Author Topic: [CLOSED][GB] Selfjoking Novelty keycap  (Read 7651 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Fri, 16 April 2021, 03:25:54 »
Novelty Self-joking keycap
A figure is inspired by Chinese Internal slang - 小丑竟是我自己 (Myself is the joker).
It is a kind of self-mocking expression. Originally, it depicts the treachery of a man or a woman in a relationship.  You could use it in a situation like that you tell a funny story with your intimates or friends, however, you finally get aware that it is you are the hero of your funny story. Then you could say, Myself is the joker.
Resin, hand painted
MX stem compatible
Groupbuy ended on 6th May
Estimated delivery in mid of July
purchase
« Last Edit: Sun, 16 May 2021, 02:11:55 by KPrepublic »
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: [GB] Selfjoking Novelty keycap
« Reply #1 on: Fri, 16 April 2021, 03:26:52 »
