Author Topic: [IC] - Twilight switches, a new JWK tactile (GB May 12th - May 22nd)  (Read 33091 times)
Offline ThickJimmy
Re: [IC] - Twilight switches, a new JWK tactile (GB May 12th - May 22nd)
« Reply #50 on: Tue, 11 May 2021, 22:46:13 »
Another JWK tactile I must buy!!!
Offline Achromous
  • noesc.co.uk
    • NOESC
« Reply #51 on: Tue, 11 May 2021, 22:55:10 »
That force curve graph and that price, I'm in for some of these switches for sure.
Offline lush_bunny
We're happy to announce that our group buy is starting May 12 and continues until May 22! If you haven't seen it in the main post, here are our vendors and prices:
[US] Dangkeebs - 0.55 USD per switch, in packs of 10
[CA] AlphaKeys - 0.55 USD per switch, in packs of 10
[CN] Moyu.Studio - 3.6 RMB per switch
[EU] Mykeyboard.eu - 0,55 euro per switch, in packs of 10
[UK] proto[Typist] - £0.47p per switch, in packs of 10
[AU] Daily Clack - $0.48 AUD per switch, in packs of 10
[PH] Zion Studios - 0.65 USD per switch, in packs of 10
We'll be running this initially as a group buy so that you can reserve switches for immediate delivery, but afterwards we plan to have an in-stock sale so you can come back if you need more later or miss the group buy.
Excellent! How long are we expecting for fulfillment? This is my first time joining a GB for switches.
« Last Edit: Wed, 12 May 2021, 00:54:01 by lush_bunny »
Offline Ella
  • Why is it called an oven
It's at the top of the post
Offline lush_bunny
Silly me. Thanks.
Offline inceptive
« Reply #55 on: Wed, 12 May 2021, 08:59:34 »
Just purchased mine, woo hooo!!!!!
Any decision if this are lightly lubed or unlubed?
Offline Pylon
« Reply #56 on: Wed, 12 May 2021, 12:05:15 »
Awesome! Thanks!
These are unlubed.
Offline lush_bunny
« Reply #57 on: Wed, 12 May 2021, 13:41:33 »
Potentially dumb question. Once fulfilled and JWK Twilight becomes an in-stock item, will the same vendors for the GB be carrying them?
EDIT: I'm asking because this is the difference between buying a lot of Twilights at once or just half now and half later.
« Last Edit: Wed, 12 May 2021, 13:48:00 by lush_bunny »
Offline holer
« Reply #58 on: Sun, 16 May 2021, 08:59:28 »
I came to ask just this!
Offline norb
« Reply #59 on: Sun, 16 May 2021, 09:50:56 »
the real question should be, how long will the stock last.
Offline lush_bunny
« Reply #60 on: Sun, 16 May 2021, 18:14:49 »
I mean if people buy it and people actually like it, I assume it will have regular restocks. This isn't some sort of super complicated switch after all, it's the a franken made from two tactiles from the same manufacturer.
