Author Topic: Need Recs for Good Low End PC (Fall 2010)  (Read 14307 times)
Offline hyperlinked
« on: Sun, 15 August 2010, 17:08:46 »
I've got a friend who's shopping for a decent low end desktop PC. She's currently on something like a Dell with a Pentium II or something similarly outdated. She obviously doesn't need any sort of blazing system.
Any of you have some good recs on decent quality desktops in the $400 and under range that you could recommend? The specs of the machine are less important than overall durability and a company that provides at least some modest level of customer service would be a big bonus. This is a machine that needs to last her for 5+ years and should have a chance of still being a usable low-end system several years from now.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline Phaedrus2129
« Reply #1 on: Sun, 15 August 2010, 17:21:04 »
You good with building something for her?
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline hyperlinked
« Reply #2 on: Sun, 15 August 2010, 17:32:03 »
Quote from: Phaedrus2129;212885
I'm looking for a pre-built system. My hardware skills are light and I don't have the time to build something anyway. I also don't want to get stuck supporting this PC if it has issues a few months from now.
Offline ch_123
« Reply #3 on: Sun, 15 August 2010, 17:36:29 »
With manufactured stuff, it's very much a case of 'pick your poison'. They're all the same thing, they all probably come from the same factory, and for every good story about their customer service you hear, you'll hear a bad one from elsewhere.
Tbh, as sacrilege as it may be to people who have half a clue about computers, I always tell people to buy a Dell if they want a recommendation for a machine - I guess it's a sort of "Nobody gets fired for buying IBM" attitude I have towards the thing.
Offline Ekaros
« Reply #4 on: Sun, 15 August 2010, 17:40:54 »
Quote from: ch_123;212890
Yep, anything will do likely easiest is to find one with best warantty... Not too many differences in that price range.
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
« Reply #5 on: Sun, 15 August 2010, 17:42:10 »
If she's going for prebuilt PCs, then there aren't any *good* options. Dell likes to use shoddy motherboards using a BTX form factor so you have to buy from them when they fail. HPs tend to overheat like mofos. Acer have a very high failure rate. eMachines has solved their PSU troubles but I've heard their customer support is crap. All of the major OEMs are equally mediocre in different ways.
If she's willing to spend $500 shipped and wait a couple weeks I can build something and provide a year of support. Real technical support; I can actually diagnose **** instead of reading off a card, though I can't afford to replace it if the whole thing goes kaboom. It'd be a Sempron system with 2GB DDR3, 500GB HDD, Windows 7, SeaSonic 300W PSU.
Offline Ekaros
« Reply #6 on: Sun, 15 August 2010, 17:47:57 »
Quote from: Phaedrus2129;212895
It's just strange how powerfull todays cheap systems look like in old context, 500GB and 2GB ram... Just crazy a couple years back... Likely, in normal use they will last, if not newest stuff isn't wanted in software department...
[SIGPIC][/SIGPIC]
Offline gr1m
« Reply #7 on: Sun, 15 August 2010, 17:49:34 »
Something better. I have old parts lying around. An X2 5200 with a heatsink on an Asus mATX board with 1GB of DDR2 RAM and onboard graphics (some kind of Nvidia slop, GeForce 6000 onboard perhaps). I can provide the parts, Phaedrus can build it if he wants.
« Reply #8 on: Sun, 15 August 2010, 17:53:04 »
I'm not sure which is better, an Athlon64 X2 5200 or Sempron 140. The Sempron is certainly far lower power consumption. The Athlon is probably a little better though. I do normally recommend DDR3 for new systems though, DDR2 is only going to rise in price as DDR3 becomes the standard, so it's best to jump on the bandwagon now rather than later. That means AM3, which means forward CPU compatibility.
Hm, will an Athlon64 work in an AM3 socket?
Offline gr1m
« Reply #9 on: Sun, 15 August 2010, 17:57:48 »
Quote from: Phaedrus2129;212903
I agree with all your points except for the fact that there is absolutely no reason to future-proof this computer, since Hyperlinked even mentioned that a Pentium II rig is currently sufficient.
Hyperlinked, you can take a look at these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16883103267
http://www.newegg.com/Product/Product.aspx?Item=N82E16883114085
http://www.newegg.com/Product/Product.aspx?Item=N82E16883114086
Regardless of how garbage prebuilt computers are, if she's not going to play 11 hours of modern FPSes on it a day, it should be fine. I understand the quality concerns of pre-built computers (and I wouldn't buy one myself) but I wouldn't hesitate to buy one of those for, say, my grandmother.
Offline TexasFlood
« Reply #10 on: Sun, 15 August 2010, 18:00:13 »
Quote from: hyperlinked;212880
If you have a Microcenter around, there are worse places to look for a low-end PC.  Powerspec, eMachines, Acer, other new and many refurbished brands.  And at least where I live, the sales folks aren't terrible to get decent recommendations from.
Offline EverythingIBM
« Last Edit: Sun, 15 August 2010, 18:05:02 by EverythingIBM »
Offline Ekaros
« Reply #12 on: Sun, 15 August 2010, 18:05:35 »
Quote from: EverythingIBM;212908
Here's a cheap comp for $100:
http://cgi.ebay.ca/IBM-IntelliStation-Z-Pro-Workstation-Xeon-3-6GHz-1gb-73-/130420540440?pt=COMP_EN_Workstations
IntelliStation Z Pro, 3.6 Ghz Xeon (upgradeable to two). 8 GB Max RAM, & 70 GB SCSI HDD.
Done & done.
Can't care to look for specs, but does that one have PATA or SATA? Onces that 10k SCSI dies...
[SIGPIC][/SIGPIC]
Offline hyperlinked
« Reply #13 on: Sun, 15 August 2010, 18:09:52 »
Hey, that's cool of you to offer that Phaedrus. I'll put the offer of a custom built system on the table for her. I'll have to see what she's comfortable with. I don't actually know her that well. She's actually a customer of mine and is a very low end PC user. She has an AOL account and may have only recently finally moved off of dial-up.
She's not your typical AOL user though. I built her a website six years ago and she's been doing a pretty impressive job of maintaining the content herself all this time. She got stuck with garbage and has just gotten used to it and might actually be able to take a step forward if she has something that's not garbage.
« Reply #14 on: Sun, 15 August 2010, 18:12:50 »
Quote from: Ekaros;212910
Oh yeah, IBM always puts SATA in as well (above & beyond I always say). I was running a SCSI, SATA and IDE HDDs on my intellistation at one point: but yeah, things got sticky so I just use the SCSI.
I don't think it's going to die though, and if it does, you can still buy ultra 320 SCSI drives.
« Reply #15 on: Sun, 15 August 2010, 18:13:53 »
Well, we might be able to do it cheaper than $500 if Gr1m contributes the mobo/ram/cpu. He gets paid a fair value for them+shipping, then I order a case, PSU, HDD, and Windows 7 off Newegg, stick in an extra 2GB DDR2 I have sitting around, then ship it. Might get it down to $450.
Or Gr1m could just cut me out of the equation, but whatever. :p
EDIT: Oh, and I have an Earthwatts EA430 I could use for the PSU.
« Last Edit: Sun, 15 August 2010, 18:17:50 by Phaedrus2129 »
Offline gr1m
« Reply #16 on: Sun, 15 August 2010, 18:18:50 »
Na, since I won't be down for the tech support stuff and assembly (since shipping an assembled rig would be suicide from Canadistan). I'm just gonna sell the mobo and CPU for very cheap, you get it and do whatever you want with it. If that works for you and Hyperlinked, I'm fine with it. Name your price. It's been rotting in my closet for about a year so I won't be expecting crazy amounts for it.
Oh, and the RAM.
« Last Edit: Sun, 15 August 2010, 18:22:40 by gr1m »
« Reply #17 on: Sun, 15 August 2010, 18:26:13 »
Hm, that would work, but I'd appreciate you testing it for functionality first. But would $50+shipping sound fair to you?
Offline gr1m
« Reply #18 on: Sun, 15 August 2010, 18:28:29 »
Yeah, I'll test it. $50+shipping sounds fine. I even have the DVD drive if it's any use.
« Reply #19 on: Sun, 15 August 2010, 18:39:16 »
Sure, I was planning on budgeting that. Call it $55 then. ;)
And let's see, I'll do some basic config, put a decent AV and MalwareBytes on there, FireFox instead of IE (unless she really wants to use IE), and instructions to blow it out with compressed air once a year. That should work out well all around. Depending on shipping costs I might even get it down to $400.
Offline hyperlinked
« Reply #20 on: Sun, 15 August 2010, 22:01:07 »
Wow, I'm blown away by how everyone's trying to help me with this. Thanks!
I have to talk to this person first and I actually don't know when she'd be ready to buy something. She is probably at least weeks away from replacing her computer. Don't put in too much effort into helping me make this happen just yet. I don't want anyone to put more than a few minutes into this on my behalf until I can get a better idea of how committed she is.
Offline Lanx
« Reply #21 on: Sun, 15 August 2010, 22:19:32 »
scour coupon sites like
slickdeals.net or other coupon sites
(or i can pm you if you'd like,if i remember)
for when dell has coupon codes for their dell out
usually it's 15-20% off most of the time it's a code for everyone, sometimes it'll be a one time use only email code.
something like this(this will probably be gone but you get an idea of what dell can give you for 430ish bucks)
http://outlet.us.dell.com/ARBOnlineSales/Online/SecondaryInventorySearch.aspx?rn=4670&SC=&c=us&cs=22&l=en&s=dfh
See the thing about a prebuilt system like many have said is the tech support and issues, i'm known as the tech/geek guy for family/friends. For the first few years i was like yea cool, lemme come over and yada yada... then it got old. So i just say dell, if you break it down component wise it's probably a 10% net over what you can get from building yourself at newegg(don't forget dell ships free too).
if not that and you want coupons try e-junkie.com
i've never used them for dell coupons, but i have used them at least 3x to get unique/one time use staples coupons. I mean these staples coupons are like 2/3bucks and it's 25 off 75, so you basically get 22$ off really (and they email you the code right away).
here's one coupon now
http://www.e-junkie.com/shop/product/437595.php
but i highly recommend a dell/hp (whatever) builds it for her, tech supporting for free gets old after the first 10 years.
« Reply #22 on: Sun, 15 August 2010, 22:42:54 »
Quote from: Lanx;212978
That's why I usually limit it to one year, then some sage advice, then you're on your own. :tongue:
Offline 8_INCH_FLOPPY
« Reply #23 on: Sun, 15 August 2010, 23:18:19 »
Install linux on the PentiumII and it will be running as fast as a new pc.  My Pentium I is still usable as an everyday PC...
*Hides behind chair*
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
« Reply #24 on: Sun, 15 August 2010, 23:24:07 »
Quote from: 8_INCH_FLOPPY;212989
Ubuntu 10.04 does run quite nicely on my Athlon XP system. Probably too taxing for a Pentium II though. She'd need Puppy Linux or barebones Debian or something. Hardly user friendly.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #25 on: Mon, 16 August 2010, 14:17:02 »
I would recommend getting her a used computer, something in the 2004-2005 range, a 2.4 Ghz-3Ghz, 1GB RAM kind of deal. With Windows 2000 or XP, it'll be a perfectly good machine for daily use for many years to come.
Offline hyperlinked
« Reply #26 on: Mon, 16 August 2010, 22:01:52 »
Well, it turns out that she just wants to get a Dell after all. I gave her a list of options including some custom builds and the overwhelming number of choices was too much so she just decided to pick something from Dell, which is the make of PC she'd be replacing. Thanks for your help though everyone.
« Reply #27 on: Thu, 19 August 2010, 10:02:39 »
Ugh. Don't buy Dell. Buy HP.
« Reply #28 on: Thu, 19 August 2010, 17:48:01 »
Quote from: hyperlinked;213338
Dell... well, after it catches on fire, I know where to find a lot of good IBMs.
Offline Lanx
« Reply #29 on: Fri, 20 August 2010, 12:18:47 »
Quote from: EverythingIBM;214704
Lenovo just posted 55million in profits.
Offline whininggit
« Reply #30 on: Fri, 20 August 2010, 12:42:03 »
Yeah, perhaps ask Alan Cox whether his ThinkPad is available for sale.
Cherry G80-3000LSCGB-2 (modded to Cherry MX Browns) (main) | Cherry G84-4100 (Cherry ML) | Compaq MX-11800 (modded to Cherry MX Blue) | Dell AT101W (Alps Black) | IBM Model M 1391406 (Buckling Spring) | Matias Tactile Pro (1.0) (Alps) | SGI AT-101 (Alps w/Dampers) | Black Alpsulator (XM Alps-type)
Offline Voixdelion
« Reply #31 on: Fri, 20 August 2010, 18:56:45 »
Drat, too late!  But if anyone else is looking cheap pc's it looks like geeks.com has a bunch of machines in the mid- to  higher end p4's going for about 100-150 with various acoutrements.  There are some barebones deals too.  Looks like for about 200 you could even do better:
(refurbished)P4's
Barebones
AMD Athlon / Sempron Computers
Core 2/Duo in the $220 neighborhood
Pentium D(Dual Core) under $200
I like Geeks - they often have some outrageous sales.  I once got about 6 of the ez cd/dvd dispenser doohickeys for like a buck apeice.  (Which, btw, I also highly recommend if you do a lot of burning like I do; got one for each kind of media now: cd/dvd/lightscribe/DL/etc. I love those things-  much better than futzing with the cakeboxes all the time.)
EDIT>> Good God!  (Just checked out the exploding Thinkpad) While I learned my lesson in buying prefab rigs, that is a good reminder to watch out for counterfeit/sub par elcheapo components.  Phaedrus' contributed knowledge via marvelous guides was essential in my education concerning quality PSU's
« Last Edit: Fri, 20 August 2010, 19:02:06 by Voixdelion »
"The more you tolerate each other, the less enforcement will happen."-iMav
Offline iMav
  • geekhack creator/founder
« Reply #32 on: Fri, 20 August 2010, 22:02:55 »
My honest advise would be to go to a local Best Buy and buy the best system (from a specs standpoint) that you can find for $500 (you'll have lots of options).  Have her check with her credit card provider...many will double the manufacturer's warranty up to 5 years.
« Reply #33 on: Sat, 21 August 2010, 07:16:27 »
I'd recommend sticking with the PII and just re-installing Windows (Windows NT would run great on that). It's surprising how much you can get done with an old computer. I've been using my Pentium computer a lot more as my main machine (200Mhz, 64MB of RAM) and it runs pretty good with a fresh new installation of Windows.
Offline instantkamera
« Reply #34 on: Sat, 21 August 2010, 10:12:57 »
Quote from: iMav;215215
Likewise. It's all the same **** if you are just looking for a new OEM that runs, and buying from a local box store means you have someone to throw it at when it stops working. Also, good idea with the CC. Im surprised more people don't know all the various benefits you get when putting things on your CC.
Realforce 86UB - Razer Blackwidow - Dell AT101W - IBM model MCST  LtracX - Kensington Orbit - Logitech Trackman wheel opticalAMD PhenomII x6 - 16GB RAM - SSD - RAIDDell U2211H - Spyder3 - Eye One Display 2
Offline didjamatic
« Reply #35 on: Sat, 21 August 2010, 12:49:06 »
Just get whatever is the hot special from Dell/HP in the following price ranges.  It's just not worth spending less on a new system, you really sacrifice quality if you do.  If you are short, do what it takes to come up with enough to get to these price points.  That's my 2 cents.
Desktop with monitor - spend $500ish
Desktop without monitor - spend $400ish
Laptop - spend $550-750ish
Offline Voixdelion
« Reply #36 on: Sat, 21 August 2010, 14:10:32 »
Quote from: instantkamera;215352
I suppose that's true - The only time I ever had anything I purchased break on me it happened to be the HDD on the VAIO - it went three weeks before the (non-extended) warranty expired.  I just took it to the compusa and they took care of everything with very little hassle.   Lucky though, because if it had happened much later it would have cost me several hundred just for the drive, never mind someone to install it and transfer all the crap.  Although I guess I would've probably done it myself anyway, with it being under warranty I didn't have to, and also saved me the PITA of diagnosing it as the problem to begin with.  Still it's highly unlikely I will ever buy a pre-built machine again since I will only end up disassembling it eventually anyways...  I think once you get over the "void if broken" seal on the case screw of your pc, you should get an official "geek" card.
« Reply #37 on: Sat, 21 August 2010, 18:22:01 »
Quote from: Voixdelion;215424
I literally meant that you could throw it at them, as both they, and your newly broken PC, will probably be useless. It was kind of a reference to the fact that, with ANY OEM, your chances of failure are about the same. If nothing ****s the bed, then you are good to go. If something does, oh well. That's life.
But it would still beat putting it in the mail to Dell...
Also, my wife has managed to drop every laptop she has ever own, once per. Each time, HDD replacement. It costs next to nothing, and is easy as cake to install. I just gave her my macbook, so Im sure a new HDD is just around the corner...
« Reply #38 on: Sat, 21 August 2010, 20:02:36 »
Quote from: kishy;215509
Huh? Weak drives I presume?
My laptop (5 year old Dell Inspiron 630m) has hit the tile floor from a 3-4 foot fall at least 4 times, still going strong.
Just luck of the drop I guess. She always drops on an edge, but I really don't think that matters. I also don't think there is such a thing as a "weak" HDD. A head crash is a head crash. Im not sure if the macbook has an accelerometer in it, but that would be nice...
Also, to clarify, it has really only happened twice.
Offline Lanx
« Reply #39 on: Sun, 22 August 2010, 00:45:45 »
My fiance's company gave all the employee's a company backpack to use(it's a good bag) and the laptop compartment is side loaded. While it's nice that it seperates everything, lots of ppl forget to zip up the side bag and when they swing the bag, laptop falls out. I remember she told me this and at a company dinner i went to the IT guy and asked him about it, and he's said he hasn't had to replace a laptop from dropping in the past 2 years.(stolen, spyware, general failure... all that eh has done). Dell inspirions.
« Reply #40 on: Sun, 22 August 2010, 09:41:22 »
My old Micron laptop (a TransPort GX) has been through just about everything too. It's bee dropped, abused, and beat up for ten years and it still runs great.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #41 on: Sun, 22 August 2010, 21:35:02 »
My office tends to buy the worst, cheapest PCs imaginable.
Big warnings:
1)  Many of the super-small towers take only half-height cards.  A real ***** if you need a replacement video card, for example.
2)  Get dual-core; if nothing else, the reduced binding pays for the 10 dollar premium.
In my office, the X2 4200+ I built in late 2006 is the nicest PC; there was a Core 2 E6400, but it died and was cannibalized for parts for the collection of Semprons, Celerons, and a Pentium 4 3.20.
Overton130, Box Pale Blues.
