Author Topic: two trackballs for diffent things  (Read 15112 times)
Offline tebla
« on: Tue, 16 March 2021, 04:40:26 »
Does anyone know of a way to use two trackballs for different things? I want one to move the cursor as normal but the other one to just scroll horizontally and vertically. Windows will recognise them both but I don't know how to set them up to do different things.
Preferably a solution that doesn't involve writing my own drivers or taking apart the trackballs to nab the sensors and connect them to a single microcontroller (way above my skillset), although if this is the only way I would consider trying to learn it.
Offline blur410
  • Memewhile in World of Tanks...
Re: two trackballs for diffent things
« Reply #1 on: Sun, 04 April 2021, 13:18:10 »
You could also use a programmable rotary encoder for this at a much cheaper price, as I do, but the new Ploopy nano is QMK compatible and could be set up for scrolling while moving while your main trackball does trackball things.
Keyboard Ownership History: Dynex(Rubber dome chicklet keys)-EXTINCT, Macbook Air 2016(Scissor switch)-ACTIVE, Razer Ornata(Mecha-membrane)-EXTINCT, Corsair K68 RGB(Cherry MX Reds)-RETIRED, Razer Tartarus Pro(Razer optical analog)-RETIRED, Idobao ID-75(NK Creams)-SHELF, HHKB Pro 3 Classic(Topre BKE MX Mount)-ACTIVE, New Model F62(Capacitive buckling springs)-ACTIVE, Realforce 23UB(Topre)-ACTIVE, BM60-RGBEC w/KBDFANS 5 Degree Case(NK BOX Pinks)-SHELF, Focus 2001 (Alps White)-SHELF, Unidentified Vintage MX Black Board-SHELF
Offline tebla
« Reply #2 on: Mon, 05 April 2021, 04:08:00 »
Thanks! I'm considering rotary encoders too, but the two trackball thing.. this may sound silly but the plan is to have a trackball attached on each side of my Ergodox build and I think it would look cool to have it symmetrical.
Ploopy nano looks cool, QMK compatible? I didn't even realize QMK supported mice/trackballs!
Offline jamster
« Reply #3 on: Mon, 05 April 2021, 05:46:54 »
Kensington Orbit has a wheel that surrounds the ball, and this wheel scrolls the page.
Doesn't help with the symmetry thing, but functionality-wise it's great.
Offline tebla
« Reply #4 on: Mon, 05 April 2021, 07:46:17 »
Thanks, Kensington Orbit is my daily driver, absolutely love it!
I'm actually planning to use two of them for the build. I'd like to have 6 axis of control: right trackball move mouse, right scroll wheel verticle scroll, left trackball horizontal and verticle zoom, left scroll wheel horizontal scroll. might seem a little excessive but these are all functions I use a ton in my DAW so having them as dedicated controls instead of with modifier keys would be pretty nice I think.
Another thing a little unusual I'm thinking of trying is having the left/middle/right mouse buttons mapped to keys on the left half of the ergodox. Might make click-dragging actions nicer instead of having to hold the mouse button and move the trackball at the same time with right hand.
Offline RSMilward
« Reply #5 on: Thu, 13 May 2021, 10:09:43 »
I use EitherMouse https://www.eithermouse.com/ on my desktop machine with 2 Elecom trackballs (left and right) with mirrored cursors. I keep one on my menus and use the other for drawing. Check it out - satisfied user here!
