sun, 03 October 2021, 08:31:27 »
yeah pretty sure still waiting on quotes for new cyrillic mods. its tricky adding a lot of small doubleshot text like the mods have. lots to review.
anyway, cant wait for this. good things take time!
Offline screen
« Reply #219 on: Sun, 03 October 2021, 09:38:46 »
One of my fav keycaps set of the year probably. We need more loud color non latin alphas.
Offline Nonnegaard
« Reply #220 on: Mon, 04 October 2021, 05:45:12 »
Perestroika Nightmares   :D
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline Ella
  • Why is it called an oven
« Reply #221 on: Mon, 04 October 2021, 09:59:12 »
I need taiga in my life
Offline Gnome
« Reply #222 on: Fri, 08 October 2021, 14:56:23 »
Ne updates avail?
I told myself that I would stop buying gmk sets because of the current leadtimes, but I would make an exception for this.
I really like the green. Definitely down for cyrillic base and spacebars if pricing is acceptable :thumb:
Offline Mikhail
« Reply #223 on: Fri, 08 October 2021, 17:04:26 »
Just IMO - the Cyrillic set with latin sub-letters will be killer!
And this will be more historically correct - Soviet computers simply don't exist without Latin (as far as I know).
Offline Havattack
« Reply #224 on: Fri, 08 October 2021, 19:00:20 »
I too acknowledge the objective superiority of sub-legends over mono..
« Reply #225 on: Sat, 09 October 2021, 06:09:59 »
Might be a good idea for the second run, but for this to happen we need to make this one a success first
Offline Zeelobby
« Reply #226 on: Sat, 09 October 2021, 09:59:33 »
Plus sublegends are everywhere. Much prefer some cool mono legend sets.
Offline maximize
« Reply #227 on: Sun, 10 October 2021, 18:44:43 »
This person gets it.
Offline vishydesigns
« Reply #228 on: Mon, 11 October 2021, 21:27:18 »
I feel like your missing out not incl novelties, would be awesome! and maybe an accent kit? set looks great otherwise!
Offline Namkhanhv
« Reply #229 on: Mon, 11 October 2021, 23:11:24 »
Love the colortheme so I'd definitely be in when the buy opens.
Offline NightFox99
« Reply #230 on: Sat, 16 October 2021, 15:15:57 »
Waiting for GB, I'm all in. Keep it the way it is - no sublegends, the color is perfect
Offline GMK83
« Reply #231 on: Sat, 30 October 2021, 16:10:15 »
Was there any updates on this?
Offline 1017BirckenThot
« Reply #232 on: Sat, 30 October 2021, 20:44:08 »
Patiently waiting for GB date announcement.  :thumb:
Offline illusixn
  • Formerly illusixn
« Reply #233 on: Sat, 30 October 2021, 22:27:48 »
Not until GMK decides to actually make their employees do work.
Offline tunb
« Reply #234 on: Mon, 01 November 2021, 23:34:49 »
How long to release ?
Offline peaceperfection
« Reply #235 on: Thu, 11 November 2021, 21:32:55 »
Any updates?
Offline GMK83
« Reply #236 on: Sun, 21 November 2021, 09:25:13 »
Seems like this project went idle.   :(
Offline Mikhail
« Reply #237 on: Sun, 21 November 2021, 09:46:25 »
It sad, this set could be a great gift in honor of supreme leader Putin, who love to rest in taiga with defense minister Shoigu (sorry).
Offline Oggi
« Reply #238 on: Mon, 22 November 2021, 10:10:36 »
Hi everyone, no major updates, wish I could tell you more. Join the discord in the meantime to see what else I'm up to
« Last Edit: Wed, 15 December 2021, 11:45:01 by Oggi »
Offline Ella
Re: [IC] GMK Taiga | Still no quotes
« Reply #239 on: Mon, 22 November 2021, 10:28:59 »
GMK should kidnap some oompa loompas
Offline GMK83
« Reply #240 on: Tue, 23 November 2021, 06:28:37 »
Seems like most of the renders are a combination of both base sets.  :-\
Offline Oggi
« Reply #241 on: Tue, 23 November 2021, 07:02:45 »
This is because the cyrillic modifiers weren't a thing at the start of this IC, it was just 1 basekit with cyrillic alphas and english text + icon mods, more renders will come soon though
Offline GMK83
« Reply #242 on: Tue, 23 November 2021, 07:16:19 »
Makes sense!  Will they also get added to the extension kit, or will it be Latin only?
Offline Bub
    • big bub's beepers
« Reply #243 on: Tue, 23 November 2021, 08:22:56 »
cant wait for this SET
Offline Oggi
« Reply #244 on: Tue, 23 November 2021, 12:49:09 »
I plan on keeping the extension kit latin only to cut down on mold costs, and based on the feedback form I ran a while back it seems that the majority wants to stay as is. Definitely will be a thing for R2 though (if that ever happens)
« Last Edit: Tue, 23 November 2021, 12:54:06 by Oggi »
Offline GMK83
« Reply #245 on: Tue, 23 November 2021, 13:26:50 »
Thanks for the answer.  Looking forward to R1!
Offline maximize
« Reply #246 on: Wed, 24 November 2021, 12:33:27 »
Hi everyone, still radio silence from GMK in regards to quotes, wish I could tell you more. Join the discord in the meantime to see what else I'm up to, and to be the first to know once I do actually get quotes
Might it be worthwhile to reach out and confirm that GMK received your request for quote?
Re: [IC] GMK Taiga
« Reply #247 on: Mon, 10 January 2022, 15:45:49 »
The gears are moving ;)
Offline IOVERCALLHISTIOCYTES
Re: [IC] GMK Taiga
« Reply #248 on: Fri, 28 January 2022, 22:08:44 »
The gears are moving more let’s see this update
Offline HungHingDaiLo
  • 無間道
Re: [IC] GMK Taiga
« Reply #249 on: Fri, 28 January 2022, 22:43:01 »
Not to make FOMO but,
Taiga Revised Edition (near mint) is at $ 422.93 today, around $100 jump since last year.
Let's go Taiga and all the Dual Lands!
IG: @rayhhdailo
