Author Topic: [IC] GMK Maroon | GB March 28th!  (Read 178448 times)
Offline Rpmorrison10
Re: [IC] GMK Maroon | GB March 28th!
« Reply #200 on: Thu, 10 March 2022, 21:31:41 »
Do you have pricing yet?
Offline Banned
« Reply #201 on: Thu, 10 March 2022, 22:47:11 »
I have quotes but regional pricing will come closer to GB due to stability issues with currencies atm.
Offline YESWEKEN
« Reply #202 on: Fri, 11 March 2022, 01:20:22 »
So the set will have icon mods? Or will icon+text mods be an option. I see mostly icon mods in the renders. But one render has icon+text on the enter key so thought I should get clarification.
Offline menuhin
« Reply #203 on: Sun, 13 March 2022, 08:49:38 »
Hey everyone! GB date has been announced! Maroon will be entering GB on 3/28/22!
Also, Hibi collab should be coming soon now that I have a GB date   ;D
It's kind of a short notice to gather enough for the GB within 2 weeks.
I hope the GB will last until early May 2022.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline Banned
« Reply #204 on: Sat, 19 March 2022, 18:55:29 »
It will be icon only  :thumb:
Offline IOVERCALLHISTIOCYTES
« Reply #205 on: Sat, 19 March 2022, 20:04:20 »
every time I read that I get excited that the bottom row will also be icons
I'll live. ready for maroon.
Offline incrediblejr
« Reply #206 on: Mon, 21 March 2022, 01:08:50 »
The Alt Alphas kit is missing R1 \| key which renders the kit useless for everyone that uses split backspace. Has this been addressed ?
Offline MSA_Vision
« Reply #207 on: Fri, 25 March 2022, 19:42:10 »
Also missing scooped F and J, an Extra B for alice compat in alt alphas. Missing white minibars from the spacebar kit too. Personally not a fan at all of using mod coloured bars for a two tone set so people buying the alt alphas cannot use it on an alice board.
Sic Parvis Magna
Offline 10peaches
« Reply #208 on: Fri, 25 March 2022, 20:18:56 »
Agree with the post above.
I would be keen to buy alt alpha if the missing R1 pipe key ( /|) is added. I like that you have added an extra tap in alt alpha kit cause I see the intention to let the people who bought all the kits can use the keycaps for two keyboards. Missing white coloured R1 pipe seems to be an oversight. Scooped or bar homing keys are no big deal for me.
I think there’s a lot of people also don’t like to use mod coloured spacebar for Alice. Without white spacekeys (2.25, 2.75 and 3) in spacebar kit is a bit of a let down. I would add 6u white spacebar to the spacebar kit too. I think it’s a bit redundant to have white 6.25u and 7u spacebar in the spacebar kit. I personally doesn’t use accented spacebar cause spacebar is consider as alpha.
Offline 傻子
« Reply #209 on: Fri, 25 March 2022, 21:57:08 »
pricing plz!
though it is 3/26 already but still eager for the price before GB
Offline menuhin
« Reply #210 on: Sat, 26 March 2022, 19:35:21 »
Agree that the white 6.25u and 7u spacebars in the spacebar kit are kind of redundant and if white spacebars are present it's better to have mini spacebars in white instead.
IBM M13 black
HHKB Pro 2 HasuBT
Offline Banned
« Reply #211 on: Sat, 26 March 2022, 19:50:50 »
All of these changes were for cost cutting as the base is going to be $135 USD. I felt like adding them might make more people not want to buy than the extra support would have.
Offline Banned
Re: [IC] GMK Maroon | GB March 28th - April 28th!
« Reply #212 on: Sat, 26 March 2022, 19:52:20 »
Pricing is here!
« Last Edit: Sat, 26 March 2022, 21:00:27 by Banned »
Offline Diggidy
« Reply #213 on: Sun, 10 April 2022, 18:11:10 »
Sigh. I swore off GMK....
Can't wait to get this set in 2025. I'm all in.
Offline Banned
« Reply #214 on: Fri, 15 April 2022, 12:34:06 »
GB Thread Here!
IC is locked
