Author Topic: [IC] flxlb ZT60 (premium 60% ortho)  (Read 22224 times)
Offline fluxlab
« on: Sat, 24 April 2021, 14:31:08 »
*Updated pre-group buy
flxlb ZT60
Discover refined precision with the ZT60, a premium 60% ortholinear keyboard engineered for both form and function. The ZT60 features a clean ortholinear layout that enhances finger symmetry and ergonomics without compromising usability. Designed with meticulous attention to detail, it supports most standard keycap sets and offers extensive layout customization options, combining versatility with aesthetic elegance.
Case Specifications
Typing Angle: 7.5 degrees
Front Height: 16.5 mm
EKH: 25 mm
Dimensions: 355 mm x 120 mm
Weight: 1.5 kg assembled
Mounting: Silicone gasket (PCB mount)
Plate options: FR4, PC, POM, Aluminum, Brass
PCB: Hotswap or solder
PCB Specifications
Options: Hotswap or solder
MCU: ATMEGA32U4
Switch compatibility: MX only
Firmware: QMK and VIA
Layouts
Solder:
Hotswap:
2021 IC Content:
UPDATE Aug 5, 2021
Hey everyone,
Sorry things went a little quiet recently around the ZT60.
I wanted to wait for the new prototype to arrive before I make an update.
It just arrived, so here’s the latest update!
I’ve been trying to figure some things out regarding the feedback I’ve received on the keyboard’s layouts, and I have come up with another updated design.
A few people have mentioned to me that the new layout I proposed will not work--the 1.75u backspace key in my renders does not actually exist!
I overlooked that the 1.75u backspace key in the 40% kits is for row 2 instead of row 1.
To solve this problem, I have decided to add custom machined novelty keycaps for the escape and backspace keys (1.25u and 1.75u, keycap design not finalized yet).
This will, however, come at a premium (~CAD$100). The original layout with the staggered number row will still be an option.
Group buy date is still to be determined, but I’m aiming for an end date before the end of the year.
I’ve attached some photos of the new ZT60 production sample below.
There are some surface imperfections which I am sorting out with my supplier currently.
I will be posting a sound test video within the next few weeks.
Jason
Updates
April 28, 2021: New aligned number row layout option, new renders
August 5, 2021: Production sample received, new photos
Hello!
My name is Jason.
I have just completed the Zplit group buy and would like to introduce a new keyboard: the FluxLab ZT60.
The ZT60 will be a premium, 60% ortholinear keyboard for most high-end keysets.
While running the Zplit GB, I realized that my product did not have the same quality as many other keyboards.
Surface finish was not perfect, packaging was rough, and official QMK and VIA firmware support was not ready.
So, for the ZT60, I will be focusing on giving you a premium experience throughout, starting from the unboxing to the first typing test.
The ZT60 has been in development for almost a year, and I have been using a prototype of it as my main keyboard for the past 6 months.
Many changes have since been made to the design.
I will be posting regular updates on the FluxLab Discord server: https://discord.gg/ngQMCMBKjw
Alternatively, updates will also be posted on the FluxLab Instagram page: https://instagram.com/flxlb
Thanks,
Jason
Production Sample Images
Sound test will be posted here.
The Design
The FluxLab ZT60 is a 60% ortholinear keyboard with support for most high-end keysets.
As long as the keyset has 1u/1.75u and 2u shift keys, it will be fully compatible with the ZT60.
It will support various bottom-row layout features, such as a 6.25u spacebar, a 7u spacebar, split spacebars, and an arrow cluster.
The image below illustrates all the layout options available.
Default
Aligned number row
Case Specifications
Plate Mount: Gasket
Weight: ~2 kg
Case Material: 6063 aluminum
Weight Material: C36000 brass
Gasket Material: Poron and silicone
Typing Angle: 6.9 degrees
Case Surface Finish: Electrophoresis coating or anodized
Plate Surface Finish: PVD coated
Color Options: White or black
Case Feet: Adhesive rubber feet
Plate Options
Brass
POM
FR-4
PCB Specifications
MCU: Atmel ATMEGA32U4
Connector: USB-C (with daughterboard)
Switch direction: South-facing
Protection: ESD, overvoltage, overcurrent
Hotswap: Mill-max service or Kailh (depending on interest)
Lighting: None
Firmware: QMK and VIA installed out of the box
Renders
Pricing
Exact final pricing is not yet determined, but will be in the range of CAD$500-650 (~USD$400-500).
Group buy will be run through my website, flxlb.ca, which will use Shopify to process payments.
Timeline
*I will be generous with the estimated dates.
Group Buy date to be determined
2nd month
Receive final samples
4th month
Receive case parts, PCBs, and packaging
Inspect parts
Test PCBs
Assemble and package if quality requirements are satisfied
6th month
Receive new parts if required
Begin shipping
Frequently Asked Questions
Can the number row be aligned with the rest of the alpha keys?
I've added a new layout option for this! It will require a 1.75u backspace key. There will also be a separate plate and blocker for this option, which may be slightly more expensive.
Will there be an EU vendor?
If there is enough interest for this keyboard, I will definitely reach out to EU vendors.
Will there be a hotswap option?
There will either be a mill-max hotswap soldering service or a fully integrated Kailh hotswap PCB option, depending on interest.
Are there any other colour options?
Currently, the confirmed colours are e-white and black. I may choose a third colour from the feedback I receive.
Fill out the Interest Check Form!
To show your support for my keyboard, please add this banner to your profile signature!
Code: [Select]
[url=https://geekhack.org/index.php?topic=112471.0][img width=315 height=140]https://i.imgur.com/GfQVBGq.jpg[/img][/url]
« Last Edit: Tue, 13 May 2025, 02:16:16 by fluxlab »
Offline Rubbermilitia
Re: [IC] FluxLab ZT60 (A premium 60% ortho)
« Reply #1 on: Sat, 24 April 2021, 14:47:46 »
I love this layout but I'm curious about a few things:
- what went wrong with the previous surface finishing?
- what are you doing to avoid a repeat of that issue? Changing factories, improved QA...?
- why 6.9 instead of 7 degrees?
This board has everything I like about ortho with everything I like about staggered, so I will be watching curiously!
Sent from my SM-G950U1 using Tapatalk
Offline fluxlab
« Reply #2 on: Sat, 24 April 2021, 14:54:07 »
The sandblasted brass plates did not have a coating and were prone to tarnishing.
The powdercoat had some slight orange peel and spots.
I've switched factories and will be requesting samples until the quality is satisfatory. QA will also be done on every unit before shipping.
why not? :)
Offline ZavaZ86
« Reply #3 on: Sat, 24 April 2021, 14:57:18 »
You seem to have forgotten the last buzzword to complete the IC, please revise the IC.
Offline Mandy
« Reply #4 on: Sat, 24 April 2021, 16:47:48 »
This is close for me. Odd decision to stagger the number row, and I wish it had support for an MIT style bottom row.
Offline fluxlab
« Reply #5 on: Sat, 24 April 2021, 17:24:14 »
the number row stagger is an imperfect solution, but its the only way to achieve a uniform 0.25u stagger along each row. the main benefits of ortho still remain with all the alpha keys aligned, as the num row is used much less than the alphas, so i decided to go with this design.
edit: also, not sure what an mit style bottom row looks like
Offline br4n_d0n
« Reply #6 on: Sat, 24 April 2021, 23:41:28 »
I agree with the top row being a mistake and should be linear instead of offset. As for the "MIT" style, @Mandy is probably referring to the Planck MIT layout with a 2u spacebar or at least one that is also linear.
Side note: I'm not really sure what MIT stands for in the case of the Planck, so if anyone knows, please share.
« Reply #7 on: Sat, 24 April 2021, 23:47:22 »
Yeah I would be curious to see the uniform 0.25u stagger version side-by-side with a full ortho on alphas version
Offline fluxlab
« Reply #8 on: Sun, 25 April 2021, 01:36:47 »
I've received quite a bit of feedback regarding aligning the top row, so I thought about it more and may have come up with something elegant! Will update you guys soon!
Offline peej
  • I'm a lumberjack and I'm okay
« Reply #9 on: Sun, 25 April 2021, 02:44:19 »
This is amazing, I love it.
I think the staggered top row is fine, I'd prefer this than having a non-uniform edge.
EU vendor? Shipping and imports are gonna sting.
Do you have more renders of the back and underside?
Offline Kawamashi
« Reply #10 on: Sun, 25 April 2021, 14:52:09 »
The staggered top row don't bother me, keeping a uniform 0.25u stagger along each row is much more elegant than to go full ortho.
EU vendor would be awesome !
Offline well_cooper
  • Turn metal in to typing machine
    • Thocc Supply
« Reply #11 on: Tue, 27 April 2021, 06:39:07 »
really interesting idea, GLWIC
Offline fluxlab
« Reply #12 on: Wed, 28 April 2021, 20:23:35 »
Just made an update to this! I will be deciding on whether to have an EU vendor later, depending on interest. New renders have been added, as well as an option for those who want the number row aligned!
Offline gbenz
Re: [IC] FluxLab ZT60 (A premium 60% ortho) - New layout options!
« Reply #13 on: Thu, 29 April 2021, 01:40:39 »
That skinny little blocker at the top left of the aligned num row layout............. .. .. feels bad
Offline fluxlab
Re: [IC] FluxLab ZT60 (A premium 60% ortho) - Production Sample received!
« Reply #14 on: Thu, 05 August 2021, 21:02:30 »
Just received the new production sample and posted an update!
Offline gbenz
« Reply #15 on: Fri, 06 August 2021, 13:09:43 »
Wow this is looking clean! But please put the esc right next to the 1 in the aligned layout. No blocker please, I beg of you.
Offline Codezilla
« Reply #16 on: Sat, 07 August 2021, 21:34:57 »
Yes, please... No blocker between esc and 1. Let there be a custom 1.25 esc. No blockers please.
Offline Antoxa
Re: [IC] flxlb ZT60 (premium 60% ortho)
« Reply #17 on: Fri, 01 August 2025, 11:21:39 »
It's good that I'm not the only one. ;D
24.04.2017 - Leopold FC660M Cherry MX Black 60cN
23.12.2017 - Leopold FC980M PD Cherry MX Black 60cN
18.11.2019 - OLKB PLANK Gateron Milky Pro Yellow Linear 100gf
17.07.2025 - Keychron Q15 MAX Gateron Jupiter Banana 59+15gf
Offline wtzll
« Reply #18 on: Sun, 02 November 2025, 15:00:59 »
Any updates to this?
5975:JP
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #19 on: Mon, 03 November 2025, 18:12:54 »
Overall I really like your design and hope you are still planning to run a group buy down the road.
While I agree that the staggered number row was bad, the gap between R1 and R2 is no better. I propose a parallelogram that eliminates both these issues as well as the gap between ESC and 1. Using the standard 2.25u shift is another benefit, as base kits don't always include 2u shift.
Offline dvorcol
« Reply #20 on: Mon, 03 November 2025, 19:58:39 »
Oops, my proposal is about a year too late – the GB already ran LOL
https://geekhack.org/index.php?topic=125166.0
Offline Nibor
    • BRN Labs
« Reply #21 on: Tue, 04 November 2025, 11:04:35 »
The back of the case looks so beautiful, flows so smoothly on the sides!
I'm curious, Does the layout cause issues with muscle memory for traditional keyboard users?
