Author Topic: AT cable replacement  (Read 1704 times)
Offline WhiteRice
« on: Sun, 15 August 2010, 22:25:44 »
I took apart one of the keyboards I just got and noticed that the AT cable was attached by a 4 pin connector with a ground.
Is there any place to find a ps2 one I can replace it with?
Offline 8_INCH_FLOPPY
« Reply #1 on: Sun, 15 August 2010, 22:32:35 »
I have  2 extra ps/2 cables sitting here on my desk.  I found them attached to some horribly crappy Logitech membrane keyboards sitting in the dumpster.  Spend any longer than 30 minutes looking in dumpsters and I'm sure you will come across a pile of crappy ps/2 keyboards that nobody cares about.  If your time is more precious to you than that, just swing by your local thrift store and buy a crappy ps/2 keyboard for 50 cents.
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
Offline didjamatic
« Reply #2 on: Sun, 15 August 2010, 23:02:47 »
A sweet mod would be to install an sdl port on a pc at board so you could use any model m cable and be detachable.  But with that much effort you may as well install a USB converter instead.  Any ps2 cable should work, just find the pinouts and you're set
