Author Topic: full sized kits  (Read 2200 times)
Offline Error213
full sized kits
« on: Sat, 01 May 2021, 23:39:45 »
i wanna build my dad a keeb for  fathers day and he needs full sized. media keys would be nice and he would really love a volume knob, also for some reason he doesent want a macropad for media and volume knob.
Offline Faceman76
Re: full sized kits
« Reply #1 on: Sun, 02 May 2021, 01:16:55 »
1800 board and layers for media buttons
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
Offline Volny
Re: full sized kits
« Reply #2 on: Sun, 02 May 2021, 02:10:43 »
I'd be pretty bummed if someone gave me a keyboard as a present that required me to use layers just to reach the media controls.
If you can't find a kit with media keys and volume knob (probably pretty hard to find - if you do, let us know!), consider remapping prtsc, scrollLock, and Pause to play/pause, volUp, and volDown, with keycaps to suit. Consider also using clicky switches for those keys so they feel more like buttons.
play/pause, volUp, and volDown are likely the most commonly-used media keys - you could then perhaps use layers to convert them to mute/nextTrack/prevTrack if needed. This is of course assuming that he never uses prtsc/scrollLock/pause, but most people's dads probably don't.
« Last Edit: Sun, 02 May 2021, 02:33:14 by Volny »
Offline Leslieann
Re: full sized kits
« Reply #3 on: Sun, 02 May 2021, 02:19:44 »
This.
The only ones I can come up with are DAS and Corsair.
The more "hardcore" keyboard companies don't like volume knobs and multimedia keys because of the lack of ready made keycaps so your options are a bit limited. I have no idea how good either is at this point but they fit what you're after.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Error213
Re: full sized kits
« Reply #4 on: Sun, 02 May 2021, 09:44:22 »
This.
He uses a das but I can’t really mod it without it being more trouble than it’s worth, and they all have these weird laptop stabs except for the space bar so Corsair?
Offline Faceman76
Re: full sized kits
« Reply #5 on: Sun, 02 May 2021, 10:05:15 »
If layers aren't a big no, this may be your only option.  Just make sure he still doesn't use all the keys mentioned above.  With Window shortcuts and the Snip Tool readily available, keys such as  Print Screen are no longer a necessity.
Offline Leslieann
Re: full sized kits
« Reply #6 on: Sun, 02 May 2021, 19:42:33 »
Check a few reviews, maybe one of them shows what stabs they're using on the model you're interested in, it's possible they use the same though I doubt it.
I would expect the Corsair to a bit nicer.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
