Author Topic: KEYHOME KH68 68 KEY DUAL MODE BLUETOOTH 5.0 MECHANICAL KEYBOARD 65%  (Read 9049 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
SPEC
Dual Mode Keyboard (Bluetooth 5.0+ Cable Mode)
Full RGB LEDs (support kinds of light effects)
Switch Hot-swappable sockets
Support software to adjust keyvalue\RGB light effect\Macro
Type C(USB detachable design)
NKRO
PBT Dye-Subbed Keycap\XDA Profile
Buy now
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: KEYHOME KH68 68 KEY DUAL MODE BLUETOOTH 5.0 MECHANICAL KEYBOARD 65%
« Reply #1 on: Thu, 29 April 2021, 03:41:58 »
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #2 on: Thu, 29 April 2021, 03:42:30 »
How to connect with other devices:
Make sure your keyboard is not connected with cable
Turn battery button on(at the bottom of keyboard)
Press Fn+Q or W or E for 3 sec , make sure KH68 is in pairing mode
Then search Bluetooth device at your mobile device and connect with KH68, next time , you just need press Fn+Q or W or E to change with different devices.
If you connect with cable under blue tooth mode, pls remember press Fn+R to change it to Cable mode. And KH68 software can only run when KH68 is under cable mode.
NOTE: If you want to change the key value in software, pls turn off the LED effect in the software first. Otherwise, it cannot be changed if you don't turn off the LED effect.
Power indicator: When charing, the Spacebar LED is Blue, If the power is 100%, the spacebar LED is green. And if the keyboard is in low power, The spacebar LED is red and all switch led will be off.
