Author Topic: In Search of Sound Dampening Mat Material  (Read 5788 times)
Offline ddrfraser1
  • RIP Neil
« on: Sat, 20 March 2021, 14:36:31 »
Hola folks. I'm on a mission to make the worlds quietest mechanical keyboard for my brother in law who is an audio engineer. I'd like to replicate the dampening mat used for the HHKB.
http://www.smartimports.net/hhkb-hg-embossed-vibration-absorption-mat/
I got this adhesive neoprene one off amazon but I heard silicon is better suited.
https://www.amazon.com/gp/product/B07FMWGJ6J/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
I'd like it to be something with an adhesive back. I'd rather not glue it. Also, has to fit under a full size. 12x12 won't do it.
Recommendations?
Re: In Search of Sound Dampening Mat Material
« Reply #1 on: Sat, 20 March 2021, 14:40:47 »
I always heard that sorbothane was the gold standard.
https://en.wikipedia.org/wiki/Sorbothane
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
Offline ddrfraser1
  • RIP Neil
« Reply #2 on: Sat, 20 March 2021, 18:48:05 »
Nice. Looks promising. Having a hard time finding any that fits the bill tho :/
Offline ju6ju8Oo
« Reply #3 on: Sat, 20 March 2021, 21:54:40 »
Silicone adhesive tape is expensive though
Offline Leslieann
« Reply #4 on: Sat, 20 March 2021, 22:08:22 »
Sorbothane works but it's typically not used on such large quantity, it's usually for small feet and such, which isn't surprising considering the cost.
If I was using a keyboard in a studio environment and concerned with it being heard I'd start with a something other than a (not quite) mechanical keyboard.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline ddrfraser1
  • RIP Neil
« Reply #5 on: Sun, 21 March 2021, 03:38:03 »
Well I may do some testing with my neoprene mat for now and see if that is satisfactory. Worst case I can always stick to 12 x 12‘s together and cut them to size if I do end up going with silicone.
« Reply #6 on: Sun, 21 March 2021, 04:13:28 »
You could also look at kits for lining the interior of PC cases with sound-damping foam. That foam is often self-adhesive, but not intended to be pressed though - only to block sound waves in air from reverberating in a metal chassis.
Offline ddrfraser1
  • RIP Neil
« Reply #7 on: Wed, 31 March 2021, 10:13:57 »
Here's the build log and the direction I ended up going in.
https://www.keebtalk.com/t/worlds-quietest-mechanical-keyboard/13656?u=ddrfraser1
