Author Topic: [IC] Thock It! JumboPad  (Read 8623 times)
Offline Dotnick
« on: Thu, 01 April 2021, 00:31:15 »
THOCK IT! JUMBOPAD
The Thock It! JumboPad is all about innovation with features and technologies never seen before in the keyboard hobby.
Featuring a GROUNDBREAKING ledge and weight design, plastic electroplated stainless-steel construction, next generation knob technology, NFC, and never before seen battery life, Thock It! is the ultimate gaming machine.
We spared no expense to create the best and most innovative user experience possible.
I really hope you enjoy this set and that you share your thoughts and feedback using the form below!
Interest Check Form
Discord server
Social Media
Renders
Features
2.05π rad typing slope
6mm front height (a new world record)
Full 8mm thick poron foam strips isolation gasket mount
Earthshatteringly innovative ledge and weight design
Polycarbonate foam bump-ons
Thock It! button will come built with a Razer Orange switch and a proprietary ring wire stabilizer lubed with Nyogel 760
Flick activates automated non fungible token bidding technology
Horn plays the entire Taeha Types' Mechanical Keyboard Sounds vinyl upon each twist
Pull toggles Lulzthax's jawline on and off
Spinnable wheel designed exclusively for Microsoft OneNote sidescroll
Leaf spring mounted rotary encoder technology
Tmk programmable button and encoder
Bluetooth 5.3
Optimized top right blocker
Stainless steel construction with plastic electroplating for a unique look
Full NFC compatibility
Integrated FTP server
Compatible with size 35 Duracell battery (battery not included)
Patent Pending #6942069420
Thanks
Equals for spending crunch time in Fusion making this fever dream come true
Empty for being curvy
Topy for slowly degenerating while we built this
Plop for plopping
Code: [Select]
[url=https://geekhack.org/index.php?topic=112026.0][img width=315 height=140]https://i.imgur.com/LBiZ9Ui.png[/img][/url]
« Last Edit: Thu, 01 April 2021, 01:22:32 by Dotnick »
Offline Bachoo
Re: [IC] Thock It! JumboPad
« Reply #1 on: Thu, 01 April 2021, 00:35:08 »
amazing
Offline sub0001
« Reply #2 on: Thu, 01 April 2021, 00:37:50 »
big fan of the front height and typing angle -- hoping this gets to GB!
Offline convoliution
« Reply #3 on: Thu, 01 April 2021, 00:38:45 »
Finally, an actually ergonomic rotary encoder. I'm in.
« Last Edit: Thu, 01 April 2021, 00:41:33 by convoliution »
Offline Nukz
  • ig: nukzak
« Reply #4 on: Thu, 01 April 2021, 00:39:42 »
im in
Offline P103
« Reply #5 on: Thu, 01 April 2021, 00:42:29 »
I need that token bidding technology now.
Offline The Equals D
« Reply #6 on: Thu, 01 April 2021, 00:43:35 »
The designer of this must be really innovative
Offline NathanAlphaMan
« Reply #7 on: Thu, 01 April 2021, 00:51:17 »
Hi Nick
Offline Rx003
« Reply #8 on: Thu, 01 April 2021, 00:52:28 »
Nostalgic
Offline TimKeyLess
    • Twitch
« Reply #9 on: Thu, 01 April 2021, 00:56:29 »
yes daddy
Offline whirlwind
« Reply #10 on: Thu, 01 April 2021, 01:02:27 »
I'll buy 5 million billion units
Offline Dotnick
« Reply #11 on: Thu, 01 April 2021, 01:44:27 »
Offline kimchijody
« Reply #12 on: Thu, 01 April 2021, 02:17:08 »
Nick you actual mad lad holy ****
Offline Sainity
« Reply #13 on: Thu, 01 April 2021, 02:23:09 »
This made my morning.
Offline see
« Reply #14 on: Thu, 01 April 2021, 02:45:24 »
wtf... not even lubed with carbon x69000 uranium titanium grease from the literal heavens? disappointment. will be passing this up.
Offline Dotnick
« Reply #15 on: Thu, 01 April 2021, 09:12:46 »
You want in on the 69 karat gold private gb version?
Offline iinko_mk
  • Status: broke
« Reply #16 on: Thu, 01 April 2021, 09:25:52 »
the **** only gets better they say, it will be good they say. Were they right?
fk yeah
Offline mTopy
« Reply #17 on: Thu, 01 April 2021, 09:39:09 »
Does it come with carbon fiber accents?
Offline Dotnick
« Reply #18 on: Thu, 01 April 2021, 18:26:13 »
no
Offline EdgeOfInfinity
« Reply #19 on: Fri, 02 April 2021, 00:28:34 »
add to cart!  ;D
Offline hottrout
  • I'd Hit Dat Key
« Reply #20 on: Fri, 02 April 2021, 03:56:37 »
Can you add UK ISO?
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
