GB Thread HereTwilight SwitchesGroup Buy May 12th-May 22nd. Estimated to ship around mid-July, followed by an in-stock sale around then.- New, very tactile JWK switch combining their Clear-like tactile stem with their T1 leaf
- 5-pin housing
- POM Stem (purple), PC top and nylon bottom (smoky gray)
- 67g spring
- Unlubed
- By Pylon and brainandforce
Twilights are not a JWK recolor. It was born out of a JWK frankenswitch combo that Pylon and brainandforce discovered independently while experimenting: combining the MX Clear-like stem from a Durock Medium Tactile switch with the tactile leaf of the Durock T1 housing. The result is a sharp, punchy, tactile switch, with just a bit of pretravel. Imagine a smoother, much more tactile Ergo Clear. A tactile switch as intense as an NK_ Blueberry that can hold its own at lighter spring weights.
![[IC] - Twilight switches, a new JWK tactile (GB May 12th - May 22nd) 264876-1](https://geekhack.org/index.php?PHPSESSID=doaqlllgm50h79dfi5sglv8tfibtt3a3&action=dlattach;topic=111852.0;attach=264876;image)
If you want a taste of what this switch feels like, you can use the stem off a Durock Medium Tactile, Mode Signal, Penguin, or RARA V2, and pair it with the housing from a Durock T1 or Koala. We are making this a pre-assembled switch so you can avoid the hassles and costs of frankenswitching.
Teal T1 stem for comparison
Force curves:
Vendors and prices - [US] Dangkeebs- $0.55 USD per switch, in packs of 10
- [CA] AlphaKeys - $0.55 USD per switch, in packs of 10
- [CN] Moyu.Studio - 3.6 RMB per switch
Changelog:
3/21/21 - initial post.
3/21/21 - We upped the minimum spring weight from 55g to 60g, and the minimum option for spring weights on the IC form to 62g. We were initially under the impression that the Everglide Jade stem we used for testing the 55g spring was identical to the Durock Medium Tactile stem and other JWK Clear-like stems, but it is slightly more rounded and allows for a return with slightly lighter springs. Krzew on the Switchmodders Discord said that they couldn't get this to return with a Kelowna 58g spring. We just tested this with a Cherry 60g spring from an MX Brown and it did return, but JWK does not have a stock 60g spring, so 62g is the lightest we can offer stock. We also removed the Everglide Jade from the list of stems you can use to try out the feel of this switch. Apologies to those of you that wanted a 55g spring.
3/27/21 - Added Moyu.Studio as our vendor for China
3/31/21 - Added Mykeyboard.eu as our vendor for the EU.
4/24/21 - Added ProtoTypist as our vendor for the UK, and Daily Clack as our Australian vendor.
4/28/21 - Added Zion Studios as our Philipines/SEA vendor.
5/6/21 - Added USD pricing. Added force curve
5/7/21 - Remeasured the force curve (accidentally mixed JWK "V2" and "V1.5" parts on the switch used for 5/6 force curve - remeasured with all "V1.5" parts). Added comparison force curve.
5/9/21 - Slightly revised the wording on the description
5/10/21 - Added prices for each vendor
5/11/21 - Revised prices, added GB dates!
5/12/21 - Removed IC form, updated specs (switch is 67g and unlubed), updated prices [/list]
