Author Topic: NTSC or PAL? (SECAM can bite me)  (Read 4451 times)
Offline Oqsy
« on: Thu, 19 August 2010, 02:25:16 »
Which video format gets your goat?
I like NTSC because it are the better.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline timw4mail
    • https://timshomepage.net
« Reply #1 on: Thu, 19 August 2010, 07:02:46 »
NTSC has a better framerate, PAL doesn't have 3/2 pulldown jitter.
Seems fairly evenly matched.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline Ekaros
« Reply #2 on: Thu, 19 August 2010, 07:10:26 »
Does it realy matter anymore? They both should be burried...
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline timw4mail
« Reply #3 on: Thu, 19 August 2010, 07:13:22 »
Quote from: Ekaros;214349
And abandon 70+ years of video and hardware?
Offline bhtooefr
    • bhtooefr.org
« Reply #4 on: Thu, 19 August 2010, 08:15:05 »
Quote from: timw4mail;214348
NTSC and PAL are color encoding standards.
And you can get 60i framerates (with 3/2 pulldown jitter and all) on PAL. It's called PAL-M, and it's used in Brazil.
(I don't believe there's any actual standards using NTSC color on video systems traditionally used with PAL, though.)
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #5 on: Thu, 19 August 2010, 09:38:55 »
As color encoding standards, NTSC was the first and simplest one. PAL solved a problem with over-the-air broadcasting of color TV programs of phase shift by inverting the phase of the color signal with every second line. SECAM, instead, used frequency modulation instead of phase shift modulation to encode color information, and alternated which component of color information was sent on each line (instead of sending both components in phase quadrature).
PAL and SECAM are typically used in Europe, where the basic video standard is 625 lines at 50 Hz, while NTSC is used in North America and Japan with 525 lines at 60 Hz.
As noted, Brazil makes use of the newer PAL method of color modulation while having the basic North American video standard.
But the terms "NTSC" and "PAL" are currently sometimes misused to refer to the 525 and 625 line video standards respectively, and I think that they're being referred to in this sense - because DVDs are referred to as being either NTSC DVDs or PAL DVDs.
The 525-line video standard runs at 30 fps, and the 625-line video standard runs at 25 fps.
DVD players are made to connect to TV sets, but they have an internal capability of doing framerate conversions, so you can (provided there is no region coding issue) watch a PAL DVD on an NTSC television and vice versa. (Brazilians, of course, would be watching NTSC DVDs natively, and PAL DVDs with conversion, despite using PAL as their color modulation system, since the framerate requires conversion - the color modulation system is trivial, the DVD player just has to provide the right signal.)
The thing is, of course, that most motion pictures with a soundtrack (silent ones used to be 16 fps, and that changed to 18 fps) are filmed at 24 fps.
So because the difference is very small, in Europe, when a movie is shown on TV, they just run the projector fast, showing the movie at 25 fps.
In North America, that isn't an option - in one sixth of a second, there are five frames at 30 fps, and four frames at 24 fps. This results in what was called "3/2 pulldown": TV is interlaced, so there are 60 fields per second - thus, if one takes the four frames of a movie that are in 1/6th of a second, and scans them this way:
Frame one: even field, odd field, even field
Frame two: odd field, even field
Frame three: odd field, even field, odd field
Frame four: even field, odd field
then, by including some redundant information in the video signal, one has the movie running at exactly the right speed.
I've always wondered why they didn't use a television standard with a 120 Hz field rate and quintuple interlace - but since the reason for using 60 Hz was so that power line effects wouldn't distort the picture vertically (so that TV sets could have cheap power supplies) a doubled frequency might not have done the trick.
Thus, one could have a 587-line video standard, with each field containing 115 2/5 lines. So there would be four equalization pulses added instead of one during the vertical blanking interval. This would divide up the extra resolution gained by eliminating the redundant fields when showing motion pictures evenly between vertical and horizontal.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #6 on: Thu, 19 August 2010, 09:40:04 »
I like the VHS video format the best. I can fast forward through all the FBI warnings on a video tape.
Offline itlnstln
« Reply #7 on: Thu, 19 August 2010, 09:42:00 »
Chapter Fwd will typically skip them on Blu-Ray and DVD.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #8 on: Thu, 19 August 2010, 12:55:15 »
Are we talking about the analog television/broadcasting standards (color encoding, modulation etc.), or about the digital ones (DVB and DVD etc. -> resolution and framerate)? ;P Either way, I prefer PAL! For digital, it's lower framerate can actually be a advantage, because here you mostly have some sort of bitrate limit, and 25/50fps eats less bitrate than 30/60fps, even at it's slightly higher resolution. Only thing that sucks is the audio speedup in movies, tho pitch correction is pretty good nowdays.
A Ghost From The Past
Offline ricercar
  • mostly abides
« Reply #9 on: Thu, 19 August 2010, 15:33:28 »
NTSC
Never The Same Color
