Author Topic: Does a shorter TKL exist?  (Read 2397 times)
Offline g_hack_it
« on: Fri, 02 April 2021, 08:53:14 »
I'm trying to find board that's a cross between ikki68 and an exploded 75% layout. My main need/want is a full-sized shift-key + F-keys + semi-exploded arrow cluster in as small a package as possible. Does a layout like this exist and what would it be called?
If this doesn't exist, are there any programmable 68-key boards with similar layouts to ikki68 & saka 68 I should keep my eyes out for? I'm new and it seems I missed the boat on both GBs.
Attached screenshot of my current working ideal layout (although I don't care much about Insert & Print Screen).
Offline Sup
Re: Does a shorter TKL exist?
« Reply #1 on: Fri, 02 April 2021, 14:26:58 »
I think the ID80 comes the closest to what you want.
current
Coming soon
Offline g_hack_it
« Reply #2 on: Sun, 04 April 2021, 08:03:28 »
Yeah that and the gmmk pro come really close, it's just the right-shift key that holds me back at this point. However I'm working on normal/non-exploded 75% board right now and it's gotten a lot easier since switching from XDA to KAT keycaps. So maybe by the time I'm ready to pull the trigger on a new board, I won't care anymore.
Sent from my LM-V600 using Tapatalk
Offline Aritega
    • Art by ringo
« Reply #3 on: Sun, 04 April 2021, 10:53:52 »
You might like the Returned Wing! The f row isn't exploded but it's close enough to what you want. https://geekhack.org/index.php?topic=106227.0
(Note that you get more updates and info from their discord. They don't use geekhack often, unfortunately.)
https://discord.gg/yP6GA9Ebdz
« Last Edit: Sun, 04 April 2021, 11:03:49 by Aritega »
Offline g_hack_it
« Reply #4 on: Sun, 04 April 2021, 19:33:10 »
Oh nice! This is super close, thank you!
