Author Topic: Help rendering  (Read 1761 times)
Offline manbanye
Help rendering
« on: Thu, 29 April 2021, 12:08:23 »
Hey guys, i am trying to make a ic, but I don't know how to render and stuff :( . Can someone explain how exactly I should go about it?
Offline shs0913
Re: Help rendering
« Reply #1 on: Mon, 03 May 2021, 06:01:02 »
Do you only have ideas? Or is it just the rendering left after designing?
You could use a program like V-RAY, or maybe even have a renderer built into the program.
External rendering programs will be able to take the designed file right away and run it.
One problem is, it is quite wasteful to simply buy these programs for IC.
Re: Help rendering
« Reply #2 on: Mon, 03 May 2021, 08:26:28 »
If you got your models done I could help with that.
Alternative to a static render check out my signature :)
