Author Topic: [GB] GMK Lazurite | Color Samples from GMK  (Read 64522 times)
Offline jaekid
    • Instagram
« on: Sat, 08 May 2021, 19:26:03 »
GMK LAZURITE
An allusion to High Renaissance art and the value of the pigment ultramarine
GMK Lazurite takes inspiration from the mineral lazurite found in lapis lazuli, processed and turned into a pigment called ultramarine. It was used by High Renaissance painters for the color blue, and was even priced more than the value of gold.
Group Buy Schedule: May 7, 2021 to June 6, 2021
Estimated Shipping Date: Q2-Q3 2022
Where to place your group buy orders?
GMK Lazurite Kits and Accessories
EU : MyKeyboard
US : Mechs & Co.
UK : Proto[Typist] Keyboards
CA : Desk[H]ero
Oceania (AU/NZ) : Daily Clack
CN/East Asia : zFrontier (EN)
CN : zFrontier (CN)
South Korea : SwagKeys
SEA : iLumkb
Latin America : Fancy Customs
Philippines : Zion Studios PH
Separate PATAG x Lazurite Deskmat Links
*Some vendors have the same product page links with GMK Lazurite kits
Philippines : PATAG
CA : Desk[H]ero
SEA : iLumkb
KBDfans x Lazurite Keyboard
*DOES NOT come with the keycap set
Worldwide : KBDfans x Lazurite D60Lite
GMK Lazurite Kits and Accessories Pricing
a keyboard collaboration of GMK Lazurite with KBDfans
60% keyboard, color-matched with GMK Lazurite's colors, sold as a Group Buy.
Available for pre-order from May 7, 2021 to June 7, 2021 at KBDfans (worldwide distribution).
P.S. THE KEYBOARD DOES NOT COME WITH THE KEYCAPSET.
MORE images of KBDfans x Lazurite D60Lite keyboard with the keycapset
FULL INFORMATION about the KBDfans x Lazurite D60Lite
CLICK MORE
Layout
60% WK and HHKB
Price
$119 (keycap set NOT included)
Where to buy?
https://kbdfans.com/collections/diy-kit/products/kbdfans-x-lazurite-d60lite
Keyboard Group Buy Date
May 7th to June 7th 2021
Keyboard Estimated Ship Date
2 months after the group buy
Specs
PCB: DZ60RGB-WKL RGB hot-swappable PCB ( QMK and VIA supportable,
Type-C, support Windows, Mac, Linux )
Plate: Polycarbonate
Stabilizers: KBDfans transparent stabs
Gasket: 2 sets of gaskets, injection-molded silicone gaskets, foam gaskets Switch foam: it's the type with the switch holes Bottom silicone pad:which is tightly fitted. Compared with kbd67lite, it is a newly added configuration.
Case: PC+ABS material, using an injection molding process, the surface is matte, opaque (The picture is rendered, physical picture will be updated later)
USB-C Cable
Colors: Bottom Case (Blue); Top Case (White), USB Port (Gold) - color-matched with GMK Lazurite
Typing angle: 6°
Gasket mount Designers:KBDfans Wei ( D60lite ); jaekeyed ( GMK Lazurite )
GMK Lazurite Color Combination
Here is the summarized breakdown of how the set looks like in terms of colors
CLICK MORE
For people who want minimal colors, ultramarine blue and white
Lazurite (Base): blue alphas, white mods
Calcite (Alternate Alphas): white alphas
Lapis (Spacebars): blue
High Renaissance (Blue) | Novelties 2: blue on white
For people who would like to accentuate their keycap set with gold on ultramarine blue
Lazurite (Base): blue alphas, white mods, gold accents
Lapis (Spacebars): gold
High Renaissance (Gold) | Novelties 1: gold on blue
I have added a few gold Esc and Enter keys for the 40s community so you can also have the Pyrite accents.
Ultra (Extension): blue on white, blue on gold
Kits
Lazurite - Base Kit ($126)
Inspiration: lapis lazuli's lazurite on a calcite marble with pyrite mineral accents
Colors
-Ultramarine Blue Alphas
-White Mods
-Gold Accents
Support
-Full-size layout
-Compact-1800
-65%
-75%
-80%/TKL
-60% HHKB/Tsangan
-Basic 40% (3-key support)
-Basic US ISO
-Alice layout (Shift keys, extra B)
-Barred and Scooped Homing Keys
Calcite - Alternate Alphas Kit ($63)
Inspiration: pure calcite marble with minimal touch of ultramarine
Colors
-White Alphas
-Ultramarine Blue Legends
Support
-Barred and Scooped Alphas Homing Keys
-Alice extra B
-Basic US ISO alphas
Lapis - Spacebars Kit ($30)
Ispiration: lapis lazuli bars and pyrite accents
Colors
-Blue
-Gold
Support
-split
-Alice
-centered and off-centered stems
Ultra - Extension Kit ($38)
Inspiration: the 40% community, no need for a deeper meaning, I would just like to give love to the community.
Colors
-Ultramarine Blue Bars
-White Mods
-Gold Accents
Support
-typical 40%/ortho layout
High Renaissance - Novelties Kits 1 and 2 ($60/kit)
The idea is to create a paint frame design for your mechanical keyboards using the novelties, which will act as 'borders' on ortholinears, usual 40% layouts, 60%, 65%, 75%, 80%/TKL, Tsangan, HHKB, WKL, 1800 and full-sized keyboards. (almost all layouts are supported by both novelties kits)
Color Compatibility (PLEASE READ)
Both novelties kits 1 and 2 can complement the look of these two configurations:
-Lazurite base kit (blue alphas, white mods) and
-Lazurite base + Calcite alternate alphas (full white set)
At the end of the day, it is your own preference and you can create your own combination with both of these novelties. Enjoy!
High Renaissance (Gold) | Novelties Kit 1
Color: Gold on Ultramarine Blue
High Renaissance (Blue) | Novelties Kit 2
Color: Ultramarine Blue on White
GMK Lazurite High Renaissance Novelties Compatibility
These novelties are also intended to complement or accentuate other mono-tone sets (same-colored alphas and mods). Mix and match them with your existing/upcoming keycapsets
CLICK MORE to check a few of the existing/upcoming keysets which can pair up nicely with the High Renaissance Novelties
High Renaissance (Gold) | Novelties 1 will complement the ff. colors:
-saturated yellow
-gold
-blue (light)
-white
see the GMK Civilizations x GMK Lazurite render
High Renaissance (Blue) | Novelties 2 will complement the ff. colors:
-gold
-white with any shade of blue-colored legends
-blue (light/dark shade)
have a look at this GMK Earth Tones x GMK Lazurite High Renaissance (Blue) Novelties render
These renders were permitted by the respective designers. I also tapped Holi, designer of GMK Honey to show you how the High Renaissance Novelties 1 and 2 can complement, this time an existing set which has already been shipped to buyers.
GMK Honey x GMK Lazurite High Renaissance (Blue) Novelties render
GMK Honey x GMK Lazurite High Renaissance (Gold) Novelties render
Keyboard Renders
SWIFT65 by Swift Cables
Chapter 1 keyboard design and renders by Rooke Design
MORE PHOTOS
Loki65 by Nedzc27
CLICK MORE TO VIEW ALL KEYBOARD RENDERS (OLD AND NEW - UPDATED NOVELTIES)
40% Keyboards
Keeblade by Qlavier
MORE PHOTOS
Alice Keyboard
NOTE: I am currently reworking on the renders to show corrected High Renaissance novelties
Charlotte by KraizesGB
MORE PHOTOS
60% Keyboards
RAMA WORKS M60-A by RAMA WORKS
MORE PHOTOS
Mekanisk Fjell by Mekanisk
AXE60 keyboard design and renders by S61
MORE PHOTOS (Different variations of GMK Lazurite's kits)
KN2.10² by thesiscamper
MORE PHOTOS
65% Keyboards
Swift65 by Swift Cables
MORE PHOTOS
NOTE: non-existent keyboard case colorway (image for render purposes ONLY)
Kohaku65 by Elaine of SINGAKBD
MORE PHOTOS
Nseries N6 keyboard design and renders by Neson Design
Reasonable65 by Rizwanislol
MORE PHOTOS
Pizza65 by Pizza Keyboards
MORE PHOTOS
75% Keyboards
GHS.RAR keyboard design and renders by Gone Hacking Studio (mods legends are changed to ICON+TEXT on the final kits)
ALTERNATE ANGLE
KL-90 by Kiko's Lab
a new set of photos will be uploaded with the PC version of a teal KL-90 which will go LIVE for GB in a few
MORE PHOTOS
80% Keyboards
F2-84 by Geon
MORE PHOTOS
RAMA U80-A by RAMA WORKS
MORE PHOTOS
PATAG x Lazurite Desk Mats
MORE INFO - CLICK MORE
Specifications:
-900mm x 400mm
-microfiber top
-stitched edges
-rubber base
Notes:
-I have partnered Lazurite with a desk mat brand, PATAG that I founded last year
-PATAG is a brand geared towards promoting Filipino culture through our products (desk mats), with a commitment of sharing our profit to the local Filipino indigenous communities where designs are inspired from.
-Lazurite's desk mats are distinct from what we design as a brand. Even so, I have decided, being a majority owner of this venture, that our brand will run the Lazurite deskmats to inspire local artists/designers in pursuing their talents.
CLICK MORE to view individual deskmats
Paint Frame - Ultramarine ($25)
Paint Frame - Calcite ($25)
Renaissance Ornament ($25)
Metal Artisan Esc Keycap ($60)
RAMA x Lazurite
Brass with Polished Gold PVD)
Renders with the keycap set on KBDfans x Lazurite D60Lite
MORE PHOTOS
Renders with the keycap set on KN2.10², keyboard designed by thesiscamper
MORE PHOTOS
Collaborations
All collaboration pieces for GMK Lazurite. Some of the artisans have already been sold out (raffle type of sales). More information and ease of access to these collaboration pieces can be found inside my Discord server.
Keyboard
KBDfans x GMK Lazurite D60 Lite
MORE PHOTOS
Coiled USB Cables
Swift Cables
Mechanical Keyboard Bag
From Scratch
I designed this mechanical keyboard bag in collaboration with the amazing Ruby of From Scratch special shoutout to Alstr27 for reaching out.
Artisan Keycaps
CLICK MORE to see all Artisan Keycaps Collaboration of GMK Lazurite
DEAGcaps (US)
NORK (Philippines)
(RAFFLE FORM IS LIVE)
Nonekomata - "Featuring the usage of ultramarine pigments, a replication of the randomness of real Lapis Lazuli (thanks nature!), and pieces of history itself. That’s right, there are actually 2 pieces of the gemstone itself encapsulated inside both ears of the sculpt." -NORK
Keebsake (Philippines)
(GROUP BUY ON-GOING)
Medici
Alpha Keycaps
Yohan allowed me to design/choose a colorway for his amazing sculpts: Keypora and Salvador.
actual sample photos soon to be uploaded
AK Keypora
AK Salvador
Buckeys! (Philippines)
Buckeys! Eerie Lazurite and Maskara Lazurite
Buckeys! Rogue Lazurite
ZappyCappys (US)
Lazurite Arrow Set
Artisan Keycaps (ENDED SALES)
Primecaps Artisans (Canada)
(RAFFLE ENDED)
Al Bumen - Feldspar Tsar
Golden Star Keycap (Vietnam)
(RAFFLE ENDED)
Sokratis and Bara
Velites and Wooloo
Solunar
MORE GSK Artisan Keycaps PHOTOS
Zero Sky (Philippines)
(RAFFLE ENDED)
Cyber Marshal
Ochre + Moss (US)
(RAFFLE ENDED)
Lazuli Goob
Krapshop (Malaysia)
(RAFFLE ENDED)
Catto19 Calcite
Catto19 Lazurite
Catto19 Raw Lazurite
Skull Keycaps (Philippines)
(RAFFLE ENDED)
Megalodon Lazurite
CECEcaps (Vietnam)
(RAFFLE ENDED)
Gukong Lazurite
Bowbie Keycaps (US)
(RAFFLE ENDED)
Bearbie Lazurite
LandCaps (Indonesia)
(RAFFLE ENDED)
LandCaps Rangda and Barong Lazurite
Gooey Keys (US)
(RAFFLE ENDED)
Hecky Lazurite
Namong Keycaps (Korea)
(RAFFLE ENDED)
Baekho, Jujak and Dokkaebi Lazurite
Sandun Art (Korea)
(RAFFLE ENDED)
Grim Reaper Lazurite
Picaps (Vietnam)
(RAFFLE ENDED)
Butora and Master Rua
Amidst The Clouds (Arizona, US)
(RAFFLE ENDED)
Cloud Caps
(Waiting for sample photos - CONFIRMED)
KEYFORGE (Salt Lake City, Utah)
Artisan Wrist Rests
Resinboy Project (Philippines)
Artisan Labs (South Carolina, US)
Custom Mouse Mod
Leonardo Da Mouse (UK)
Custom Mouse Mod Raffle
If you want to view the photos like a gallery, you may check the Instagram link below where I also post updates, stories, collaboration raffles and renders of the set.
For faster updates regarding the progress of GMK Lazurite, and if you want to follow what comes next after my first keycapset design, you can hop inside my Discord server! Welcome!
Ultra marinus, the theme of this set means beyond the sea, representing us as a community, a distant bond but a precious one. I will always wish the best for all of you. Thank you for being a part of this journey!
Special thanks to the following:
ON THE EARLY STAGES OF GMK LAZURITE
konstantin
NoPunIn10Did (DSS Late Harvest)
simbusped (GMK Earth Tones) and the rest of Zion Studios PH
HungHingDaiLo (GMK Maestro)
Bobas (KAT Great Wave)
EURA
Nick's Clicks (GMK Lavender)
Lumis (KDD)
Swishy (KDD)
u/Rizwancameback (Reasonable65)
u/jkaos92 (Melody65)
For responding to my concerns about my blue GMK set, thank you for your kind words and nice gestures
Virtual (GMK Sumi)
ARSLOCK (GMK Classic Blue)
Tom (GMK Deep Navy)
Zambumon (GMK Striker)
UP UNTIL THE GROUP BUY
Ehmerald, Darlene, Erica
PATAG Team & Fam
Alfred of Swift Cables
Wei and Bob of KBDfans
dvorcol
Army of Keyboards
Mike, Psyoshi and the whole team of Mechs & Co.
OG BRASS GANG: McPatty, Deara, Aurora Camo, Cdog019
Yuliaa and David of MyKeyboard
and all vendors/proxies of GMK Lazurite
ImperfectLink#5617
Daniel of Your Mouse Mods
ALL KEYBOARD CASE DESIGNERS who allowed me to render GMK Lazurite on their amazing keyboards
ALL AMAZING ARTISANS and COLLABORATORS of GMK Lazurite
THESE CONTENT CREATORS
Army of Keyboards
Jeff
Straubrey TV
Eri Neeman
Tiny
Brandon
Jukay
Elyxirine
TaeKeyboards
Magniboards
Qlavier
TechBroll
Tom Bermor
Madam Bonez
And to everyone I have come across, who has been a part of this wonderful journey, showing support and sharing their feedback about my very first keycapset.
Signature Banner
If you want to show your support for GMK Lazurite, copy and paste this code to your Geekhack profile sitnature  ;D Thank you!
Code: [Select]
[url=https://geekhack.org/index.php?topic=112710.0][img]https://imgur.com/yMn8ekg.png[/img][/url]
« Last Edit: Thu, 30 September 2021, 07:52:55 by jaekid »
Offline jaekid
    • Instagram
Re: [GB] GMK Lazurite | May 7, 2021 to June 5, 2021
« Reply #1 on: Sat, 08 May 2021, 19:26:31 »
GB Tracker (Latest Numbers)
Final Count (including extras)
Kits
Lazurite | Base - 1139
Calcite | Alternate Alphas - 361
High Renaissance (Gold) | Novelties 1 - 525
High Renaissance (Blue) | Novelties 2 - 500
Lapis | Spacebars - 323
Ultra | Extension - 107
PATAG x Lazurite Deskmats
Paint Frame Ultramarine - 179
Paint Frame Calcite - 190
Renaissance Ornament - 156
Artisan Keycap
RAMA Lazurite - 363
Last graph prepared by dvorcol
<-- without extras
GB Order Updates
GMK Lazurite kit orders have already been placed by the lead vendor, MyKeyboard.
I'll be waiting for color samples for approval, and the set will be lined up for production. Extras will be sold by each proxy/vendor.
Thank you very much for supporting my first keycap set design!
09/30/21 Update
GMK color samples just arrived.
« Last Edit: Thu, 30 September 2021, 07:51:13 by jaekid »
Offline Dumblescore
« Reply #2 on: Sat, 08 May 2021, 23:10:34 »
Does it look like blue china if you use the blue-on-white alphanumeric keys with the Blue High Renaissance Novelties on a white board?  Any chance you have a picture of that?
Offline jaekid
    • Instagram
« Reply #3 on: Sun, 09 May 2021, 03:48:57 »
Hi there! Because of this question, I realized, I haven't done a number of renders with all white look: Lazurite Base + Calcite alphas + High Renaissance (Blue) novelties.
Take a look. ;)
Thank you for your question!
Offline AuroraCamo
« Reply #4 on: Sun, 09 May 2021, 09:13:00 »
What a great set! Can't wait to buy that D60 and put Laz on it
Offline mcpatty_mk
  • Formerly McPatty1926
« Reply #5 on: Sun, 09 May 2021, 12:32:46 »
One vendor that you can buy Lazurite from is Mechs and Co for those who live in the US: https://mechsandco.com/products/gb-gmk-lazurite?variant=34887354744967
« Last Edit: Sun, 09 May 2021, 13:02:38 by McPatty1926 »
Offline mcpatty_mk
« Reply #6 on: Sun, 09 May 2021, 12:37:04 »
Good mornoonight! It has been so awesome to see how far you have gone with your first set, Jae! You should be proud of yourself, and give yourself a pat on the back. All the collaborations and all the other things, like the renders of this set on many keyboards, have been amazing to be a witness, and I'm glad that I was able to find this set. Keep up the hard work because you're almost at the finish line. You got this!
Offline zionsped
    • Simbusped
« Reply #7 on: Sun, 09 May 2021, 16:43:31 »
Goodluck and congratulations!
Offline dvorcol
  • dvorcol#5071
« Reply #8 on: Sun, 09 May 2021, 23:44:48 »
Offline PradyXT
« Reply #9 on: Mon, 10 May 2021, 11:57:15 »
I like the blue novelties in this set :)
Offline jaekid
    • Instagram
« Reply #10 on: Mon, 10 May 2021, 12:35:22 »
Thank you for the support Aurora! KBDfans has some discount code which shall help you decide with the KBDfans x Lazurite D60Lite  ;)
Thank you as always Patty and the rest of the Brass Gang!
Thanks bro! GLWGB too!
I like your comment too.  :D Thank you!
« Last Edit: Tue, 11 May 2021, 22:35:43 by jaekid »
Offline jaekid
    • Instagram
Re: [GB] GMK Lazurite | May 7, 2021 to June 6, 2021
« Reply #11 on: Fri, 14 May 2021, 19:17:43 »
05/14/21
GMK Lazurite Group Buy is moving into its 2nd week. We’re pulling in the 1st week data and it shall be uploaded soon. Thank you very much for all your support! I’m really grateful for everyone who appreciated my dedication to this keycapset! Stay safe and healthy everyone!
*added new renders of GMK Lazurite on SWIFT65, an upcoming 65% keyboard by Swift Cables
Offline dvorcol
  • dvorcol#5071
« Reply #12 on: Fri, 14 May 2021, 21:01:34 »
Offline Khelby
« Reply #13 on: Sat, 15 May 2021, 07:50:34 »
Created an account to say thank you for this set! I'm drooling over here.
Offline jaekid
    • Instagram
« Reply #14 on: Sat, 15 May 2021, 11:23:05 »
Hey there! Thank you very much for taking the time to do this. I really appreciate it! Hope you stay safe and healthy!  :D
Offline saber8689
« Reply #15 on: Sat, 15 May 2021, 15:57:53 »
This set has grown on me. I really really like the novelties and the deskmats...I'll probably end up grabbing one!
Offline jaekid
    • Instagram
« Reply #16 on: Sun, 16 May 2021, 10:22:04 »
Thank you for dropping by and leaving a few comments! Hope you'd have a great build if you ever decide to make a purchase. Have a great day! ;D
Offline jaekid
    • Instagram
« Reply #17 on: Sun, 16 May 2021, 10:52:20 »
May 16, 2021, 10PM (ICT) | 11AM (EDT) EVENT (runs for 12HRS ONLY)
Goldenstar Keycap x GMK Lazurite
Artisan Keycaps Collaboration Raffle
IS LIVE
https://imgur.com/gallery/ypkdU7p
« Last Edit: Sun, 16 May 2021, 16:18:37 by jaekid »
Offline jaekid
    • Instagram
« Reply #18 on: Mon, 17 May 2021, 10:17:41 »
May 17, 2021, 9:30AM CST (24HRS Raffle)
Gooey Keys Hecky Lazurite is LIVE
Offline jaekid
    • Instagram
« Reply #19 on: Wed, 19 May 2021, 04:20:25 »
Sandun x GMK Lazurite ARTISAN RAFFLE SALES LIVE
May 19, 2021, 6:00PM PST (24HRS Raffle + GIVEAWAY) - Sandun Artisan (Korea) x GMK Lazurite Banbani and GB (Sandun Grimreaper Lazurite)
Sales Form
Raffle
- nomal Banbani : 10 available
- Lazurite gold Banbani : 20 available (limited edition)
- Lazurite white Banbani : 20 available (limited edition)
GB
- Grim reaper Gold Skull
- Grim reaper Ultramarine
- Grim reaper gold
- Grim reaper Antique
Offline jaekid
    • Instagram
GSK x GMK Lazurite Raffle Sales (R2) is LIVE
May 19, 2021, 10:00PM (ICT) | 3:00PM (WET) | 11:00AM (EDT) (12HRS R2 Raffle) - Goldenstar Keycap x GMK Lazurite Sokratis and Bara
RAFFLE FORM
IMAGES
Offline UnicornCables
    • Unicorn Cables
Wow, looks amazing, congratulations!
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
Very high effort set with one of the nicest mods sets of 2021
I'm not a fan of the base kit, but the Alt Alpha + Blue High Renaissance is a banger
And holy cow that's a lot of collabs. IMO the number of collabs detracts from the set itself (which is more than enough to stand alone). I counted 30 collabs. Gotta collect 'em all I guess.
Seems this is a GB of a Lazurite theme than the Lazurite keycap set itself
With that said, you can tell the level of effort and love poured into this, and I said this day 1 of seeing your IC
GLWGB.
Offline jaekid
    • Instagram
Thank you! Appreciate your time to drop a comment. :D
GLWGB.
Hi loop. Thank you for taking the time to leave your feedback about Lazurite!
Yes I get a lot of feedback/criticisms (maybe) for having a lot of collaborations. Majority of these collabs (especially artisan keycaps) are fairly new in the hobby and I believe I can be a bridge for them to have another platform to share their amazing craft. Of course it is mutually beneficial for the keyset and the collaborator; and that’s how it should be. By doing this, I was also able to gain a lot of friends in them along the way and get to learn more of the work poured into their craft. :D
Another consideration I had is the frustration of GB participants who buy a keyset and want a themed collaboration artisan with a very slim chance of winning raffle sales. It’s been a very tough project management for me but rest assured I make sure to not miss in promoting every collab in all platforms where Lazurite is uploaded. The design I envisioned was for the community after all and that’s how it’s supposed to be.
I’m just happy to get more involved in this hobby and to share my passion with the community. Thanks loop!
« Last Edit: Thu, 20 May 2021, 13:10:08 by jaekid »
Offline dvorcol
  • dvorcol#5071
« Reply #24 on: Thu, 20 May 2021, 19:31:12 »
« Last Edit: Sat, 22 May 2021, 15:32:17 by dvorcol »
Offline jaekid
    • Instagram
Offline dvorcol
  • dvorcol#5071
« Reply #26 on: Sat, 22 May 2021, 15:30:43 »
Offline jaekid
    • Instagram
« Last Edit: Sun, 23 May 2021, 14:56:16 by jaekid »
Offline jaekid
    • Instagram
Amidst The Clouds (Arizona, US) x GMK Lazurite Cloud Caps is NOW LIVE
CLICK PHOTO to access the form
« Last Edit: Tue, 25 May 2021, 12:42:53 by jaekid »
Offline jaekid
    • Instagram
Leonardo Da Mouse (UK) x GMK Lazurite Custom Mouse Mod Raffle is NOW LIVE (ends on the 28th of May at 12noon BST)
Customize your own mouse with the GMK Lazurite theme (kit buyers get a big discount)
« Last Edit: Tue, 25 May 2021, 12:57:12 by jaekid »
Offline dvorcol
  • dvorcol#5071
Offline jaekid
    • Instagram
Re: [GB] GMK Lazurite | 9 Days Left
« Reply #31 on: Thu, 27 May 2021, 13:16:22 »
This artisan keycap collaboration deserves a highlight. NORK has dedicated his time to encapsulate the inspiration of GMK Lazurite, the gemstone lapis lazuli and the pigment ultramarine.
NORK (Philippines)
Nonekomata - "The Origin of Blue
Pyrite | Calcite | Lazurite
These are the components of Lapis Lazuli, a semi-precious stone that was the source of the highly coveted color during the renaissance period, the Ultramarine Blue...
-NORK
Offline jaekid
    • Instagram
Re: [GB] GMK Lazurite | 7 Days Left
« Reply #32 on: Sun, 30 May 2021, 13:27:16 »
05/30/21
Last week to participate on the group buy of GMK Lazurite. Here's a render on a KL-90 Frost Ice.
Offline dvorcol
  • dvorcol#5071
« Reply #33 on: Sun, 30 May 2021, 15:06:23 »
Offline jaekid
    • Instagram
Re: [GB] GMK Lazurite | 6 Days Left | NORK Nonekomata RAFFLE LIVE
« Reply #34 on: Mon, 31 May 2021, 01:44:34 »
NORK (Philippines) x GMK Lazurite Nonekomata is NOW LIVE
Offline jaekid
    • Instagram
Re: [GB] GMK Lazurite | LAST DAY - all kits will be made
« Reply #35 on: Sat, 05 June 2021, 13:14:18 »
Last day to enter the Group Buy for GMK Lazurite. All kits will be made. Thank you to everyone who has supported GMK Lazurite and my journey in designing my first keyset from the beginning until the end of the GB. This wouldn't be possible without all your help. I am forever grateful for this opportunity!
Lazurite's colors and inspiration is based off lapis lazuli and the pigment ultramarine. The pigment's name came from the phrase ultra marinus which means beyond the sea; and my first keyset will always be the representation of the bond we form while we are in the hobby - a strong one that will stand the test of time even if we are far apart.
Offline dvorcol
  • dvorcol#5071
« Reply #36 on: Sat, 05 June 2021, 19:17:31 »
Offline mochili96
Re: [GB] GMK Lazurite | Counting Final Numbers
« Reply #37 on: Mon, 14 June 2021, 18:51:44 »
I'm so sad I JUST missed this by a couple days...it would've been PERFECT for the build I had in mind
Offline jaekid
    • Instagram
« Reply #38 on: Tue, 15 June 2021, 19:39:58 »
Extras will be available for pre-order don't worry. We will be uploading the final numbers soon.
Offline mochili96
« Reply #39 on: Tue, 15 June 2021, 21:01:02 »
Oh! I have no idea what these final numbers are supposed to mean, but approximately how soon should would pre-order for extras become available for order? Just wondering to know how often I should check back here, or the vendor's website??
Offline jaekid
    • Instagram
« Reply #40 on: Wed, 16 June 2021, 00:28:04 »
Final numbers for the keyset kits and accessories' total orders are uploaded together with the number of extras, so that the community know how much would be available to possibly acquire the set. As the designer and GB runner of Lazurite, I'll be posting updates re pre-orders inside the Discord server if in case anyone missed out on updates from different proxies/vendors. Thank you!
Offline jaekid
    • Instagram
Re: [GB] GMK Lazurite | Order Placed with GMK
« Reply #41 on: Wed, 23 June 2021, 08:09:08 »
06/23/21 Updates
Order placed with GMK.
Kits
Artisan Keycap
RAMA Lazurite - 363
Offline dvorcol
  • dvorcol#5071
« Reply #42 on: Wed, 23 June 2021, 22:48:16 »
<-- without extras
Offline Havattack
« Reply #43 on: Thu, 24 June 2021, 14:54:11 »
So now that that went so well, what are the chances of doing a GB of that gold on blue set that got nixed during the IC phase? That thing was by far the best. I was pretty bummed i had to bow out of this GB when that got cut.
(If it does happen, gold accent keys with blue legends please, especially the ornate corner ones)
Offline jaekid
    • Instagram
« Reply #44 on: Thu, 01 July 2021, 09:16:38 »
Thank you for following this thread brother. :D I'll know once all kits are shipped out. It will depend if there are people who'd also be interested to have that variant of Lazurite once we all see it in person.
Offline onceforever
« Reply #45 on: Thu, 01 July 2021, 23:01:06 »
See you in 3 years!
Offline Havattack
« Reply #46 on: Thu, 08 July 2021, 16:29:28 »
See you in 3 years!
Fock.
(Jesus, the childish rules in this forum are beyond stupid. As if there could ever be anything wrong with saying/typing ANY word. Dumb.)
« Last Edit: Thu, 08 July 2021, 16:31:29 by Havattack »
Offline nvh2092
« Reply #47 on: Sun, 11 July 2021, 06:15:23 »
You're not the only one interested in that kit. I was planning to buy that gold on blue base with the blue on gold novelty and the 2 got cut out completely.....
Offline Havattack
« Reply #48 on: Mon, 12 July 2021, 13:28:59 »
Same. I was still going to get in on the GB when they cut that base, but then they cut those novelties i wanted too, and i had to bow out. Such a shame, i was digging those 2 sets quite a bit.  :(
(Don't get me wrong, this set still turned out great, but I all ready have a couple white/blue sets- Striker,  Masterpiece-)
Offline nvh2092
« Reply #49 on: Mon, 12 July 2021, 15:11:44 »
Same situation with the blue on gold novs, the standard base kit will go very well with BOG novelties imo. The set is great with the design, I just don't understand why BOG novelty got cut out....
