Author Topic: Where can I buy mac keyboard keycaps ?  (Read 2999 times)
Offline Kevin240
« on: Wed, 21 April 2021, 04:26:03 »
I have a Logitech G pro X keyboard. I will be getting a macbook pro soon and I want to use this keyboard with Mac OS. I'd like to buy some Mac keycaps to replace the alt and windows buttons with the command and option buttons. Since my keyboard is rgb, I want to have backlit keycaps. The only mac keycaps I can find are the keychron keycaps, but I don't think they're backlit. Let me know where I can find some mac, backlit keycaps.
Edit: I forgot to mention I have mx stemshttps://19216881.org/ https://1921681001.link/ https://19216801.digital/
« Last Edit: Tue, 11 May 2021, 12:30:05 by Kevin240 »
Offline SammyRodgers
Re: Where can I buy mac keyboard keycaps ?
« Reply #1 on: Wed, 21 April 2021, 09:28:17 »
Offline Riverman
« Reply #2 on: Thu, 22 April 2021, 11:39:48 »
It looks like the G Pro X keyboard has a non-standard bottom row (everything 1.25 wide except for the space bar), so that might cause some difficulty.  You can find Mac command and option keycaps from a few places like WASD Keyboards, Max Keyboards (the only source for backlit ones), eBay, and AliExpress, but they're all going to be 1.25 wide.  It looks like the Alt, Fn, menu, and Windows keycaps may be 1.25, but the Ctrl keycaps look like they're wider than that.  It might be worth it to buy the cheapest set you can find and see if they fit.  Even if you could just replace the Alt keycaps and the single Windows key, that would be better than nothing.
