Author Topic: [Help] Do I have to desolder my keyboard  (Read 3349 times)
Offline ottoxf
« on: Thu, 22 April 2021, 13:00:46 »
I forgot to put the stabilizers in my keyboard before I soldered all of the switches. I have this plate
https://keygem.store/collections/plate/products/carbon-fiber-plate-60
I attached an image below of what it is like right now. How can I fix this, am I able to install plate mounted stabilizers, or do I have to desolder the board and if so how long will that take.
Since it in thin carbon could i cut off the plate and then install some like that?
« Last Edit: Thu, 22 April 2021, 13:02:25 by ottoxf »
Offline MIGHTY CHICKEN
Re: [Help] Do I have to desolder my keyboard
« Reply #1 on: Thu, 22 April 2021, 13:19:52 »
Do not cut off the plate, just heat up the pins and once both of a switch are heated, yank the switch. If you have a pump, then heat up a pin, suck with the pump, repeat
Offline ottoxf
« Reply #2 on: Thu, 22 April 2021, 13:22:08 »
how long will it take to do that
« Reply #3 on: Thu, 22 April 2021, 13:25:52 »
for the 2u stabs, you only have to desolder one switch, but the spacebar almost looks as if you have to desolder a good chunk of switches around to see if you can bend the plate a little to slip stabs underneath, it will take a little longer than soldering if you have a pump, a good deal longer if no pump.
Offline ottoxf
« Reply #4 on: Thu, 22 April 2021, 14:43:49 »
thanks! i have a pump arriving tommorow
