Author Topic: [IC] KBM Blanks | Updated 5/11 | New Manufacturer!  (Read 111101 times)
Offline midknight
Re: [IC] GMK Blanks | Updated 5/12 | CMYK and RGB modifiers added!
« Reply #100 on: Sun, 06 June 2021, 14:30:33 »
imagine shinethrough windows kit... that would be instant cop
Offline titanium
« Reply #101 on: Mon, 07 June 2021, 22:15:13 »
IIRC, GMK charges 30-40% less for blanks than they do for doubleshot keycaps. This could have changed since my memory is from like 4 years ago a la GMK Mondrian but I think it should still be around that price.
I'm definitely in for a white and CMYK set no matter what though!
Offline Neely_12
« Reply #102 on: Tue, 08 June 2021, 00:34:23 »
Im really interested to see the pricing on this. Cant be that much less, but still it might be appealing enough.
Offline NovaRMK
Re: [IC] GMK Blanks | Updated 6/13 | Ergo kits added!
« Reply #103 on: Sun, 13 June 2021, 16:38:53 »
6/13
-Added ergo kits
-Minor kitting changes to base kits
-Updated renders
Offline TK0
« Reply #104 on: Tue, 15 June 2021, 20:22:05 »
Thanks for the ergo kits! :thumb:
However, since the caps are blank, almost all 1u needed for the ergo and some 1,5u keys are already available on the main kit. Maybe we should take advantage of that.
You will only have to add 13 keys to the main kit to support ergo boards, instead of having a separate ergo kit. Otherwise, ergo users will need to buy the main kit and the ergo kit, which will result in buying almost double of the keys actually needed.
If I counted correctly, the keys that need to be added are:
1x 1u R2
2x 1,5u R1
4x 1,5u R2
2x 1,5u R3
4x 2,0u R2
Offline NovaRMK
« Reply #105 on: Tue, 15 June 2021, 21:08:30 »
1x 1u R2
2x 1,5u R1
4x 1,5u R2
2x 1,5u R3
4x 2,0u R2
Thanks for the feedback! I'll be sure to take this under careful consideration, and this is probably what I'll end up doing.  :thumb:
Offline kizuna
« Reply #106 on: Tue, 15 June 2021, 21:18:05 »
very cool, thank you for putting this together!
Offline Learis
« Reply #107 on: Tue, 15 June 2021, 23:07:00 »
Hmm, wondering if it's possible for you to sell the split spacebar options by themselves. I have no need for blank keycaps except for my split spacebar, and split spacebar keycaps are really hard to find!
Mend and Defend
Offline NovaRMK
« Reply #108 on: Thu, 17 June 2021, 13:06:14 »
Hmm, I think what I'll end up doing is making the spacebars their own kits that way people can get them without having to buy the entire base kit.
Offline beigeandbrown
« Reply #109 on: Thu, 17 June 2021, 13:09:08 »
smh no f13  support
Offline NovaRMK
Offline Biotrin
« Reply #111 on: Thu, 24 June 2021, 10:47:40 »
Gimme
Offline Keeblet_257
« Reply #112 on: Thu, 24 June 2021, 12:58:13 »
is this gonna be the first gmk set sub 100?
Offline NovaRMK
« Reply #113 on: Thu, 24 June 2021, 14:49:53 »
Well, there have been sets like MoDo and Minimal that were $99.99 which is technically sub 100, but yes, it's more than likely that this will be the cheapest GMK set on the market
Offline scoopbb
« Reply #114 on: Thu, 24 June 2021, 22:45:54 »
ergo as separate kits for me. i dont want the base kits. i want ergo kits for minimal and wob.
also left feedback regarding the actual kiting for ergo. its missing support for a few other boards (boardwalk/boardrun, other ergo kits). mudbeam had a good ergo kit (just subtrack the accent bars).
Offline autocast
« Reply #115 on: Thu, 24 June 2021, 23:27:20 »
Keen for blanks made by GMK
« Last Edit: Thu, 12 May 2022, 01:04:11 by autocast »
Offline hottrout
  • I'd Hit Dat Key
« Reply #116 on: Fri, 25 June 2021, 04:03:53 »
Please add UK ISO and I will go in for BoB as well as the WoW set.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline HappyB0T
  • I'm a Piggie
« Reply #117 on: Fri, 25 June 2021, 11:21:48 »
WoW! made me laugh.
Offline NovaRMK
« Reply #118 on: Fri, 25 June 2021, 12:10:17 »
I hadn't thought about it like that. WoB/BoW sets could use these kits as an ergo extension, thanks for pointing this out. I'll probably keep these kits separate from the base kit.
Thanks for the input! I'll also be adding the missing keys to support the other boards
« Last Edit: Tue, 03 August 2021, 18:50:39 by NovaRMK »
Offline NovaRMK
« Reply #119 on: Fri, 25 June 2021, 12:18:55 »
/s  :p
Offline Mistah
« Reply #120 on: Wed, 30 June 2021, 14:15:02 »
Is there any way we could add an accent spacebar pack just like the accent r4 mod pack? Unsure if GMK does 1.5u convex, but I bet the ortho community would eat up small GMK bars, especially in stock colors to complement their sets.
Offline NovaRMK
Re: [IC] GMK Blanks | Updated 7/23 | Major Kitting Changes!
« Reply #121 on: Fri, 23 July 2021, 19:00:53 »
7/23
-Revised Ergo Kits
-Remove spacebars from base kit
-Added spacebars kit
-Added shinethrough keys to macro (now extension) kit
-Revised extension kit
Offline zRoze
« Reply #122 on: Sun, 25 July 2021, 18:44:19 »
I think this could be really great for just an alphas kit. Maybe consider alphas?
Offline mrvco
« Reply #123 on: Tue, 17 August 2021, 14:27:27 »
Sign me up.
Offline proskit
« Reply #124 on: Wed, 18 August 2021, 02:18:21 »
GMK always do nice work
Offline Grindbox
« Reply #125 on: Fri, 03 September 2021, 16:33:55 »
Thanks for adding the extra keys for the ergo clones!!  I'm in for at least one ergo kit!  I was bummed out that I missed the last blank GB.  Any idea what the GB timeline is looking like?
Offline NovaRMK
« Reply #126 on: Wed, 08 September 2021, 17:38:37 »
Sometime around the end of the year
Offline Grindbox
« Reply #127 on: Wed, 08 September 2021, 17:42:57 »
Aw yeah, I'll be back in a couple months to provide bumps and hype.  Thanks for the update!!
Offline baobaozi
Re: [IC] GMK Blanks | Updated 9/8 | Vendors Announced!
« Reply #128 on: Wed, 08 September 2021, 21:36:40 »
Nice! Since they're blanks, what kind of cap thickness are we looking at though? Since it'd be single shot?
I thought I read some people talking about some other runs of GMK blanks that they sound different and were lighter in mass than their double-shot counterparts.
Offline NovaRMK
« Reply #129 on: Thu, 09 September 2021, 06:53:05 »
From what I can tell, the doubleshots and the blanks are the same thickness (or very very close). It looks like on the doubleshots the outer shell is thinner to account for the inner mold adding thickness.
I don't know about the mass and sound difference, but I would imagine that yes, different mass keycaps would affect the sound. I don't have a scale percise enought to weight a blank vs a doubleshot, but it may be something I want to look into in the future.
Offline CustomerSupport
  • 🕸 developer
    • Discord
« Reply #130 on: Fri, 12 November 2021, 12:52:10 »
When?
Idk bro you tell me how soon you want it and I'll deliver <3 (no but seriously I might run this sh*t)
I want it now.
No, but seriously, is there a GB date in the works? Definitely interested in this :D
Offline Grindbox
« Reply #131 on: Fri, 12 November 2021, 23:51:56 »
When?
I want it now.
I am also ready to buy this.
Offline renderling
« Reply #132 on: Thu, 18 November 2021, 10:37:28 »
Just wanted to second this request for separate ergo kits. I'd much rather be able to buy the ergo kits to pair with other GMK kits that use CR/WS1 as the base color.
Offline MIGHTY CHICKEN
« Reply #133 on: Thu, 18 November 2021, 13:39:18 »
I am excited for this
Offline C0M9LEXM1ND
« Reply #134 on: Wed, 01 December 2021, 03:01:10 »
Nothing but oil baby!
Offline AuroraCamo
« Reply #135 on: Sat, 02 April 2022, 00:16:39 »
Bringing this back to the front page
Offline hvontres
  • Buckling Spring Enthusiast - Full Size Evangelist
Re: [IC] GMK Blanks | Updated 4/1 | GMK CR Base Kit Added!
« Reply #136 on: Sat, 02 April 2022, 01:51:51 »
Actual GMK Minimal
Any hiragana sublegends?
Only in the same color as the base key
Henry von Tresckow
1986 Model M 1390131, 1987 Model M 1391401 , 1993 Model M2 Modded Reddragon k556(Test Mule) Boston Prototype x2 (Daily Drivers :) )
Offline conternecticus
« Reply #137 on: Sat, 02 April 2022, 04:26:21 »
Offline ThreadyKeycaps
    • ThreadyKeycaps
« Reply #138 on: Sat, 02 April 2022, 04:53:47 »
Amazing!! Love the clean design, is like the legends have been cleaned off! I'll have fun with all the typos using this keycap set since I'm still getting used to my split keyboard  :))
Offline LMarci
« Reply #139 on: Fri, 08 April 2022, 05:26:05 »
It was me. I stole the legends  :thumb:
Offline WhiskyBoi99
« Reply #140 on: Sun, 17 April 2022, 05:11:44 »
Any artisans/collabs? Could do something fun with Salvun or HIBI?
Offline Tomson
« Reply #141 on: Tue, 19 April 2022, 07:11:59 »
Is this IC still alive?
Offline treeleaf64
    • treeleaf64
« Reply #142 on: Tue, 19 April 2022, 08:12:17 »
The treeleaf wants some Brown Blanks for his happy rug on the floor
Everyone must pay the cat tax
  • 🕸 developer
    • Discord
« Reply #143 on: Wed, 27 April 2022, 13:27:12 »
Same. Very interested in this!
Offline NovaRMK
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #145 on: Sun, 01 May 2022, 19:38:14 »
Indeed it is :)
Great news!
Strange though,  I asked my mom the other day and she had no idea.
Offline NovaRMK
« Reply #146 on: Mon, 02 May 2022, 20:28:38 »
Indeed it is :)
Great news!
I'm in your walls
Offline EdgeOfInfinity
« Reply #147 on: Tue, 10 May 2022, 11:49:40 »
yay - need blanks  :thumb:
Offline NovaRMK
Re: [IC] KBM Blanks | Updated 5/11 | New Manufacturer!
« Reply #148 on: Wed, 11 May 2022, 21:20:49 »
bump  ;)
Offline SDKCAMPING
« Reply #149 on: Wed, 11 May 2022, 21:36:44 »
To be fair I think the original appeal was to get to try GMK caps for cheaper, so switching over kind of changes the scope. Not  fan of it now being PBT but the colors are still pretty good so I might still try.
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
