Author Topic: [IC] Smoothie Split 40% Keyboard  (Read 8961 times)
Offline meatsmoothies
  • howdy!
    • portfolio / store
« on: Mon, 05 April 2021, 13:49:58 »
Howdy! Inspired by a love of uniform stagger and lack of keycap compatibility, the smoothie split is a board for people that know what they want out of their layout. 40 keys, split layout, and large corner blockers will make you the talk of the town as they ask how you type numbers or use the ctrl key.
This IC is moreso to check if there's more interest in a larger format GB, or limited run of in stock boards.
IC FORM
Features:
> Fully assembled PCB
> USB-C
> C to C
> Fixed layout
Layout is below, as well as some pictures. Buy will be run through P3D and pricing is TBA!
3D Printed Proto Photos - can PCBS for buy will be white with black silks ( purple may be an option if interest is expressed )
Bottom acrylic panel can also be cut in different colors
Offline Bub
    • big bub's beepers
Re: [IC] Smoothie Split 40% Keyboard
« Reply #1 on: Mon, 05 April 2021, 13:50:09 »
reserved
can you photograph the usb cutouts?
(this is neat and if it were cheaper i would def consider)
« Last Edit: Mon, 05 April 2021, 13:55:51 by Bub »
Offline Pontus
« Reply #2 on: Mon, 05 April 2021, 13:51:47 »
I like this. It's very cute
Offline BapoDonu
« Reply #3 on: Mon, 05 April 2021, 13:52:10 »
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #4 on: Mon, 05 April 2021, 14:42:55 »
how do you type numbers
Offline dingusxmcgee
« Reply #5 on: Mon, 05 April 2021, 14:46:16 »
You don’t and neither do I.
You’re not my dad.
Offline frostykoala
  • consider Nightlight
    • Check out some Renders :)
« Reply #6 on: Mon, 05 April 2021, 14:52:56 »
i like the vanilla bean case, will def keep up with this and can't wait
Offline FishyKeebs
  • hey
« Reply #7 on: Mon, 05 April 2021, 15:22:12 »
Very cool! I would get it if it were cheaper like bub said
Offline MelonBred
« Reply #8 on: Tue, 06 April 2021, 22:38:55 »
Stoked! been waiting for this to come up.
Offline citrusfruit
« Reply #9 on: Thu, 08 April 2021, 07:33:03 »
Looking forward to this! Will you join the 40% discord so that we can get live updates etc.?
𝕔𝕚𝕥𝕣𝕦𝕤 (●´ω`●)ゞ
  • howdy!
    • portfolio / store
« Reply #10 on: Thu, 08 April 2021, 13:08:35 »
Live updates will most likely occur in the P3D channel as that's who the vendor will be!
  • howdy!
    • portfolio / store
« Reply #11 on: Thu, 08 April 2021, 13:12:48 »
reserved
Still not sure on pricing but the usb cutouts can be seen on the 3d view here ! :)
Offline Etmost
« Reply #12 on: Sun, 11 April 2021, 10:19:10 »
This is so cool!
Looking forward to hear updates about it.
Offline minicap
« Reply #13 on: Sun, 11 April 2021, 15:41:44 »
Love the shape! Excited to see where this goes :D
Offline matthewdias
« Reply #14 on: Sun, 11 April 2021, 22:34:32 »
please just let me buy this already
Offline Heist Morty
  • MD.Doof
    • Mascis Designs
« Reply #15 on: Wed, 02 June 2021, 16:46:58 »
^ this please
