Author Topic: [IC] Awoo Switches  (Read 6586 times)
Offline Nutty
    • Twitch
[IC] Awoo Switches
« on: Fri, 02 April 2021, 21:54:44 »
Hello Geekhack!
Nutty/Jordan here again! I would like to introduce a project that goes along with my current keyset, GMK Harvest:
Awoo Switches
These switches will JWK linear switches with a 63.5g spring.
The material of the switches will be composed of a PC top and a Nylon bottom with a POM stem.
They will come unlubed.
There will also be some accompanying stabilizers in a recolor of the Durock v2's. (render shows a v1)
Thank you Pupper for these renders.
Please fill out my IC Form to help me gauge interest as well as for any criticism, changes, suggestions, or feedback.
Additionally, if you're interested, I do have a Discord if you join, just go into the rules and roles and react to the keyboard role.
GB Dates, Vendors, and Pricing
Date TBD
Vendor Keyspresso
Price TBD
« Last Edit: Tue, 13 April 2021, 16:38:17 by Nutty »
Offline of_sam
Re: [IC] Awoo Switches
« Reply #1 on: Fri, 02 April 2021, 21:55:47 »
Why not just add this to your IC instead of clogging geekhack with more JWK?
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline Nutty
    • Twitch
« Reply #2 on: Fri, 02 April 2021, 21:57:18 »
I assumed it was the correct thing to do as it would have a different GB date and potentially not all the same vendors, depending on how its run. My mistake if this wasn't the proper etiquette.
Offline yoot
    • none
« Reply #3 on: Fri, 02 April 2021, 22:00:29 »
please don't make them factory lubed
Offline doggo1dance
« Reply #4 on: Fri, 02 April 2021, 22:01:04 »
why not just let him do what he wants? is it gonna kill you if he does that?
Offline shima
  • keeb weeb
« Reply #5 on: Fri, 02 April 2021, 22:06:08 »
2 diff IC posts?
boards: anura
Offline NSkeptic
« Reply #6 on: Fri, 02 April 2021, 22:35:55 »
This looks great! I'm interested.
Offline Anthixious
« Reply #7 on: Sat, 03 April 2021, 02:47:51 »
Are you sure these are v2 stabs? These don't look like v2, I don't see the singular lip coming up from the back to hug the wire.
Offline Anthixious
« Reply #8 on: Sat, 03 April 2021, 02:48:35 »
Great-looking switches otherwise, reminds me of Noctua and caramel apples.
Offline Sissy
« Reply #9 on: Sat, 03 April 2021, 03:00:56 »
I believe they just use V1 rendering since there isn't one for v2.
Offline Anthixious
« Reply #10 on: Sat, 03 April 2021, 03:54:29 »
Ah gotcha, really? Never knew.
Offline Nutty
    • Twitch
« Reply #11 on: Sat, 03 April 2021, 07:20:40 »
I didn’t even think of that haha.
I apologize for that mistake, it is supposed to be v2’s this is the v1’s in the renders I now notice. I’m going to try and get that settled. Thanks for bringing this to my attention.
Offline Zanhana
« Reply #12 on: Sat, 03 April 2021, 09:01:29 »
if there's one thing the world doesn't already have enough of, it's standard-issue JWK PC top, nylon bottom, 63.5g linear recolors
Offline Chippy
  • sus chef
« Reply #13 on: Sat, 03 April 2021, 13:52:45 »
I feel like this is better suited to be on your gmk set IC, since it is just another jwk recolor
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline lush_bunny
« Reply #14 on: Tue, 06 April 2021, 17:35:20 »
Which JWK linear will Awoo be cloned from? I wasn't particularly impressed with L7 Durock linears, but I've heard nothing but good things about Alpacas and Lavenders.
Offline Nutty
    • Twitch
« Reply #15 on: Tue, 13 April 2021, 16:40:13 »
Update.
These will be unlubed switches.
I was told will be similar to Durock Linear Moss switches.
Currently waiting on a Pantone color deck as the manufacture prefers to work with Pantone so I will have to match RAL colors to Pantone now.
With that color matching in play, I should be receiving sample switch, so when the time comes I should be able to better judge the matching from Pantone to RAL.
