Author Topic: [IC] GMK Maroon | GB March 28th!  (Read 169189 times)
Offline Banned
« on: Sat, 17 April 2021, 17:10:57 »
GB Thread Here!
I was inspired by deep red and purple, and I wanted to make a clean, simple mono set that had a splash of color, and that's why I chose to make this set!
Colors
Color Comparison
Kits
Base Kit
Alt Alphas
Spacebars
Renders
Colors may not be fully accurate, and are merely to provide an idea of what it may look like. The kitting renders are the most color accurate, while the board renders use different lighting to imitate real life lighting setups
Beak 6.5 by Stilou Studio
TMO v2 by Funderburker
TGR Alice by Yuktsi
Dalco 959 Mini by DalexSnail
Deskmats
Bird (Huge thanks to mooN for designing this one! Inspired by the maroon colored Pompadour Cotinga)
Topo
Wave
Deskmat samples should arrive soon!
Topo and Wave deskmats are a collaboration with BobaSweatandTears
Collabs
Asero Foundry: Metal Cap and Keyboard
Miroticaps: Resin Cap
Hibi.MX: Metal Cap (Pudding)
Vendors
EU: MyKeyboard
UK: Prototypist
CA: DeskHero
NA: Vala Supply
Asia: zFrontier
SEA: Pantheonkeys
OCE: Switchkeys
Pricing
Contact
Discord: banned // gmk maroon#3665
Gmail: bannedmkb@gmail.com
Special shoutouts to
LittleAad for all of the support from the very beginning, as well as inspiring me to make this set in the first place.
Swishy, Acitrin, and Honorless  for all the help with my kitting.
Dudeship, and Iinko for the help with my renders.
And everyone else who helped me along the way <333
GMK Maroon discord: https://discord.gg/yYvJWUczbR
If you want to support this project, please consider adding the following to your signature:
Code: [Select]
[url=https://geekhack.org/index.php?topic=112349.0][img]https://i.imgur.com/yE8zST7.png[/img][/url]
« Last Edit: Fri, 15 April 2022, 12:33:12 by Banned »
Offline Banned
Re: [IC] GMK Maroon
« Reply #1 on: Sat, 17 April 2021, 17:13:44 »
Changelog
  • 4/18/21: Changed accents to GMK WS1
  • 4/20/21: Added Iron165 renders
  • 4/27/21: All vendors finalized, color comparisons added
  • 5/22/21: Deskmats added, IC form updated
« Last Edit: Mon, 24 May 2021, 21:09:29 by Banned »
Offline NovaRMK
Re: [IC] GMK Maroon
« Reply #2 on: Sat, 17 April 2021, 17:15:35 »
Petition for white accents instead of black
Offline Buburoo
Re: [IC] GMK Maroon
« Reply #3 on: Sat, 17 April 2021, 17:16:01 »
Reminds me of my primary school uniform. GLWIC.
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
Re: [IC] GMK Maroon
« Reply #4 on: Sat, 17 April 2021, 17:18:11 »
Good luck Banned :)
Offline Banned
Re: [IC] GMK Maroon
« Reply #5 on: Sat, 17 April 2021, 17:20:40 »
I originally had that, but switched to a darker accent. If enough people want it I'll change it!
Offline Banned
Re: [IC] GMK Maroon
« Reply #6 on: Sat, 17 April 2021, 17:22:41 »
Good luck Banned :)
Offline kure_
Re: [IC] GMK Maroon
« Reply #7 on: Sat, 17 April 2021, 17:38:30 »
cool set.
Offline n.mande
Re: [IC] GMK Maroon
« Reply #8 on: Sat, 17 April 2021, 18:57:17 »
I require a Canadian vendor plz.
Offline totalemon
  • good morning :)
Re: [IC] GMK Maroon
« Reply #9 on: Sat, 17 April 2021, 19:03:16 »
Definitely like the idea of white accents a little more. This is a pretty cool set! Reminds me of something but I'm not sure what
Offline Banned
Re: [IC] GMK Maroon
« Reply #10 on: Sat, 17 April 2021, 19:04:37 »
Offline Banned
Re: [IC] GMK Maroon
« Reply #11 on: Sat, 17 April 2021, 19:08:52 »
I may end up changing to white accents as it seems like many people want it.
Offline dimo
[IC] GMK Maroon
« Reply #12 on: Sat, 17 April 2021, 19:18:43 »
somewhere between the bingsu mods and alphas. might be nice to render a comparison versus some of the other similiar purple sets
Offline Banned
Re: [IC] GMK Maroon
« Reply #13 on: Sat, 17 April 2021, 19:39:59 »
Will do. I'll do burgundy, Jamon, and Bingsu for it
Offline dimo
Re: [IC] GMK Maroon
« Reply #14 on: Sat, 17 April 2021, 19:56:55 »
i would add full alpha + mod gmk VOC as that’s what looks very familiar to me.
also phantom, although the colors of the set in real life resemble this more than the original renders did.
Offline Banned
Re: [IC] GMK Maroon
« Reply #15 on: Sat, 17 April 2021, 19:58:15 »
Alright, will have that up tomorrow
Offline Bachoo
Re: [IC] GMK Maroon
« Reply #16 on: Sat, 17 April 2021, 20:39:12 »
Well done, I second the opinion that white should be the accent color.
Offline ab042896
Re: [IC] GMK Maroon
« Reply #17 on: Sat, 17 April 2021, 20:58:01 »
put me down for the dark grey accents  :thumb:
Offline Banned
Re: [IC] GMK Maroon
« Reply #18 on: Sat, 17 April 2021, 21:14:12 »
Please respond to IC form and tell me which you want!
Offline Coby
Re: [IC] GMK Maroon
« Reply #19 on: Sat, 17 April 2021, 21:18:42 »
 Looking awesome, try to see if you can add arrow accents  :D, white accents would look awesome but I think that it might resemble to bingsu a bit but quite frankly would look pretty lit ngl, GLWIC BROTHA  :thumb:
Offline armintehgreat
Re: [IC] GMK Maroon
« Reply #20 on: Sat, 17 April 2021, 21:19:44 »
Looks good, I enjoy this kitting  :thumb:
Offline Banned
Re: [IC] GMK Maroon
« Reply #21 on: Sat, 17 April 2021, 21:23:28 »
Yeah it's untraditional but pretty cool
Offline Banned
Re: [IC] GMK Maroon
« Reply #22 on: Sat, 17 April 2021, 21:24:19 »
Ty! Looks like accents are turning white
Offline vheissu
  • Pragmatic Geometrist
Re: [IC] GMK Maroon
« Reply #23 on: Sat, 17 April 2021, 21:31:18 »
Can you render it on a plum Iron165?
Offline Baka Bot
Re: [IC] GMK Maroon
« Reply #24 on: Sat, 17 April 2021, 21:34:05 »
Ne Maroon lovers avail? (i like this)
Offline Banned
Re: [IC] GMK Maroon
« Reply #25 on: Sat, 17 April 2021, 21:37:38 »
I can do that.
Offline lush_bunny
Re: [IC] GMK Maroon
« Reply #26 on: Sat, 17 April 2021, 21:46:28 »
I have too many monochrome sets, but I am so tempted by this. Btw I think White/Light accents might suit this set better. GLWIC!
Offline chewnior
Re: [IC] GMK Maroon
« Reply #27 on: Sat, 17 April 2021, 22:06:32 »
Looks really good, I also think the white accents would look nice. GLWIC  :thumb:
Offline Banned
Re: [IC] GMK Maroon
« Reply #28 on: Sat, 17 April 2021, 22:23:53 »
Yep, changing that for sure!
« Last Edit: Sat, 17 April 2021, 22:40:58 by Banned »
Offline LittleAad
  • Hello
Re: [IC] GMK Maroon
« Reply #29 on: Sat, 17 April 2021, 22:45:08 »
This is awesome, glad to see it. Glwic!
Offline Banned
Re: [IC] GMK Maroon
« Reply #30 on: Sat, 17 April 2021, 23:06:13 »
kekthumb
Offline darthcapn
Re: [IC] GMK Maroon
« Reply #31 on: Sat, 17 April 2021, 23:13:06 »
Hawt keyset!!
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline Banned
Re: [IC] GMK Maroon
« Reply #32 on: Sun, 18 April 2021, 00:13:31 »
Hawt keyset!!
TY!!
Offline beigeandbrown
Re: [IC] GMK Maroon
« Reply #33 on: Sun, 18 April 2021, 01:14:19 »
gmk gig 'em.  I love how purple it is, really unique color.
Offline RogueArchitect
Re: [IC] GMK Maroon
« Reply #34 on: Sun, 18 April 2021, 01:24:16 »
Absolutely love this!  Would love to see some white alphas with maroon legends as a kit.
Offline Banned
Re: [IC] GMK Maroon
« Reply #35 on: Sun, 18 April 2021, 01:52:09 »
I'm down to make an alt kit if I get enough interest
Offline Poesjuh
[IC] GMK Maroon
« Reply #36 on: Sun, 18 April 2021, 03:50:50 »
Ooo, very nice! I like it :D
*small edit; I do notice a lot of differences between the various renders. Which one would you say is the closest to the color? The ones from Vulcan especially are completely different.
« Last Edit: Sun, 18 April 2021, 03:53:15 by Poesjuh »
Offline Banned
Re: [IC] GMK Maroon
« Reply #37 on: Sun, 18 April 2021, 03:54:39 »
As said above, the base kit renders are the closest to accurate. I did mess around with different lighting scenes to imitate different light sources irl
Offline Poesjuh
Re: [IC] GMK Maroon
« Reply #38 on: Sun, 18 April 2021, 04:04:00 »
I’m blind, forgive me. I’ll go hide in the corner now.
Offline Banned
Re: [IC] GMK Maroon
« Reply #39 on: Sun, 18 April 2021, 04:07:34 »
Haha, don't worry about it
Offline roguesystem087
Re: [IC] GMK Maroon
« Reply #40 on: Sun, 18 April 2021, 06:13:42 »
yea white accents would be pretty dope!!!
Offline darthcapn
Re: [IC] GMK Maroon
« Reply #41 on: Sun, 18 April 2021, 12:05:49 »
Oh **** yes, white accent would be kick ass
Offline Cylent
  • Formerly cylentshadows
Re: [IC] GMK Maroon
« Reply #42 on: Sun, 18 April 2021, 12:29:12 »
Ay, much improved from some of the OG renders and color ideas, GLWIC fam
Offline Banned
Re: [IC] GMK Maroon
« Reply #43 on: Sun, 18 April 2021, 13:09:23 »
For sure. Putting up white accents soon.
Offline Banned
Re: [IC] GMK Maroon
« Reply #44 on: Sun, 18 April 2021, 14:50:37 »
White accents look good! Uploading soon once render finishes
Offline Banned
Re: [IC] GMK Maroon | Accents Updated
« Reply #45 on: Sun, 18 April 2021, 19:22:49 »
Accents are now changed!
Offline honorless
« Reply #46 on: Sun, 18 April 2021, 19:41:29 »
whew! not only do the white accents look DOPE, removing the third color should drop the cost of the base kit. stroke of brilliance IMO.
Am very curious how the pricing on this turns out. You already know I'm down...
Offline Banned
« Reply #47 on: Sun, 18 April 2021, 19:52:25 »
Haha, yeah. Definitely hoping for sub 120 base but that might be unreasonable lol
Offline darthcapn
« Reply #48 on: Sun, 18 April 2021, 21:06:14 »
Gosh white accents look so good. I am totally down for this set. Glwic, I hope gb starts soon.
Offline Banned
« Reply #49 on: Sun, 18 April 2021, 21:31:32 »
TY!! Hoping to do IC for around a month or two
