Author Topic: BM80 RGB PCB  (Read 8312 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
BM80 RGB PCB
« on: Tue, 20 April 2021, 03:42:51 »
SPEC
1\80% Layout with 87 keys(BM80 doesn't mean the pcb only has 80 keys, 80% is size type)
2\Fully programmable PCB(VIA supported)
3\Full hot-swappable switch sockets
4\Full RGB switches LEDs (With kinds of LED effects)
5\MX Stem support
6\All components of the board have been pre-soldered so the PCB is ready for key switches and LEDs
7\Type C port
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: BM80 RGB PCB
« Reply #1 on: Tue, 20 April 2021, 03:43:11 »
