Author Topic: [IC]Samice 60% Keyboard FCFS+Alu Samples updated  (Read 14778 times)
Offline Lukenan
    • Sam Website
« on: Sun, 25 April 2021, 05:57:08 »
Hi there,
This is Samice 60% Keyboard kit from Sam’s Studio. Please express any interest and feedback by fill the IC form. There will be a limited amount for sale. If you have any questions, feel free to comment here or join the Discord server: https://discord.gg/XMKBwN4mr3 for GB updates. Thanks.
Gallery: https://imgur.com/a/fqDtzMr
Features:
Top mount
PC or Aluminum alloy top case
3MM mirrored stainless steel PVD bottom case
Alu plate( Grey Silver Green Blue Red )
Pure Brass weight
PCB: Soldered PCB, TYPE-C interface, VIA support
Typing angle:7°
Front height:2cm
RGB Underglow
3.5MM foam silicone
Aluminum alloy top Case color: Grey Black Green Blue Red
GB TIME: May
Price: $300USD +-
Delivery: The estimated shipping date will be confirmed after the GB ends. (About 1-2 months)
No Vendor
« Last Edit: Fri, 30 April 2021, 20:55:29 by Lukenan »
Offline P103
Re: [IC]Samice Ergonomic 60% Keyboard FCFS
« Reply #1 on: Sun, 25 April 2021, 06:11:54 »
Can you post pictures for the internals? Curious about the weight.
Offline Baka Bot
« Reply #2 on: Sun, 25 April 2021, 07:38:08 »
Any other plate materials?
Offline Lukenan
    • Sam Website
« Reply #3 on: Sun, 25 April 2021, 08:56:34 »
will update more pictures before GB. Thanks
Offline Lukenan
    • Sam Website
« Reply #4 on: Sun, 25 April 2021, 08:57:22 »
weight: 2kg+
Offline Lukenan
    • Sam Website
« Reply #5 on: Sun, 25 April 2021, 08:57:55 »
currently no plan
« Reply #6 on: Sun, 25 April 2021, 10:18:09 »
Could we have a rule against advertising the Alice as "ergonomic", please?
Offline jtqx
« Reply #7 on: Sun, 25 April 2021, 11:00:45 »
https://www.zfrontier.com/app/flow/4xmMMoNlrxmd
I skipped on this when it was available on taobao as a groupbuy due to the weight design. At this size, it may as well be a badge rather than a "weight". Will this be changed for the international buy?
Big boys: JER1800, Cypher, IBM Model M, W1-AT
TKLs: F1-88, F1-8x_722, F2-84, EO87, Matrix ME, IBM 'SSK', Bias, NCR80
Small boys: HHKB Pro 2, KWa.6, Maggio
Others: Praxis, LZ Phase, Sagittarius
65% and 75% bad
Offline blaqbern
« Reply #8 on: Sun, 25 April 2021, 11:21:36 »
The bottom of the board is stainless steel, so this one should be pretty hefty; SS is heavier than brass.
I think the brass piece is added just for aesthetics. So calling it a badge rather than a weight might be more accurate, but I don’t have any concerns about the overall weight of the board. OP mentioned it was 2kg+ :thumb:
Offline Lukenan
    • Sam Website
« Reply #9 on: Fri, 30 April 2021, 20:58:17 »
Thanks for your suggestion. Already updated. Thanks
Offline SDKCAMPING
« Reply #10 on: Fri, 30 April 2021, 21:07:03 »
Doesn't really matter much in this case, but brass is actually heavier than SS by a tad bit.
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline blaqbern
« Reply #11 on: Fri, 30 April 2021, 22:08:59 »
Thanks for the info! Not sure where I got the idea that SS was heavier. In any event, this board should be plenty hefty.
Offline Ustinj
Re: [IC]Samice 60% Keyboard FCFS+Alu Samples updated
« Reply #12 on: Fri, 30 April 2021, 22:15:45 »
Heavier on the wallet  :)) But here it seems an excellent value!
Offline Havattack
« Reply #13 on: Sat, 01 May 2021, 01:47:19 »
What caliber is that gun your including with the keyboard? it's functional right?
....(it was kind of a silly choice, but no more then a cactus or any of the other random stuff people put in glamor shots I guess..)
Offline rafamundez
« Reply #14 on: Tue, 15 June 2021, 04:35:12 »
This was available on Taobao? Link?
Edit: never mind. I see the link on the zfrontier page now.  https://item.taobao.com/item.htm?spm=2013.1.w4023-22664781237.16.75967a33P44ZH4&id=644724275655
According to google translate, it's sold in a quantity of 100? 70 PC and 30 alu?
« Last Edit: Tue, 15 June 2021, 15:51:15 by rafamundez »
Offline DeMechanica
« Reply #15 on: Wed, 04 August 2021, 08:57:29 »
Already delivered. Nice GB!
