Author Topic: [GB] Jelly Epoch - boing boing 75%  (Read 59220 times)
Offline OwLab
« on: Fri, 09 April 2021, 20:05:32 »
IC here
266247-0
266249-1
266251-2
266253-3
266255-4
266257-5
266259-6
266263-7
Date&Time&Places:
product page won't be up online until the time of the sale
Popkeyboard.com (Africa, Antarctica, Asia, Oceania, Europe, North America, and South America except SEA or KR) 3pm PDT on the 17th of April
zionstudios.ph (South East Asia ONLY) 1pm PHST or UTC+8 on the 18th of April
swagkey.com (Korea ONLY) 8pm KST on the 18th of April
Format:
REGION LOCKED First come first serve
(region lock meaning Popkeyboard.com sale won't ship to SEA or KR and vise versa)
Payment method:
on Popkeyboard.com (except SEA or KR) ⇒ Visa, MasterCard and PayPal
You won't be able save your payment info in advance on our website if you are not using PayPal
KR and SEA ⇒ Zion and Swagkeys support
Units:
700(including Special Edition), in-stock (additional 150 for Zion and extra 50 for Swagkeys)
Limit:
one per order and one per household
PCB:
Hotswap or solder, QMK&VIA powered, no switch LED
Daughterboard:
USB type-c (supporting c-to-c cable) and LED ambient light strip
Plate:
PC included, alu as extra
Foam:
case foam and pcb foams are included
Weight:
brass, PVD clear coated for regular version
mysterious coating and color for SE
Color:
DewDrop, Ruby, Navy, Ink and Sage
1. we won't disclose quantity of each to help extra premium in after market
2. top and bottom cases are the same color; mid cases are grey for all colorways
Size:
327x145x39mm, front height 22mm
Typing angle:
7 degrees
Mass:
the weight itself is 1.5kg and total weight is 2.2kg unbuilt, 2.6kg built
Price:
USD$389 for Ruby, Navy, Ink and Sage
USD$399 for DewDrop (electrophoresed)
USD$429 for SE
Layout:
hotswap - standard ANSI + 1.75u shift + stepped cap compatible; solder - ANSI, stepped cap, ISO and split backspace
Shipping out:
within one month
you will receive tracking number via email
SE:
It’s within the 900 units we have internationally. It has a special finish on the SS weight.
The case is in one of the 5 colors (not every SE is in the same color)
content list:
solder version
 - solder pcb x1
 - solder pc plate x1
 - pre-assembled case x1 (including top, mid and bottom cases, weight, diffuser, LED/USB daughterboard, multiple screws, bump-ons and weight Anti-slips)
 - stab shims/washers (our pcb is thinner that regular ones)
 - JST cable for daughterboard
 - Jelly gaskets x8
 - dual-layer pcb foams (recommended but optional in building)
 - case foam (recommended but optional in building)
hotswap version
 - swap pcb and plate to hotswap version
 - one more set of standoffs and screws (optional in building)
 - others the same as the solder version
extras (will be made after sale):
ordering these will impact your shipping out time
- alu hotswap plate $19
- alu solder plate $19
- PC hotswap plate $19
- PC solder plate $19
- hotswap pcb $39
- solder pcb $39
- PCB poron foam $6
- PCB PE foam $3
- Case foam $6
Please join our Discord server for the latest about the sale.
« Last Edit: Sat, 17 April 2021, 12:13:03 by OwLab »
Offline OwLab
Re: [GB] Jelly Epoch - boing boing 75%
« Reply #1 on: Fri, 09 April 2021, 20:05:45 »
FAQs (updating)
- where are the rest streams?
Minterly's Sage unit is scheduled at 16th
Apiary's Ruby unit is scheduled at 14th
MechMerlin's DewDrop unit is scheduled at 15th
- why only 900 units?
It's in-stock and we have invested at max budget months ahead
The hype is totally unexpected
We have other projects incoming this year so we can't add more units without causing a delay
- what is electrophoresis?
it's a coloring technique and it's not as rigid as anodization
- how to purchase extra pcb and plate?
you will be able to add them into cart 1 day before the sale from other product pages
if they are sold-out, extras will be removed from the cart
if Jelly is sold out earlier, your extras-only order will be cancelled
we don't provide order alteration after the order is in
i.e. no change, no cancellation, no addition or refund
- difference between hotswap plate and solder plate?
if you have hotswap plate, you are locked into ANSI layout
so even if you purchase a solder PCB, you won't be able to use ISO and tsangan or split b/s, only stepped capslock and ANSI
also, we will only provide standoffs to hotswap keyboards but not extra plates and pcbs
there won't be holes on the solder plate so you won't be able to use those standoffs
hence, don't get hotswap version and solder extra plate if you don't understand the limits here
- switch count?
81 switches are needed for the hotswap version. For solder, up to 85.
- I don't see the page? where to purchase?
the product page goes live at the time of the sale
- estimation of hype? how long will it take to sell out?
we don't know any other than that most people won't be able to get a unit
just be there a few minutes when the sale happens
- what else do I need to do?
check our Acceptable Quality Standards on our website
no returns, if you have faulty parts, we'll send you the replacements of them
« Last Edit: Wed, 14 April 2021, 19:16:24 by OwLab »
Offline Rubbermilitia
« Reply #2 on: Fri, 09 April 2021, 21:12:14 »
Yes please....
Offline Altain
  • Formerly zungzangbi
« Reply #3 on: Fri, 09 April 2021, 21:20:25 »
I'm sold!
Offline OwLab
« Reply #4 on: Fri, 09 April 2021, 22:32:56 »
« Reply #5 on: Fri, 09 April 2021, 22:47:12 »
Is there a pic of the Ink and Navy straight on like the red, green and beige?
Offline OwLab
« Reply #6 on: Fri, 09 April 2021, 23:16:24 »
no unfortunately Ink and Navy samples are in the hands of Alex and Andy.
You can check their streams in the previous IC post I made.
Offline glenntmm
« Reply #7 on: Mon, 12 April 2021, 01:29:54 »
interested, what's the material used for the case outside of the weight? I believe it's not all cnc'd alu right?
Offline Altain
« Reply #8 on: Mon, 12 April 2021, 03:18:38 »
I believe, according to their Jelly IC page, that the only parts that are not aluminum in stock configuration are their PC plate, Brass weight and Gaskets.
Offline UGunaLOSE
« Reply #9 on: Mon, 12 April 2021, 08:12:48 »
Absolutely love the sound of this board (based on sound test videos). GLWGB!!
Offline OwLab
« Reply #10 on: Mon, 12 April 2021, 11:59:55 »
thank you very much!
it's a limited stock sale btw
Offline OwLab
« Reply #11 on: Mon, 12 April 2021, 12:00:55 »
and some accessories too :)
thanks for your help
Offline DaftFiction
« Reply #12 on: Sat, 17 April 2021, 17:12:01 »
Well I tried to get one at least
Offline DutchMatrix558
« Reply #13 on: Sat, 17 April 2021, 17:55:17 »
I got one! I can't believe I got one!
I'm sorry, I am not trying to brag, but I never have any luck with these sorts of group buys. I always miss out. But this time, woo-hoo!
Offline rangda
« Reply #14 on: Sat, 17 April 2021, 19:22:58 »
People were already posting screen grabs of purchases before the site would even show me the board as being available.  Never had a chance.
« Reply #15 on: Sat, 17 April 2021, 19:30:44 »
I got all the way to selecting shipping and then it sold out. So damn disappointed...
Offline SwitchKeys
    • SwitchKeys
« Reply #16 on: Sat, 17 April 2021, 21:21:30 »
Smashed it guys. Well done on the successful run!
Offline OwLab
« Reply #17 on: Sat, 17 April 2021, 21:43:10 »
700 is a lot ig
Offline OwLab
« Reply #18 on: Sat, 17 April 2021, 21:43:43 »
Offline Techdude594
« Reply #19 on: Sat, 17 April 2021, 22:14:05 »
Managed to snag one! This sale went well, lasted longer than expected! Well done on the run Owlabs! :D
Offline dimo
« Reply #20 on: Sun, 18 April 2021, 02:43:36 »
how many minutes did it sell out in? just curious, these comments seem a bit contradicting
« Last Edit: Sun, 18 April 2021, 06:29:32 by dimo »
Offline OwLab
« Reply #21 on: Sun, 18 April 2021, 10:25:39 »
less than 2
Offline OwLab
« Reply #22 on: Sun, 18 April 2021, 10:26:03 »
yeah we expected seconds
Offline rangda
« Reply #23 on: Sun, 18 April 2021, 19:21:08 »
I think the only reason it lasted as long as it did was because people were queued for checkout.  I sat in the checkout queue for a good couple of minutes before it came back as sold out (and I was in such a rush to buy I didn't even notice until after I checked out what ended up being a pcb only order).  If not for that it probably would have been seconds.
Offline OwLab
« Reply #24 on: Tue, 20 April 2021, 15:03:45 »
sorry about that - we'll definitely consider gb after in-stock for our next project.
Offline oliboy
« Reply #25 on: Tue, 20 April 2021, 19:51:31 »
Also since your projects are pretty awesome and have a lot of hype around them. Maybe you should choose vendors with servers that can handle the incoming load. The SEA group buy was the worst experience I've ever had on a group buy.
« Last Edit: Tue, 20 April 2021, 19:53:12 by oliboy »
Offline rangda
« Reply #26 on: Tue, 20 April 2021, 21:24:17 »
I don't fault you for not getting one, it's to be expected when a FCFS sale is done.  I am disappointed.  The acoustics of the board generated a lot of hype, and clearly the market is heavily under-served if you can blow through 700 $400 keyboards (that's over a quarter million dollars) in < 2 minutes.
I knew I was screwed right off, people were posting screen grabs of checkouts and the web site was still not showing me a buy link.  I'm sure by the time it finally refreshed to show me an add to cart it was too late.
Offline Broxigar
« Reply #27 on: Sat, 24 April 2021, 10:49:23 »
Thank you for considering a GB. I think for this board, it's extremely needed and warranted.
The FCFS is only great when the demand is not there but it's absolutely terrible when the demand is extremely high. FCFS becomes more of a game of RNG.
I logged on like many users 30-40 min prior and spammed F5 for the page to refresh when that clock hits, added the color of choosing and sat in queue. Unfortunately, I chose the color that most in the front of the queue picked as well so it got deleted during shipping portion. By the time I was able to add another color and went back in the queue, that color was also taken. By the time to my 3rd try, everything was sold out.
For the next FCFS, I would recommend that you guys consider:
1. Add a 'any color' button. So that we may just get any color that's that still the highest availability. This gives the customer better chances to grabbing a board who were there in the queue.
2. Do a raffle in queue like CannonKeys and not lose position if their color selection were first sold out.
3. Include a GB option in the website during release for those who were not fortunate enough one quickly. Their orders will auto convert into a GB.
Thank you Owlab for producing such great quality products. It's not your fault that you guys are so hot right now and in demand. I'm very happy for your company and the way things are going. But please do consider better ways of serving the community.
Offline OwLab
« Reply #28 on: Sat, 24 April 2021, 10:56:03 »
We think an unlimited gb would be the best cure.
I'll send your suggestions to the team.
Deeply appreciated for your suggestions.
Offline DannyK570
« Reply #29 on: Sat, 24 April 2021, 11:17:43 »
Just move on people. It was a FCFS and it's all about how fast you are and add some luck in it. You win some and ofc you gonna take fat Ls on some. There will always be more keyboard out there waiting for you.
Offline Broxigar
« Reply #30 on: Mon, 26 April 2021, 17:19:28 »
[/quote]
Unlimited GB would be amazing for so many people that missed out. Sign me up.
Appreciate you taking feedback and actually caring to respond. You guys are the best.
Offline dkFreeze
« Reply #31 on: Tue, 27 April 2021, 01:40:29 »
I would greatly appreciate a GB if it is being considered, especially because your boards are so unique. It might even help with some of the scalpers/flippers for the epoch. Of course, it's your decision to have a post-FCFS GB for this board or to do it for the next project.
Offline OwLab
« Reply #32 on: Tue, 27 April 2021, 14:50:54 »
[/quote]
don't get me wrong tho - we'll consider gb for the projects to come, not Jelly
Offline OwLab
« Reply #33 on: Tue, 27 April 2021, 14:52:51 »
for the future projects - sorry for the confusion
Offline Broxigar
« Reply #34 on: Tue, 27 April 2021, 15:12:55 »
Thank you for clarifying. It was confusing when unlimited GB was being considered in a Jelly Epoch post. I got excited there for a bit when I saw the possibility in the future.
What you really meant was unlimited GB is being considered ONLY for future releases. However, Jelly Epoch is not planned to be released again. Would this be an accurate statement?
« Last Edit: Tue, 27 April 2021, 15:22:41 by Broxigar »
Offline OwLab
« Reply #35 on: Tue, 27 April 2021, 20:13:18 »
yes. "Unlimited GB" was just me answering a comment saying FCFS isn't enough for a good project like Jelly Epoch.
It does not mean that we are offering the form of group buy anytime soon.
No additional sale of Jelly Epoch is in consideration at this moment.
Offline UGunaLOSE
« Reply #36 on: Wed, 28 April 2021, 07:45:01 »
OwLab
Congrats on the board. Well deserved win for a well designed board!!!
Offline OwLab
« Reply #37 on: Wed, 28 April 2021, 12:45:00 »
OwLab
Thank you very much! I'll pass on the appreciation to our team members.
Offline treeleaf64
    • treeleaf64
« Reply #38 on: Wed, 28 April 2021, 15:00:13 »
That is a lot of units and there is also a very nice green color
Everyone must pay the cat tax
Offline toro428
« Reply #39 on: Tue, 25 May 2021, 07:39:05 »
Can't believe I missed this, is there any possibilities for another run?
Offline OwLab
« Reply #40 on: Tue, 25 May 2021, 15:06:51 »
not planned at this moment
sorry about that
Offline Inoghami
« Reply #41 on: Tue, 10 August 2021, 08:47:23 »
We need a R2 of the jelly epoch! :D
Offline solomonshv
« Reply #42 on: Tue, 10 August 2021, 13:58:18 »
i want a jelly too. unfortunately i had to work during the drop and i don't want to reward the scalpers out of principal.
 i know doing in stock sales is a big investment so i would definitely jump on a group buy if that's what it takes to make it happen. i'm sure many people will.
Keebs::: Bok.CP - Antique Copper | Keycult No.2/65 Black/Brass | Keycult No.2 Rev 1 Grey/Brass | Jane V2 CE - Black/Multicolor | J-01 Rev1 - Blue | Haus - Silver | Kohaku - Red | OwLab Jelly Epoch - Ruby SE & Popcorn | KBD8X MKII WKL - Black PC | Ayleen WKL - Gin
Caps::: GMK Modo, GMK Jamon, GMK Olive, GMK Mizu, GMK Olivia++, GMK Bingsu, GMK Analog Dreams, GMK Botanical, GMK Moondust, GMK Taro R2, GMK Hennessey, GMK Serika R2, GMK Birch, GMK Tuzi, GMK Red Alert, GMK Zooted, GMK Hazakura, GMK Cyrillic Beige, GMK Lavender, GMK Daifuku, GMK November Fog, GMK Villanelle, GMK Blossom, DCS 9009 WYSE Alps
On order: GMK Tiramisu, GMK Maroon, GMK Bordeaux, GMK Taiga
